Programing chip
slahiri
Programing chip
PostPosted: Sun Mar 02, 2003 1:26 pm     Reply with quote
How can I program my chip using my picstart-plus. I have the hex flie. I don't know how to set up picstart-plus and MPLABIDE ver 6.1.
___________________________
Original Post ID: 12278
Re: Programing chip
PostPosted: Sun Mar 02, 2003 2:34 pm     Reply with quote
:=How can I program my chip using my picstart-plus. I have the hex flie. I don't know how to set up picstart-plus and MPLABIDE ver 6.1.
There are many tutorials on the net, for setting up CCS
with MPLAB. A quick search with google found these two.
They are complete with screen shots.
<a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank">http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html</a>
<a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank">http://web.media.mit.edu/~r/projects/picsem/GettingStarted/</a>
With respect to 6.1, I don't use it, but that question is
asked about once a week on here. Do a quick search of the
board.
Original Post ID: 12282
slahiri
Re: Programing chip
PostPosted: Sun Mar 02, 2003 4:15 pm     Reply with quote
:=:=How can I program my chip using my picstart-plus. I have the hex flie. I don't know how to set up picstart-plus and MPLABIDE ver 6.1.
:=There are many tutorials on the net, for setting up CCS
:=with MPLAB. A quick search with google found these two.
:=They are complete with screen shots.
:= <a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank"> <a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank">http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html</a></a>
:= <a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank"> <a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank">http://web.media.mit.edu/~r/projects/picsem/GettingStarted/</a></a>
:=With respect to 6.1, I don't use it, but that question is
:=asked about once a week on here. Do a quick search of the
:=board.
I have no problem setting up CCS and MPlab IDE, I was able to complie the code and have the hex file. Now I like to program my chip using picstart plus. PC detect the picstartplus, I don't know how to export the hex file and then burn it into the chip.
Original Post ID: 12284
slahiri
Re: Programing chip
PostPosted: Sun Mar 02, 2003 6:31 pm     Reply with quote
:=:=:=How can I program my chip using my picstart-plus. I have the hex flie. I don't know how to set up picstart-plus and MPLABIDE ver 6.1.
:=:=There are many tutorials on the net, for setting up CCS
:=:=with MPLAB. A quick search with google found these two.
:=:=They are complete with screen shots.
:=:= <a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank"> <a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank"> <a href="http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html" TARGET="_blank">http://www.swarthmore.edu/NatSci/echeeve1/Ref/MPLab/MPLab_Intro.html</a></a></a>
:=:= <a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank"> <a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank"> <a href="http://web.media.mit.edu/~r/projects/picsem/GettingStarted/" TARGET="_blank">http://web.media.mit.edu/~r/projects/picsem/GettingStarted/</a></a></a>
:=:=With respect to 6.1, I don't use it, but that question is
:=:=asked about once a week on here. Do a quick search of the
:=:=board.
:=I have no problem setting up CCS and MPlab IDE, I was able to complie the code and have the hex file. Now I like to program my chip using picstart plus. PC detect the picstartplus, I don't know how to export the hex file and then burn it into the chip.
Thank I figured it out what was the problem I am able to program my chip.
Original Post ID: 12292
Mark
Re: Programing chip
PostPosted: Sun Mar 02, 2003 6:35 pm     Reply with quote
If you have setup the MPLAB IDE and CCS compiler and are compiling in the IDE, then it is as simple as choosing the PICSTART as your programmer in the IDE and then choosing to program the device. If you are not compiling from within the IDE then you must choose the import to memory from the file menu and then choose to program.
Regards,
Mark
:=:=board.
Original Post ID: 12294
