allenhuffman
Joined: 17 Jun 2019 Posts: 681 Location: Des Moines, Iowa, USA
| [Solved] ICD debugger printf output corrupted by timer? |
Posted: Mon Jun 08, 2026 7:38 am |
PIC24: 24FJ64GA002
EDIT: Further testing shows it is not timer2, specifically, but some combination. See attached code.
Our firmware was developed without the aid of debugging output (an impressive feat). When I inherited the code, I got printf output going to help me learn how things worked.
On one of our projects, using a 24FJ64GA002, using timer2 corrupts the debug printf via the ICD debugger console.
To work around this, I just called that function from timer3, which seemed to work fine.
Does anyone know why this would be? Compiler? Hardware design issue? PIC24 flaw? I did not see anything obvious in the errata when I looked into this years ago.
Cheers,
| Code: | #include <24FJ64GA002.h>
#device ICSP=1
#use delay(clock=32MHz,crystal=8MHz)
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#define DEBUGGER_ON 0 // Set both debugger #defines to use printf ().
#define DEBUGGER_WITH_PRINTF 1 // Set both debugger #defines to use printf ().
// Sets the debugger to ON
#if DEBUGGER_ON == 1
// Allows DEBUGGER
#device ICD=TRUE
#endif
// Allows both the debugger and the printf ()
#if DEBUGGER_WITH_PRINTF == 1
// Turn on the RS-232 functionality.
#use rs232 (ICD)
#define DEBUG_PRINTF printf
#else
#define DEBUG_PRINTF(...)
#endif
#define LED_OK PIN_B6 // LED2 enable
#define DIGITAL_IN2_ESTOP PIN_B5 // Digital input #2 - E-Stop
// Timer constants
#define TIME_1_MS 0x07D1 // A one millisecond timer period.
#define TIME_10_MS 0x4E21 // A ten millisecond timer period.
#define TIME_1_SEC 0xF425 // A one second timer period.
#define MOD_VALUE 60000
#define USE_TIMER1
#define USE_TIMER2
#define USE_TIMER3
//#define USE_TIMER4
//#define USE_TIMER5
#include <stdint.h>
// Globals
volatile uint32_t g_Tick1 = 0;
volatile uint32_t g_Tick2 = 0;
volatile uint32_t g_Tick3 = 0;
volatile uint32_t g_Tick4 = 0;
volatile uint32_t g_Tick5 = 0;
// Timer ISRs
#INT_TIMER1 LEVEL=6
void timer1_isr (void)
g_tick1++;
#INT_TIMER2 LEVEL=6
void timer2_isr (void)
g_tick2++;
#INT_TIMER3 LEVEL=6
void timer3_isr (void)
g_tick3++;
#INT_TIMER4 LEVEL=6
void timer4_isr (void)
g_tick4++;
#INT_TIMER5 LEVEL=6
void timer5_isr (void)
g_tick5++;
// Main
DEBUG_PRINTF ("\nUniversal test: "__DATE__" "__TIME__"\r");
// Setup and initialize each timer to 1ms.
#ifdef USE_TIMER1
setup_timer1 (TMR_INTERNAL | TMR_DIV_BY_8, TIME_1_MS);
enable_interrupts (INT_TIMER1);
#endif
// This messes up debug output for some reason, so it will now be handled
// inside the TIMER3 ISR.
#ifdef USE_TIMER2
setup_timer2 (TMR_INTERNAL | TMR_DIV_BY_8, TIME_1_MS);
enable_interrupts (INT_TIMER2);
#endif
#ifdef USE_TIMER3
setup_timer3 (TMR_INTERNAL | TMR_DIV_BY_8, TIME_1_MS);
enable_interrupts (INT_TIMER3);
#endif
#ifdef USE_TIMER4
setup_timer4 (TMR_INTERNAL | TMR_DIV_BY_8, TIME_1_MS);
enable_interrupts (INT_TIMER4);
#endif
#ifdef USE_TIMER5
setup_timer5 (TMR_INTERNAL | TMR_DIV_BY_8, TIME_1_MS);
enable_interrupts (INT_TIMER5);
#endif
disable_interrupts (GLOBAL);
uint32_t tick1 = g_tick1;
uint32_t tick2 = g_tick2;
uint32_t tick3 = g_tick3;
uint32_t tick4 = g_tick4;
uint32_t tick5 = g_tick5;
enable_interrupts (GLOBAL);
#ifdef USE_TIMER1
if (tick1 % MOD_VALUE == 0) { printf ("\n1: %lu\r", g_tick1); }
#endif
#ifdef USE_TIMER2
if (tick2 % MOD_VALUE == 0) { printf ("\n2: %lu\r", g_tick2); }
#endif
#ifdef USE_TIMER3
if (tick3 % MOD_VALUE == 0) { printf ("\n3: %lu\r", g_tick3); }
#endif
#ifdef USE_TIMER4
if (tick4 % MOD_VALUE == 0) { printf ("\n4: %lu\r", g_tick4); }
#endif
#ifdef USE_TIMER5
if (tick5 % MOD_VALUE == 0) { printf ("\n5: %lu\r", g_tick5); }
#endif
// End of file.
_________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
Last edited by allenhuffman on Mon Jun 08, 2026 12:00 pm; edited 1 time in total |
jeremiah
Posted: Mon Jun 08, 2026 11:19 am |
It's a software serial port so you'll want to disable interrupts for the stream:
#use rs232 (ICD, DISABLE_INTS, stream=DEBUG_STREAM)
allenhuffman
Posted: Mon Jun 08, 2026 11:56 am |
| jeremiah wrote: | It's a software serial port so you'll want to disable interrupts for the stream:
Wow, wish I knew this years ago. I had no idea interrupts were being enabled when using something that did not need interrupts.
Thank you! _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606. |
jeremiah
Posted: Mon Jun 08, 2026 3:25 pm |
| allenhuffman wrote: | | jeremiah wrote: | It's a software serial port so you'll want to disable interrupts for the stream:
Thank you! |
They are not being enabled for things that do not need interrupts. Your code enabled interrupts:
DISABLE_INTS just turns off all of your interrupts temporarily while a software UART operation is being performed.
Hopefully that helps explain it better! |
allenhuffman
Posted: Mon Jun 08, 2026 3:27 pm |
| jeremiah wrote: |
That is a clear explanation. By default, it will not mask interrupts, but if you are using other IRQs, you can tell it to mask. Makes perfect sense. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
