allenhuffman
Joined: 17 Jun 2019 Posts: 681 Location: Des Moines, Iowa, USA
| Fun PCD 5.123 bug with passing structures |
Posted: Wed May 13, 2026 7:32 am |
CCS support is aware of this, but I ran into an issue where 1 == 1 was not tru ;-) Here is the test program:
| Code: | #include "main.h"
#include <stdint.h>
typedef struct
uint8_t type;
uint8_t length;
uint16_t offset; // or uint8_t if not struct is > 255 bytes.
} tlv_offset_entry_t;
tlv_offset_entry_t testTLV[] =
{ 1, 10, 100 },
{ 2, 20, 200 },
{ 0, 0, 0 }
void test (tlv_offset_entry_t * table)
unsigned int type = 1; // This will fail
//uint8_t type = 1; // This will work
printf ("test: Is %u == %u? ", table[0].type, type);
if (table[0].type == type)
// Yes
puts ("Yes\r\n");
// No
puts ("No\r\n");
printf ("main: Is %u == %u? ", testTLV[0].type, type);
if (testTLV[0].type == type)
// Yes
puts ("Yes\r\n");
// No
puts ("No\r\n");
test (testTLV);
This will run and the compare in main() works fine, but the compare against the same value once passed to a function will fail. The output:
| Code: | main: Is 1 == 1? Yes
test: Is 1 == 1? No
So even though it prints the proper value, the compare fails. From what support said, they think the optimizer may have removed something that would have cleared half of the 16-bit value used in the compare when comparing against the uint8_t value.
Fun one. This took me down quite the rabbit hole to figure out where the issue was.
My workaround of just using an uint8_t worked for THIS example and my original version, but once I shifted some code around and changed the size or whatever, it stopped working again. I am testing a second workaround today, but support may beat me to it. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606. |
Posted: Wed May 13, 2026 12:02 pm |
That suspiciously sounds like they may have re-introduced a problem they
had about 50 versions ago.
They were getting the sizes wrong in PCD when pointers were passed,
not performing the arithmetic correctly. You should be able to see if that
is happening with an ICD.
Does it work correctly on say 5.121?.
If so, learn the lesson that many of the posters here will quote.
Don't change versions unless you need a feature from the newer version.
It saves a lot of problems. |
allenhuffman
Posted: Wed May 13, 2026 12:07 pm |
| Ttelmah wrote: | That suspiciously sounds like they may have re-introduced a problem they
Very true.
Though every company I have ever contacted to get help with an older version always says "try it on the current supported version then get back to us" ;-) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Thu May 14, 2026 11:36 am |
When I have had problems with a new release, one of the first things CCS
often asks if if the fault was there with the previous release(s), and if it
only appeared at a particular version, they will suggest you carry on with
the older code until they have a fix.
Having the past 'history' allows them to speed up identifying what they
have got wrong.
I've had Microsoft do the same when a new driver update causes issues. |
allenhuffman
| Ttelmah wrote: | When I have had problems with a new release, one of the first things CCS
have got wrong. |
Well, we are running 5.123 because it fixes an issue we found with the previous release ;-) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Thu May 14, 2026 11:46 am |
For anyone else playing along at home...
Looks like we encountered our previous issue in 5.118. They provided an internal 5.122 with a fix, and then it was rolled in to the release of 5.123. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Sat May 16, 2026 10:58 am |
As a silly question, would it be possible for you to pass by reference?,
I find I was having an issue with passing pointers. The compiler did not
correctly know about the size of structures when they were handled using
pointers, but they did work if I passed by reference instead. |
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Posted: Wed May 20, 2026 4:34 am |
| Ttelmah wrote: | As a silly question, would it be possible for you to pass by reference?,
Following on from this, why would you want to avoid passing by reference? Passing by reference save wasting cycle on pushing data structures on the stack keeping the stack smaller and saving CPU cycles. _________________ Regards, Andrew
Posted: Wed May 20, 2026 7:03 am |
Agreed.
The normal 'disadvantage' of passing by reference is that you can
inadvertently change the source variable, but that applies equally with
pointers. Normally faster, and uses less storage. For me it fixed the
problem with passing pointers in this case.
It would be 'nice' to have this fixed, but if using by reference fixes the
issue, then it probably is the better way to go. |
jeremiah
Posted: Fri May 29, 2026 8:01 am |
| asmallri wrote: | | Ttelmah wrote: | As a silly question, would it be possible for you to pass by reference?,
Following on from this, why would you want to avoid passing by reference? Passing by reference save wasting cycle on pushing data structures on the stack keeping the stack smaller and saving CPU cycles. |
The main drawback is that passing by reference sometimes forces function inlining, which may not be desired for some larger functions. |
