cannot get RDA2 interrupt to fire -- SOLVED
mtsoule
PostPosted: Mon Apr 06, 2026 8:26 am     Reply with quote
I feel I am overlooking something simple and need another set of eyes, I cannot get RDA2 interrupt to fire, I have seen all the previous posts but none has helped, I suspect it has something to do with my Pin Select since I can’t even get a kbhit() to work. My timer1 interrupt is working as expected but RDA2 is not, any help is appreciated.
main.h
//                      ifdef Section
#ifndef   _MAIN_H
#define   _MAIN_H
//                      Include Section
//#device ICD=TRUE
//////// Program memory: 65536x16  Data RAM: 8192  Stack: 127
//////// I/O: 44   Analog Pins: 43
//////// Data EEPROM: 1024
//////// C Scratch area: 500   ID Location: 200000
//////// Fuses: LP,XT,HS,NOEXTOSC,ECL,ECM,ECH,RSTOSC_HFINTRC_64MHZ
//////// Fuses: RSTOSC_EXT_PLL,RSTOSC_SOSC,RSTOSC_LFINTRC
//////// Fuses: RSTOSC_HFINTRC_1MHZ,RSTOSC_EXT,CLKOUT,NOCLKOUT,PRLOCK1WAY
//////// Fuses: NOPRLOCK1WAY,CKS,NOCKS,FCMEN,NOFCMEN,MCLR,NOMCLR,PUT_1MS
//////// Fuses: PUT_16MS,PUT_64MS,NOPUT,MVECEN,NOMVECEN,IVT1WAY,NOIVT1WAY
//////// Fuses: LPBOR,NOLPBOR,NOBROWNOUT,BROWNOUT_SW,BROWNOUT_NOSL,BROWNOUT
//////// Fuses: BORV28,BORV27,BORV24,BORV19,ZCDDIS,NOZCDDIS,PPS1WAY
//////// Fuses: NOPPS1WAY,STVREN,NOSTVREN,LVP,NOLVP,XINST,NOXINST,WDT64
//////// Fuses: WDT128,WDT256,WDT512,WDT1024,WDT2048,WDT4096,WDT8192
//////// Fuses: WDT16384,WDT32768,WDT65536,WDT131072,WDT262144,WDT524299
//////// Fuses: WDT1048576,WDT2097152,WDT4194304,WDT8388608,WDT32,WDTSW
//////// Fuses: NOWDT,WDT_SW,WDT_NOSL,WDT,WDTWIN_12%,WDTWIN_25%,WDTWIN_37%
//////// Fuses: WDTWIN_50%,WDTWIN_62%,WDTWIN_75%,WDTWIN_100%,WDTWIN_SW
//////// Fuses: WDTCLK_LFINTRC,WDTCLK_MFINTRC,WDTCLK_SOSC,WDTCLK_SW,BBSIZ32K
//////// Fuses: BBSIZ16K,BBSIZ8K,BBSIZ4K,BBSIZ2K,BBSIZ1K,BBSIZ512,BOOTBLOCK
//////// Fuses: NOBOOTBLOCK,SAF,NOSAF,DEBUG,NODEBUG,WRTB,NOWRTB,WRTC,NOWRTC
//////// Fuses: WRTD,NOWRTD,WRTSAF,NOWRTSAF,WRT,NOWRT,PROTECT,NOPROTECT
#device PIC18F57Q43
#device PASS_STRINGS = IN_RAM
#FUSES RSTOSC_HFINTRC_64MHZ
#FUSES NOBROWNOUT
#use delay(internal = 64MHz)
//                      Define Section
#define Success   1
#define Pass   1
#define Fail   0
#define Amb_Fail   3
#define Invalid_Input   2
#define True   1
#define False   0
// DEFINTION OF I/O PORTS
// ALL INPUT PINS ARE DEFINED USING THE PORT ADDRESS
// ALL OUTPUT PINS ARE DEFINED AS USING THE PORT LATCH ADDRESS
// ***** PORT 'A' *****
#define TRISA_RUN       0xFF         // 1000 1011
#define PORTA_RUN       0xFF         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'A' I/O FUNCTIONS
#define   PORTA_0         pin_A0           //
#define PORTA_1         pin_A1      //
#define PORTA_2         pin_A2      //
#define PORTA_3         pin_A3      //
#define   PORTA_4         pin_A4      //
#define PORTA_5         pin_A5      //
#define TXD3         pin_A6      // SIM7000 TXD
#define RXD3          pin_A7      // SIM7000 RXD
// ***** PORT 'B' *****
#define TRISB_RUN       0xFF         // 1000 1011
#define PORTB_RUN       0xFF         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'B' I/O FUNCTIONS
#define PORTB_0         pin_B0      //
#define PORTB_1         pin_B1      //
#define PORTB_2         pin_B2      //
#define PORTB_3         pin_B3      //
#define PORTB_4         pin_B5      //
#define PORTB_5         pin_B4      //
#define ICSPCK          pin_B6      // In Circuit Serial Programming Clock
#define ICSPD           pin_B7      // In Circuir Serial Programming Data
// ***** PORT 'C' *****
#define TRISC_RUN       0xFF         // 1000 1011
#define PORTC_RUN       0xFF         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'C' I/O FUNCTIONS
#define PORTC_0         pin_C0      //
#define PORTC_1         pin_C1      //
#define PORTC_2         pin_C2      // Flash CE
#define PORTC_3       pin_C3      // Flash SCLK
#define PORTC_4         pin_C4      // Flash Data In
#define PORTC_5         pin_C5      // Flash Data Out
#define TXD1         pin_C6      // Output   - Dbug serial TX
#define RXD1         pin_C7      // Input   - Dbug serial RX
// ***** PORT 'D' *****
#define TRISD_RUN       0x02         // 1000 1011
#define PORTD_RUN       0x02         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'D' I/O FUNCTIONS
#define TXD2         pin_D0      //O ESP8266 TXD
#define RXD2            pin_D1        //I ESP8266 RXD
#define PORTD_2         pin_D2      //O
#define PORTD_3         pin_D3      //O
#define PORTD_4         pin_D4      //O LCD Data 4
#define PORTD_5         pin_D5      //O LCD Data 5
#define PORTD_6         pin_D6      //O LCD Data 6
#define PORTD_7         pin_D7      //O LCD Data 7
// ***** PORT 'E' *****
#define TRISE_RUN       0x00         // 1000 1011
#define PORTE_RUN       0x00         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'E' I/O FUNCTIONS
#define LED_R           pin_E0      // LCD Enable
#define LED_G           pin_E1      // LCD RS
#define LED_B           pin_E2      // LCD RW
#define VPP            pin_E3      // Programming Voltage
// ***** PORT 'F' *****
#define TRISF_RUN       0xFF         // 1000 1011
#define PORTF_RUN       0xFF         // PORTA OUTPUT INITIALIZATION DATA
// DEFINE PORT 'F' I/O FUNCTIONS
#define PORTF_0         pin_F0      //
#define PORTF_1         pin_F1      //
#define PORTF_2         pin_F2      //
#define PORTF_3         pin_F3      //
#define PORTF_4         pin_F4      //
#define PORTF_5         pin_F5      //
#define PORTF_6         pin_F6      //
#define PORTF_7         pin_F7      //
#PIN_SELECT RX1=RXD1    //C7 pin 1
#PIN_SELECT TX1=TXD1    //C6 pin 48
#PIN_SELECT RX2=RXD2    //D1 pin 43
#PIN_SELECT TX2=TXD2    //D0 pin 42
#PIN_SELECT RX3=RXD3    //A7 pin 32
#PIN_SELECT TX3=TXD3    //A6 pin 33
#use delay(INT=32000000)
//#USE SPI (MASTER, DI=SDI1, DO=SDO1,CLK=SCK1,MODE=0, bits=8, STREAM=FLASH)
#use rs232(uart1,baud=115200,parity=N,xmit=TXD1,rcv=RXD1,bits=8,stream=Dbug)
#use rs232(uart2,baud=115200,parity=N,xmit=TXD2,rcv=RXD2,bits=8,stream=SIM)
#use rs232(uart3,baud=115200,parity=N,xmit=TXD3,rcv=RXD3,bits=8,stream=ESP)
//                      Function Prototypes Section
// INTERNAL GLOBAL VARIABLES
//#define Dbug 0
// Default Defines
//#define True 1
//#define False 0
//Backlight Defines
#define Off      0
#define Red      1
#define Green   2
#define Blue   4
// EEPROM Locations
#define EE_SSID         0x0000
#define EE_PW         0x0040
#define EE_Amb_Delta      0x02
char New_Dbug_Char;
int1 Dbug_Mode = True;
int t1_overflow;
int T1_OV_Flag;
int mike;
int Connection_Status;
char New_ESP_Char, New_Sim_Char;
int1 ESP_Char_Ready, SIM_Char_Ready, Dbug_Char_Ready;
char Device_SN[20]="48:3f:da:59:80:83";
char Get_WIFI_SSID[32] ="";
char Get_WIFI_PW[32]="";
int WIFI_Failed = False;
unsigned int Current_Connection_Status;
#define ESP8266_Awake      0
#define ESP8266_Connected   1
#define ESP8266_Comm_Good   2
#define ESP8266_Disable      3
#define SIM_Awake          4
#define SIM_Connected      5
#define SIM_Comm_Good      6
#define SIM_Disable        7
main.c
#include "18F57Q43.h"
#include "main.h"
#include "SIM7000A.h"
#include "SIM7000A.c"
#include "isr.c"
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void Setup_Config(void);
int main (int argc, char** argv)
    Setup_Config();
   while(True)
        while (kbhit(SIM))
            output_low(LED_R);
            fprintf(sim,"uart2 output");//output_toggle(LED_R);
        output_toggle(LED_B);
    return (0);
   setup_oscillator(OSC_HFINTRC_64MHZ);
   SET_TRIS_A(TRISA_RUN);
   SET_TRIS_B(TRISB_RUN);
   SET_TRIS_C(TRISB_RUN);
   SET_TRIS_D(TRISB_RUN);
   SET_TRIS_E(TRISB_RUN);
   SET_TRIS_F(TRISB_RUN);
   setup_timer_1(T1_HFINTRC|T1_DIV_BY_1);// Timer1 interrupt
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   enable_interrupts(INT_RDA3);
//    setup_wdt(WDT_ON|WDT_16S);
    // turn LEDS off
    output_high(LED_R);
    output_high(LED_G);
    output_high(LED_B);
   return;
isr.c
#include "main.h"
//#include "SIM7000A.h"
int t1_overflow;
int T1_OV_Flag;
// The Timer One Inturrupt Service Routine
#int_TIMER1
void  T1_isr(void)          //   32MHz Clock = 8MHz Instruction Cycle (0.125uS)
{                     //   16 Bit Timer = 0.125uS * 65535 = 0.00819mS
t1_overflow++;            //
//Second_Ctr_Temp++;      //  8.19mS Inturrupt
//output_toggle(LED_G);
//Sleep_Pulse++;
//BT_Conn_Time_out++;
//output_toggle(PORTB_0);
//if (t1_overflow == 0x00) output_toggle(LED_B);
T1_OV_Flag =1;            //
// The UART interrupt, is connected to the Bluetooth receiving data
// UART1 Int
#INT_RDA
void RDA_isr(void)
    output_low(LED_G);
   New_Dbug_Char=fgetc(Dbug);
// UART2 Int
#INT_RDA2
void RDA2_isr(void)
    output_low(LED_R);
   New_SIM_Char=fgetc(SIM);
// UART3 Int
#INT_RDA3
void RDA3_isr(void)
    output_low(LED_B);
   New_SIM_Char=fgetc(ESP);
gaugeguy
PostPosted: Mon Apr 06, 2026 11:38 am     Reply with quote
main does not accept any variables and does not return any. There is nothing to return to.
in the #use rs232 just specify the hardware UART port and do not specify the pins. That is what #pin_select is for.
mtsoule
PostPosted: Wed Apr 08, 2026 11:17 am     Reply with quote
gaugeguy, i tried your suggestion, still no joy... but thank you i just dont know why my RDA2 is not working..
gaugeguy
PostPosted: Wed Apr 08, 2026 12:08 pm     Reply with quote
Where do you disable the analog functions for those pins?
PostPosted: Wed Apr 08, 2026 10:59 pm     Reply with quote
You ned to look at table 21-1, The pins you are using do not support
UART2. Sad
mtsoule
PostPosted: Fri Apr 10, 2026 5:33 am     Reply with quote
i changed my pin selects to the default locations, according to the DS, i am transmitting correctly, but receive is still not happening, i dont knoow why....
#PIN_SELECT RX2=ICSPD   //B7 pin 19
#PIN_SELECT TX2=ICSPCK  //B6 pin 18
#use rs232(uart2,baud=115200,parity=N,xmit=ICSPCK,rcv=ICSPD,bits=8,stream=SIM)
gaugeguy
PostPosted: Fri Apr 10, 2026 6:05 am     Reply with quote
Post the code where you handle the analog inputs. Pins default to analog on power up. A pin defined as analog will not be able to be read as a digital input or digital peripheral.
mtsoule
PostPosted: Fri Apr 10, 2026 7:50 am     Reply with quote
i have added ansel to the main.h file, still no receive
#byte ANSEL=0x00; // All i/o digital.
#use delay(INT=64000000)
#use rs232(uart2,baud=115200,parity=N,bits=8,stream=SIM)
jeremiah
PostPosted: Fri Apr 10, 2026 9:15 am     Reply with quote
Question: Is this still a thing for other chips?
For our pic18's and pic24's I haven't had to initialize them to digital in nearly a decade as the compiler does that for us before calling main(). But we also keep to a pretty consistent group of PICs to use, so it may be chip specifiic.
gaugeguy
PostPosted: Fri Apr 10, 2026 12:54 pm     Reply with quote
That is incorrect. That defines a byte size variable at address 0 called ANSEL.
the analog select registers are:
ANSELA
ANSELB
ANSELC
ANSELD
the way to take care of this in CCS is
setup_adc_ports(NO_ANALOGS);
PostPosted: Fri Apr 10, 2026 2:24 pm     Reply with quote
Most PICs default to waking with the analog pins enabled. On 90% the
compiler will automatically default to disabling them. However on a few
it doesn't, so it is always safer to set this yourself. On some of the later
chips the peripheral select bit set when a peripheral is connected, overrides
this. It is one of those settings, it is always best to make, especially when
a problem appears.
PostPosted: Sat Apr 11, 2026 5:31 am     Reply with quote
As a 'dinosaur' , I remember when PICs only had digital I/O pins and you could see the guts through the quartz windows.....
..kinda miss those days, life and PIC programming was simpler
mtsoule
PostPosted: Sat Apr 11, 2026 6:29 am     Reply with quote
gaugeguy:
That was the answer, thank you sir!!! i dont know why i thought they were default digital and i thought TRIS would take care of it.. you learn something new everyday.
and
temtronic:
i still have a bunch of those, that what i learned on, i had about 5 chips and an eraser and would FIFO them as i am debugging.
