GregEnReus
| Strange #ORG issue |
Posted: Wed Mar 18, 2026 2:42 pm |
I've written a Bootloader.
Why?
Long story. Anyway, it works perfectly. I want to locate it at the top of the memory space.
This compiles:
#build(Reset=0x1700, Interrupt=0x0008:0x0018)
#org 0x0010,0x16FF {}
#org 0x0000, 0x0006
void ForceResetVector() {
#asm
GOTO 0x1700
#endasm
Not only does it compile but the application also works. Perfectly.
There's plenty of room above the compiler code but this does not compile:
#build(Reset=0x1800, Interrupt=0x0008:0x0018)
#org 0x0010,0x17FF {}
#org 0x0000, 0x0006
#asm
GOTO 0x1800
#endasm
The compiler complains as follows:
*** Error 71 "UpperMemoryFBDPBootloader.c" Line 333(0,1): Out of ROM, A segment or the program is too large MAIN
Seg 01808-01CBE, 00AE left, need 00D2
Seg 00000-00006, 0002 left, need 00D2
Seg 00008-0000E, 0008 left, need 00D2
Seg 00010-017FE, 17F0 left, need 00D2
Seg 01800-01806, 0004 left, need 00D2
Any insight as to my stupidity in this will be thankfully received. |
Posted: Wed Mar 18, 2026 2:53 pm |
| wild guess... have you totally erased the PIC ? |
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
| Re: Strange #ORG issue |
Posted: Wed Mar 18, 2026 6:32 pm |
| GregEnReus wrote: | I've written a Bootloader.
Why?
You did not mention what PIC you are using. From the output it looks like you are out or program memory.
I assume you are not using interrupts in the bootloader. If this is the case then yuo do not need the interrupt declaration in the build statement. _________________ Regards, Andrew
GregEnReus
Posted: Thu Mar 19, 2026 3:28 am |
Hello Andrew, from Brush Electronics no less!
Thank you for taking the time to reply.
| asmallri wrote: |
I assume you are not using interrupts in the bootloader. If this is the case then yuo do not need the interrupt declaration in the build statement. |
18F1320
Why?
That's what I had in the parts box.
I found when writing the bootloader that the only way I could make it work was to totally avoid interrupts. The code polls the soft UART.
For a long time, when I tried this:
#build(Reset=0x1700), with any combination of #org, the compiler would complain. Now for some inexplicable reason it compiles! So thanks for the Andrew, that's awesome.
So then, this compiles:
#org 0x0000, 0x0006
#asm
GOTO 0x1700
#endasm
And the program memory looks like this:
0000 EF80 F00B 0C00 FFFF FFFF FFFF FFFF FFFF ........ ........
The application starts at 0x1700:
1700 EF7D F00D FFFF FFFF 6AF7 0F18 6EF6 0E17 }....... .j...n..
1710 22F7 0009 50F5 0012 4246 5044 5620 2E31 ."...P.. FBDP V1.
1720 3632 0000 860B 9093 9093 808A 0E50 6ED3 26...... ....P..n
1730 50D3 6A3B 6A3A 6A39 0E01 6E38 9093 908A .P;j:j9j ..8n....
1740 EFCC F00D C04B F04D C04A F04C C04D F003 ....K.M. J.L.M...
The application ends at 0x1BCA:
1B90 960B 6A40 6A41 D5C6 0E00 BA9E 0E01 0801 ..@jAj.. ........
1BA0 E101 D73A A60B D00F 960B 6A41 0E1B 6E40 ..:..... ..Aj..@n
1BB0 6A42 5042 DDA9 2A42 6E00 6E43 D749 0E0A BjBP..B* .nCnI...
1BC0 5C42 E1F7 DDDA D753 D7E7 D7FF FFFF FFFF B\....S. ........
1BD0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
We then have blank memory all the way up to 0x1FFF:
1FC0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
1FD0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
1FE0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
1FF0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
If I then try to push the code further up to 0x1800 the compiler complains with:
*** Error 71 "UpperMemoryFBDPBootloader.c" Line 334(0,1): Out of ROM, A segment or the program is too large MAIN
Seg 01808-01CBE, 00C6 left, need 00D2
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Thu Mar 19 09:52:50 2026
After some more digging around I think it may be that the compiler is reserving the "tail end" of the memory for internal library functions, stack space, or its own specialised "startup" code that it doesn't want the #ORG pragma to trample on.
I tried replacing the code with a 1 line application that just turns B0 on.
I managed to push it all the way up to 0x1C00 but that's still 1k shy of the 8k memory space limit.
Interesting. |
Posted: Thu Mar 19, 2026 5:45 am |
hmm,
doesn't this mean the segment( memory) starting at 1800 is only 7 bytes long ? and you need a lot more ??
would need to see the datasheet to see the 'memory map'.. but I've got 3000# of steel to relocate first.... |
Posted: Thu Mar 19, 2026 8:00 am |
One big thing is that the PIC18, only allows RESET to be to the base of
memory. To use a high memory boot loader, you would need a reset handler
at the bottom of memory that then jumps to the high memory boot-loader.
It can be done, but all uses extra space, since this re-vector code at the
bottom of memory has to be protected as well as the boot loader itself.
This is why low memory boot loaders are really the 'standard' for the PIC. |
jeremiah
Posted: Thu Mar 19, 2026 8:29 am |
Why?
This compiles:
#org 0x0000, 0x0006
#asm
GOTO 0x1700
#endasm
#org 0x0000, 0x0006
#asm
GOTO 0x1800
#endasm
So I took your second chunk you said wasn't working, tossed into a file with an empty main() and it compiled in both versions 5.025 and 5.119 for me without errors. Here is the file:
#case
#include <18F1320.h>
#org 0x0000, 0x0006
#asm
GOTO 0x1800
#endasm
void main(){
while(TRUE);
And the results:
Memory usage: ROM=0% RAM=2% - 2%
0 Errors, 0 Warnings.
Build Successful.
So maybe something else in your file is causing issues? |
GregEnReus
Posted: Thu Mar 19, 2026 10:36 am |
| jeremiah wrote: | | So maybe something else in your file is causing issues? |
Hello Jeremiah,
Let's have a look....
#org 0x0000, 0x0006
#asm
GOTO 0x1800
#endasm
void main(){
while(TRUE);
Yes, that compiles. But this doesn't:
#build(Reset=0x1E00, Interrupt=0x0008:0x0018)
#org 0x0010,0x1DFF {}
#org 0x0000, 0x0006
#asm
GOTO 0x1E00
#endasm
void main(){
while(TRUE);
Your code is a basically a While loop, it requires 32 bytes of program memory. The highest it will go without the compiler complaining is:
#build(Reset=0x1C00, Interrupt=0x0008:0x0018)
#org 0x0010,0x1BFF {}
#org 0x0000, 0x0006
#asm
GOTO 0x1C00
#endasm
void main(){
while(TRUE);
From 0x1C00 to 0x1FFF is 1k bytes.
Anyway, it is as it is. It's fine. Thanks for taking the time to look at this. I will no doubt be able to shrink my bootloader code and then I'll be able to push it a little further up.
Golden  |
jeremiah
Posted: Fri Mar 20, 2026 7:44 am |
Actually your second one compiles for me as well, both in versions 5.025 and 5.119.
I may have missed it earlier, what version of the compiler are you using? Maybe I can match it and see if it is a version bug?
For reference, I compiled the following code, which was copy pasted from your post:
#org 0x0000, 0x0006
#asm
GOTO 0x1E00
#endasm
void main(){
while(TRUE);
The result was:
Build Successful.
with the hex generated:
File Summary:
Filename: main.hex
File Status: Good
Target Chip: PIC18F1320
File Type: INHX32 (Intel Hex)
Program Size: 16 Instructions (1%)
Program Range: 0000-0007, 1DFF-1E1B
Data EE Size: 0 bytes
Checksum: D2B2
Config Size: 14 bytes
Created: 20-Mar-26 09:42
Addresses are: Byte addresses
Program Memory
000000: EF00 F00F 0100 0012
001E00: EF04 F00F
001E08: 6AF8 9ED0 9CC2 9EC2
001E10: 50C1 0B80 097F 6EC1 D7FF 0003
Configuration Words
300000: CF00 1E0E 8000 0081 C003 E003 4003
;PIC18F1320
;CRC=7FCB CREATED="20-Mar-26 09:42"
It's weird that it won't compile for you but it will me, so I'm wondering if it is a specific compiler version fluke.
Also can you please use the code tags for your code so it is more readable for us. I can't speak for others, but I have old man eyes, so anything to help me see it better would be appreciated1 |
GregEnReus
Posted: Fri Mar 20, 2026 2:09 pm |
| jeremiah wrote: | | I may have missed it earlier, what version of the compiler are you using? |
Hello Jeremiah,
The version of my CCS compiler is 4.068
I apologise but I don't know what you're referring to by Code Tags. |
gaugeguy
Posted: Fri Mar 20, 2026 2:19 pm |
| 4.068? That version is almost 20 years old. It might be time to update. |
newguy
Posted: Fri Mar 20, 2026 3:23 pm |
| GregEnReus wrote: | | jeremiah wrote: | | I may have missed it earlier, what version of the compiler are you using? |
Hello Jeremiah,
Above the editor window are a set of buttons: Bold text, Italic text, Underline text, a Quote button, and then the Code button.
When you paste code into the editor window, highlight it all, then press the Code button. The selection will then have code formatting applied. |
Posted: Fri Mar 20, 2026 4:58 pm |
4.068 is 20 years old ???
yeesh, I started with 2.453..... |
asmallri
Posted: Fri Mar 20, 2026 10:30 pm |
[quote="]One big thing is that the PIC18, only allows RESET to be to the base of
This is why low memory boot loaders are really the 'standard' for the PIC.[/quote]
I know Ttelmah knows his stuff. My comment is for the benefit of others that may not have the same depth of knowledge when it comes to bootloaders.
I agree with the Ttelmah in his post above except for the commment about 'standard' I think either is equally appropriate and I am not advocating for one over the other.
The case for the hgh memory bootloader is that most applications, built before a bootloader was considered for the project/product, will expect to start at 0x0000. A high memory bootloader, that does not use interrupts, can be added without recompiling the application. This also means there is no requirement to remap interrupt vectors and therefore there is no double jump required to enter the application interrupt handlers and, as a consequence, they deliver a lower interrupt latency than when a low memory bootlooader is used.
As Ttelmah mentioned, the high memory bootloader's limitation is the additional complexity in the bootloader code to protect the reset vector and still enable the bootloader to install application code anywhere in program memory above the reset vector up to the the code page immediately below the code page contiing the start of the bootloader. _________________ Regards, Andrew
GregEnReus
Posted: Sat Mar 21, 2026 10:26 am |
| asmallri wrote: | | The case for the hgh memory bootloader is that most applications, built before a bootloader was considered for the project/product, will expect to start at 0x0000. A high memory bootloader, that does not use interrupts, can be added without recompiling the application. This also means there is no requirement to remap interrupt vectors and therefore there is no double jump required to enter the application interrupt handlers and, as a consequence, they deliver a lower interrupt latency than when a low memory bootlooader is used. |
This is 100% correct Andrew and exactly the point. The idea of moving the bootloader code to the top of memory came to me in the early hours one morning last week.
Anyway, I've coded it now. It works perfectly. Any legacy .hex file for an 18F1320, as long as it fits under the bootloader code space, will load. No pragmas or recompiles requires. There is the obvious RETLW "Gotcha" but I've taken care of that in the form of a warning.
If the problem with pushing the code further up into memory is down to my compiler version perhas I'll rewrite it in XC8. I've never before written a line of XC8 C. Should be interesting!
Thanks again Andrew. You are the man. |
