No SPI clocks PIC16F18424
JerryR
PostPosted: Mon Mar 09, 2026 11:04 am     Reply with quote
Can anyone tell me why this code does not generate clocks on SPI1? No clocks confirmed with logic analyser and o-scope.
PCWH v5.121 uC- 16F18424
Thanks!
#include <16F18424.h>
#use delay(clock=32000000) // 8 MHz internal osc
#fuses RSTOSC_HFINTRC_32MHZ
#use spi(MASTER, BITS=8, MODE=0, BAUD=100000)
#pin_select SCK1 = PIN_C0
#pin_select SDI1 = PIN_C1
void main ()
int8 value1,value2;
while (1)
    value1= spi_xfer (0);
    value2= spi_xfer (0);
gaugeguy
PostPosted: Mon Mar 09, 2026 12:00 pm     Reply with quote
General comments:
Put the pin_select before # use spi and add SPI1 into #use spi to force it to use the hardware.
JerryR
PostPosted: Mon Mar 09, 2026 12:30 pm     Reply with quote
Thanks so much for your consideration. Generating clocks now.
PostPosted: Tue Mar 10, 2026 10:50 am     Reply with quote
I'm surprised you did not get a warning/error with the pin_select after the
#use.
PostPosted: Tue Mar 10, 2026 1:20 pm     Reply with quote
and here, this dinosaur , was focused on the delay vs fuses.......
PostPosted: Wed Mar 11, 2026 3:10 am     Reply with quote
It is because he is not specifying the SPI port to use. If you change the
#use_spi to:
#use spi(SPI1, MASTER, BITS=8, MODE=0, BAUD=100000)
It then complains that 'PIN NOT ASSIGNED'.
If you think about it as done, the #use is not saying what pin to use
or what port to use, The syntax checking is missing this....
bkamen
PostPosted: Wed Mar 18, 2026 10:44 am     Reply with quote
Don't forget to change the subject of your original post to include [ SOLVED ] in the subject line.
