PIC24 I2C routines in assembly
allenhuffman
PostPosted: Wed Mar 04, 2026 7:57 pm     Reply with quote
While digging through some files tonight, I ran across this one. I am unsure where this came from, though it might have been something I made when looking at the .lst file to understand how things like i2c_read() and i2c_write() worked in the CCS PCD compiler.
I am sharing this here to see if anyone recognizes it.
If I compiled it, I did not know then that the registers/bits can vary from PIC24 to PIC24, and with no notes on which PIC24 this was for, I could probably figure it out by looking at data sheets.
CCS PIC assmebly code for the i2c functions (currently just for Slave).
....................     #use i2c (SLAVE, I2C3, FORCE_HW, stream=SYSTEM_BUS)
* i2c_init - i2c_init(SYSTEM_BUS, 1);
00B90:  BCLR.B  2E4.7   // LATE LATE7 to 0 (RE7, SDA data)
00B92:  BSET.B  277.7   // I2CEN 1=Enable
00B94:  BSET.B  277.5   // I2CSIDL 1=Stop when in idle mode
00B96:  BSET.B  276.6   // STREN 1=Enable receive clock stretching
00B98:  BCLR.B  277.3   // IMPIEN 0=Disabled
00B9A:  BSET.B  276.7   // GECN 1=Enable interrupt on general call address
00B9C:  BCLR.B  277.0   // SMEN 0=Disable SMBUS
00B9E:  BSET.B  277.1   // DISSLW 1=Disable slew rate control (yes, 1=disable)
00BA0:  BCLR.B  277.2   // A10M 0=7-bit slave address
00BA2:  CLR     27A      // I2C3ADD - address to 0.
* i2c_slaveaddr - i2c_slaveaddr (SYSTEM_BUS, 100);
00BA4:  MOV     #32,W4   // ????
00BA6:  MOV     W4,27A   // I2C3ADD - address
* i2c_isr_state
* 85C     - @I2C_STATE (global, contains a counter)
* 974-975 - state (user return value, as an int16 in this sample)
00824:  BTSC.B  278.5   // D/A - skip next if 0 (address)
                  //     if 0, go to ADDRESS
                  //     if 1, go to WRITE
00826:  BRA     830      // go to WRITE
* ADDRESS:
00828:  CLR.B   85C      // clear @I2C_STATE
                  //     @I2C_STATE = 0;
0082A:  BTSS.B  278.2   // R/W - skip next if 1 (read)
                  //     if 0, go to WRITE
                  //     if 1, go to READ
0082C:  BRA     830      // go to WRITE
* READ:
0082E:  BSET.B  85C.7   // set high bit in @I2C_STATE
                  //       @I2C_STATE |= 0b1xxxxxxxx;
* WRITE:
00830:  MOV.B   85C,W0L   // load @I2C_STATE value into 16-bit register (?)
                  //      reg16 = [xx | @I2C_STATE];
00832:  CLR.B   1      // clear first byte of 16-bit register (?)
                  //      reg16 = [00 | @I2C_STATE]
00834:  INC.B   085C   // increment @I2C_STATE
                  //      @I2C_STATE++;
...return value (pre-increment) to user...
00836:  MOV.B   W0L,974   // store new incremented value back to state
00838:  CLR.B   975      // clear other half of state
...back to user's code...
* i2c_poll - data = i2c_poll()
* 860 - data (return value)
00BD0:  CLR.B   860      // data = 0;
00BD2:  BTSC.B  278.1   // RBF - skip next if 0
                  //     if 0, go to SKIP (don't increment)
                  //     if 1, continue (increment)
00BD4:  INC.B   0860   // data++;
* SKIP:
...return...
* i2c_read - data = i2c_read (SYSTEM_BUS, 0);
....................     data = i2c_read(SYSTEM_BUS, 0);
00BBC:  CLR.B   W1      // W1 is second parameter?
00BBE:  CALL    6C4      // read routine
00BC2:  MOV.B   W0L,860 // store byte in 'data'
* i2c_read - data = i2c_read (SYSTEM_BUS, 1);
....................     data = i2c_read(SYSTEM_BUS, 1);
00BC4:  MOV.B   #1,W1L   // W1 is second parameter?
00BC6:  CALL    6C4      // read routine
00BCA:  MOV.B   W0L,860   // store byte in 'data'
**** 6C4: Read subroutine?
006C4:  MOV     #FFFF,W0
* START:
006C6:  BTSS.B  278.3   // S - skip next if 0 (no start bit)
                  //     if 0, go to START.
                  //     if 1, go to GCSTAT.
006C8:  BRA     6C6      // go to START
* GCSTAT:
006CA:  BTSC.B  279.1   // GCSTAT - skip next if 1 (broadcast)
                  //     if 0, go to READ.
                  //     if 1, go to CHECK10BIT.
006CC:  BRA     6D6      // go to READ
* CHECK10BIT:
006CE:  BTSS.B  277.2   // A10M - skip next if 1 (10-bit address)
                  //     if 1, go to CHECK10MATCH.
006D0:  BRA     6D6      // go to READ
* CHECK10MATCH:
006D2:  BTSS.B  279.0   // ADD10 - skip next if 1 (10-bit matched)
                  //     if 1, go to READ.
006D4:  BRA     6C6      // go to START:
* READ:
006D6:  BTSS.B  278.1   // RBF - skip next if 1 (receive buffer full)
                  //     if 1, go to READBYTE.
006D8:  BRA     6D6      // go to READ
* READBYTE:
006DA:  MOV     270,W0   // I2C3RCV - read byte
006DC:  BTSC.B  278.6   // I2COV - skip next if 0 (no overflow)
                  //     if 0, go to CLOCKRELEASE.
                  //     if 1, go to CLEAROV.
* CLEAROV:
006DE:  BCLR.B  278.6   // I2COV - clear overflow bit
* CLOCKRELEASE:
006E0:  BSET.B  277.4   // SCLREL - set to 1 (release SCLx clock)
006E2:  RETURN
* i2c_read - data = i2c_read (SYSTEM_BUS, 2);
....................     data = i2c_read(SYSTEM_BUS, 2);
00BCC:  MOV.B   270,W0L   // I2C3RCV - read byte (address)
00BCE:  MOV.B   W0L,860   // store byte in 'data'
* i2c_read - data = i2c_read (SYSTEM_BUS);
007A2:  MOV     #FFFF,W0
* START
007A4:  BTSS.B  278.3   // S - skip next if 0 (no start bit)
007A6:  BRA     7A4      // go to START
* GCSTAT:
007A8:  BTSC.B  279.1   // GCSTAT - skip next if 1 (broadcast)
007AA:  BRA     7B4      // go to READ
* CHECK10BIT:
007AC:  BTSS.B  277.2   // A10M - skip next if 1 (10-bit address)
007AE:  BRA     7B4      // go to READ
* CHECK10MATCH:
007B0:  BTSS.B  279.0   // ADD10 - skip next if 1 (10-bit matched)
007B2:  BRA     7A4      // go to START
* READ:
007B4:  BTSS.B  278.1    // RBF - skip next if 1 (receive buffer full)
                  //     if 0, go to READBYTE.
007B6:  BRA     7B4      // go to READ.
* READBYTE:
007B8:  MOV     270,W0   // I2C3RCV - read byte
007BA:  BTSC.B  278.6   // I2COV - skip next if 0 (no overflow)
* CLEAROV:
007BC:  BCLR.B  278.6   // I2COV - receive overflow flag bit
* CLOCKRELEASE:
007BE:  BSET.B  277.4   // SCLREL - set to 1 (release SCLx clock)
007C0:  RETURN
* i2c_write - i2c_write(SYSTEM_BUS, x);
007C2:  MOV     #FFFF,W0
* START:
007C4:  BTSS.B  278.3   // S - start bit (skip next instruction if set)
                  //     if 0, go to RETURN.
007C6:  BRA     7D8      // go to RETURN
* GCSTAT:
007C8:  BTSS.B  278.2   // RW (1=slave write, 0=slave read)
007CA:  BRA     7D8      // go to RETURN
* CHECK10BIT:
007CC:  BTSS.B  277.2   // A10M - (1=10-bit addr, 0=7-bit address)
                  //     if 0, go to SEND.
007CE:  BRA     7D4      // go to START
* CHECK10MATCH:
007D0:  BTSS.B  279.0   // ADD10 - 10-bit slave addressing bit (1=matched, 0=not)
                  //     if 1, go to SEND.
007D2:  BRA     7D8      // go to RETURN
* SEND:
007D4:  MOV     W1,272   // I2C3TRN - send byte
007D6:  BSET.B  277.4   // SCLREL - set to 1 (release SCLx clock)
* RETURN:
007D8:  RETURN
08E     IFS5
08E.4   I2C_SYSTEM_BUS_IRQ_PENDING_BIT
278.0   TBF
278     I2C3STAT
278.0   TBF
278.1   RBF
278.2   RW
278.3   S
278.4   P
278.5   DA
I do recall that, some years ago, we were having many I2C issues. Ultimately, a rework of our I2C interrupt resolved them and allowed us to send 14+ million messages between a PC and PIC24 with zero errors. (Our protocol is a 5-byte header + data bytes + 2-byte checksum, getting a response that is at least a 7-byte header+checksum back.)
I also found some work-in-progress C routines that attempted to recreate the CCS functions:
unsigned int i2cSlaveRead (unsigned int ack)
    uint16_t data;
    data = 0;
    while (1)
        // Wait for start.
        while (S == 0);
        // GCSTAT:
        // Check for broadcast.
        if (GCSTAT == 1)
            // CHECK10BIT:
            // Check for 10-bit addressing.
            if (A10M == 1)
                // CHECK10MATCH:
                // Check for 10-bit address match.
                if (ADD10 == 0)
                    // 10-bit address was not ours. Go back to start.
                    continue;
        // If here, it was either a broadcast, a matching 10-bit address,
        // or our 7-bit address.
    // READ:
    // Wait for receive buffer full.
    while (RBF == 0);
    // READBYTE:
    // Read byte.
    data = I2C3RCV;
    // Check receive overflow flag.
    if (I2COV == 1)
        // CLEAROV:
        // Clear receive overflow flag.
        I2COV = 0;
    // CLOCKRELEASE:
    // Release SCLx clock.
    SCLREL = 1;
    return data;
 void i2cSlaveWrite (unsigned int data)
    // START:
    // If no start bit, return.
    if (S == 0) return;
    // GCSTAT:
    if (GCSTAT == 0) return;
    // CHECK10BIT:
    if (A10M == 1)
        // CHECK10MATCH:
        if (ADD10 == 0) return;
    // SEND:
    // Send byte.
    I2C3TRN = data;
    // CLOCKRELEASE:
    SCLREL = 1;
I do not know if any of this works.
Having just recently had an A.I. help me convert our legal I2C ISR into something that used the registers (via #word and #bit from the CCS compiler), and I plan to go through it and see what may have been missed. (Though the new code also appears to work perfectly, with new checks to recover from things like a missing stop bit or other glitches in the line.)
Sharing this in case it might be of interest...
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
