Woody
Joined: 11 Sep 2003 Posts: 92 Location: Warmenhuizen - NL
| Quick question about ADC in a PIC18F04Q41 |
Posted: Fri Dec 05, 2025 9:13 am |
I am either experiencing a senior moment or I never understood how channel switching for the AD converter works.
Before I elaborate on what the problem is, can I ask: do you need to issue a | Code: | | set_adc_channel(sAN2); | before every read of an ADC value? Also if I am only interested in on input channel? |
Woody
Posted: Fri Dec 05, 2025 9:44 am |
Yep, senior moment.
Reading my own question back I noticed the 'sAN2' and thought, that cannot be right....
And indeed, changing this to | Code: | | set_adc_channel(2); | solved my problem.
My excuses for the stupid question. |
Posted: Fri Dec 05, 2025 1:43 pm |
| don't feel bad.... at 72 ALL my moments are 'senior' ! |
Posted: Sat Dec 06, 2025 12:34 pm |
It is also a very common one.
The sANx designations are used for the setup, to specify which channels
are to be connected to the multiplexer. The set_adc_channel command
then just selects the numbered channel from the multiplexer you want
to read.
I suspect many of us have made that mistake at least once.....  |
Woody
Posted: Mon Dec 08, 2025 5:05 am |
| Ttelmah wrote: | It is also a very common one.
to read.
Yep.
I used the 'sAN2' designation in the original code, somewhere in the init section. As that did not work I started debugging, using the '2' designation right before the ADC start somewhere else in the code.
That (obviously) made it work but I did not see why until I posted the question. Failing to see the forest for the trees.
What made it a senior moment is that this was not exactly the first time I needed ADC in my code and that usually the ordering of my thoughts when composing a question is enough to see make me see the real problem  |
