How much voltage PIN_C0 needs for measuring oscilation?
pekka1234
PostPosted: Tue Oct 14, 2025 7:23 am     Reply with quote
I have got an instuctance meter working, but it has only 1Vpp amplitude. I have a PIC16F886 microcontroller used as a measuring instrument with pin C0 as an input. I häve tried to adjust the level from 0 to 5V, but it doesn't work. How much does it need an amplitude? Or do I have ot make a comparison? Or another measuring device?
Pekka
gaugeguy
PostPosted: Tue Oct 14, 2025 8:13 am     Reply with quote
According to the data sheet with a 5V supply the low must be below 1.0V and the high must be above 4.0V on pin C0.
PostPosted: Tue Oct 14, 2025 9:29 am     Reply with quote
First thing, if the is an analogue signal it'll probably be +/- of the 0v line
not swinging just positive which a logic input will require. As gaugeguy says
the pin needs a much bigger swing too.
Now you could capacitively couple the signal and bias the voltage it swings
round to perhaps the centre of the 5v supply. Still too small though. Could you
not use one of the internal comparators instead pf C0?. This allows the
detection of much smaller voltage swings, but limits the frequency supported.
Realistically you need to add a high speed comparator, and use this to feed C0.
