PIC24 PCD compiler and MPLAB X compiler I2C?
allenhuffman
PostPosted: Thu Oct 02, 2025 4:01 pm     Reply with quote
I have been trying to make common source files that work with our CCS PCD projects and a new one that is using the MPLAB X compiler.
I have been unable to find examples of this "Foundation Services Library" I2C code, and neither A.I. I have tried to use has produced code that fully works.
Original:
bool AD5272WriteCommandData (unsigned int address, uint8_t command, uint16_t data)
    bool status = false;
    uint16_t value = (((uint16_t)command & AD5272_CMD_MASK) << 10) | (data & AD5272_DATA_MASK);
    //AD5272_PRINTF ("AD5272WriteCommandData (0x%x, 0x%x, 0x%x)\r\n", address, command, data);
#if defined(__PCD__) // CCS PCD compiler.
    unsigned int ackStatus = 0;
    // Send start condition
    i2c_start (AD5272_I2C_STREAM);
    // Send address with write bit (0)
    ackStatus = i2c_write (AD5272_I2C_STREAM, address << 1);
    if (ackStatus == 0)
        // ACK'd, so something is there, continue writing.
        i2c_write (AD5272_I2C_STREAM, value >> 8);
        i2c_write (AD5272_I2C_STREAM, value & 0xff);
        status = true;
    // Send stop condition
    i2c_stop (AD5272_I2C_STREAM);
#else // assume MPLAB X compiler.
     ...snip...
#endif
    return status;
Does anyone here work with both systems?
The code that was presented to me in MPLABs uses "void i2c2_waitForEvent(uint16_t*);" over there, and looks like it may require some steps to have interrupts working.
I am using a PIC24FJ1024GA606 for this project, but I am happy with a polled I2C approach like we do in CCS. This MPLAB code looks like it wants interrupts, since that wait function is looking at slave and master IRQ bits.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
allenhuffman
PostPosted: Fri Oct 03, 2025 11:36 am     Reply with quote
Wow, the "Foundation Services" functions in MPLAB are basically just C wrappers to I2C register calls. I've chatted with Bing Copilot, Google Gemini, and even Claude and none of them can produce working I2C code.
I have learned you need to manually clear IRQs (polled mode) and such, so I can at least see traffic and get responses from the chip, but it leaves the bus in a weird state according to the Saleae Logic captures I have done.
"The grass is always greener on the other side."
This is a good example of how easy the CCS routines are compared to what this MPLAB stuff seems to require -- and the MPLAB stuff is still not working the same way:
uint16_t AD5272ReadCommandData (unsigned int address, uint8_t command, uint16_t data)
    uint16_t retValue = 0;
    uint16_t value = ((command & AD5272_CMD_MASK) << 10) | (data & AD5272_DATA_MASK);
    //AD5272_PRINTF ("AD5272ReadCommandData (0x%x, 0x%x, 0x%x)\r\n", address, command, data);
    if (ackStatus == 0)
        uint8_t msb = 0;
        uint8_t lsb = 0;
        i2c_write (AD5272_I2C_STREAM, value >> 8); // MSB
        i2c_write (AD5272_I2C_STREAM, value & 0xff); // LSB
        // Send repeated start condition.
        // Send address with write bit (1)
        i2c_write (AD5272_I2C_STREAM, (address << 1) | 1);
        msb = i2c_read (AD5272_I2C_STREAM, 1); // ACK
        lsb = i2c_read (AD5272_I2C_STREAM, 0); // No ACK
        retValue = (msb << 8) | lsb;
    // i2c2_driver_driver_open() is done during system startup.
    uint16_t event;
    i2c2_driver_clearBusCollision ();
    i2c2_driver_resetBus (); // Currently an empty function.
    i2c2_clearIRQ ();        // Clear the interrupt flag
    i2c2_driver_start ();
    i2c2_waitForEvent (&event); // Wait for the event flag
    i2c2_driver_TXData (address << 1);  // Address + Write
    if (!i2c2_driver_isNACK())
        ackStatus = true;
        i2c2_driver_TXData (value >> 8); // MSB
        i2c2_driver_TXData (value & 0xFF); // LSB
        i2c2_driver_restart ();
        i2c2_driver_TXData ((address << 1) | 1);
    // Only proceed to read if the initial write was ACK'd AND the Read address was ACK'd
    if (ackStatus && !i2c2_driver_isNACK())
        uint8_t msb = 0;
        uint8_t lsb = 0;
        // Prepare to receive
        // BSET.B  I2C2CON.RCEN         ; Enable receive mode
        i2c2_driver_startRX (); // RCEN=1
        while (I2C2CONLbits.RCEN); // Wait for receive to complete
        // BCLR.B  I2C2CON.ACKDT        ; ...send ACK
        // BSET.B  I2C2CON.ACKEN        ; Send ACK/NACK
        i2c2_driver_sendACK (); // ACKDT=0, ACKEN=1
        // TODO: Wait for ACKDT/RCEN bits to clear?
        while(I2C2CONLbits.ACKEN);
        // BTSS.B  I2C2STAT.RBF         ; Wait for RBF (Receive Buffer Full)
        while (!i2c2_driver_isBuferFull ());
        // MOV     I2C2RCV,W0           ; Read received byte into W0
        msb = i2c2_driver_getRXData ();
        // Clear overflow if needed.
        if (I2C2STATbits.I2COV)
            I2C2STATbits.I2COV = 0; // Clear overflow
        i2c2_driver_sendNACK ();
        while(I2C2CONLbits.ACKEN); // ACKDT=1, ACKEN=0
        lsb = i2c2_driver_getRXData ();
    i2c2_driver_stop ();  // STOP condition
    // Ensure the bus is fully released by polling the PEN/TRSTAT bits.
    while(I2C2CONLbits.PEN);
    while(I2C2STATbits.TRSTAT);
#endif
    return retValue;
PostPosted: Sat Oct 04, 2025 11:38 am     Reply with quote
One thing might give an issue on the MPLAB stuff you show. Remember that
on a read from a device, there will be an ACK, not a NACK on the last byte
what you show does not seem to handle this. Might be why it still has
problems.
allenhuffman
PostPosted: Sat Oct 04, 2025 8:17 pm     Reply with quote
problems.
I gave up on that "Foundation Services" stuff. They are just wrappers to poll or set I2C bits. And, they are missing many of the ones you still need, so you do a command, then have to manually poll a bit to make sure it has completed. Stuff like that was way too much work -- might as well write my own!
They have a second I2C thing built in that gives basically two functions. It was a brain twister to figure out, and STILL has an issue with a phantom start/stop bit before a transmission. But, it can handles writing a basic message, or reading a basic message, or queueing up transactions so it will do a repeated start between them. It is ... interesting.
The grass is MUCH greener on the CCS side of the fence when it comes to I2C. I am hoping to figure this out and write up a blog post showing how to do all of this, since no one else seems to have done it.
allenhuffman
PostPosted: Mon Oct 06, 2025 8:01 am     Reply with quote
In case anyone else goes down this path, there are two methods of I2C provided in the "MCC" tool of MPLAB. The first one is basically C wrappers to register access, and it is missing many things you need so you still have to manually poll register bits (or so it seems).
The other is more complex, and lets you write a buffer or bytes, or read a buffer of bytes. If you want to write/repeated start/read, it uses some type of buffer system where you chain them together, then it does it automatically. Sadly, I cannot really find any documentation, and there is a phantom start/stop bit seen on my analyzer which is being done inside their routines for some reason. My CCS original code does not do that.
I wanted to share a simple example, in case it helps anyone else understand how much easier the CCS tool is. This is my work-in-progress test code:
    if (ackStatus == 0)
        status = true;
    /*volatile*/ I2C2_MESSAGE_STATUS status_mcc; // Must be volatile
    uint8_t writePayload[2];
    // 1. Pack the command and data (which is in 'value') into the buffer
    writePayload[0] = (uint8_t)(value >> 8);  // Command/Data MSB
    writePayload[1] = (uint8_t)(value & 0xFF); // Command/Data LSB
    // 2. Execute the entire transaction in one blocking call.
    // This single call performs: START, Address+W, Data TX (2 bytes), STOP.
    I2C2_MasterWrite(
        writePayload,           // Pointer to data to send
        sizeof(writePayload),   // Length of data (2 bytes)
        address,                // Slave address (7-bit, the function shifts it)
        &status_mcc             // Pointer to the status variable
    // 3. Wait for the transaction to complete
    while(status_mcc == I2C2_MESSAGE_PENDING); // Requires interrupts!
    // 4. Check the final status
    if (status_mcc == I2C2_MESSAGE_COMPLETE)
        while (I2C2CONLbits.PEN);   // Wait for STOP to finish
        // This implicitly means the Address and Data were ACK'd
        status = true;
    else // status is I2C2_MESSAGE_ADDRESS_NO_ACK or I2C2_MESSAGE_FAIL, etc.
        I2C2CONLbits.PEN = 1;           // Force STOP
        while (I2C2CONLbits.PEN);       // Wait for STOP to complete
#endif
    return status;
    if (ackStatus == 0)
        uint8_t msb = 0;
        uint8_t lsb = 0;
    /*volatile*/ I2C2_MESSAGE_STATUS status_mcc = I2C2_MESSAGE_PENDING;
    I2C2_TRANSACTION_REQUEST_BLOCK combinedTRB[2]; // Two TRBs needed for W/R
    // Data buffer for the two bytes we WRITE (Command + Data MSB/LSB)
    // Data buffer for the two bytes we READ (MSB and LSB)
    uint8_t readPayload[2] = {0, 0};
    // 1. Pack the command and data (from 'value') into the write buffer
#if 1 // Faster way (repeated start)
    // --- Write Phase TRB (TRB [0]) ---
    // This TRB performs: START, Address+W, Data TX (2 bytes)
    I2C2_MasterWriteTRBBuild(
        &combinedTRB[0],      // TRB structure
        address               // Slave address
    // --- Read Phase TRB (TRB [1]) ---
    // This TRB performs: Repeated START, Address+R, Data RX (2 bytes), NACK, STOP
    I2C2_MasterReadTRBBuild(
        &combinedTRB[1],      // TRB structure
        readPayload,          // Pointer to data buffer to receive bytes
        sizeof(readPayload),  // Length of data (2 bytes)
    // 2. Insert the two TRBs into the queue as one sequential transaction
    I2C2_MasterTRBInsert(
        2,                    // count: 2 TRBs in the list
        combinedTRB,          // pointer to the TRB array
        &status_mcc           // pointer to the status variable
    // 3. Wait for the entire transaction to complete
    // 4. Check the final status and compile the result
        // Data has been successfully read into readPayload[0] (MSB) and readPayload[1] (LSB)
        retValue = (readPayload[0] << 8) | readPayload[1];
#else // Slower way (two separate start/stop transactions)
    // Write phase
    I2C2_MasterWrite(writePayload, 2, address, &status_mcc);
    while (status_mcc == I2C2_MESSAGE_PENDING);
    if (status_mcc != I2C2_MESSAGE_COMPLETE) return 0;
    // Read phase
    I2C2_MasterRead(readPayload, 2, address, &status_mcc);
#endif // fast or slow
#endif
    return retValue;
The MPLAB routine was generated by one of the AIs, and works, but inside the MPLAB functions something is creating a phantom start/stop bit that my analyzer sees. I do not know how robust these routines are.
It also requires interrupts and has a handler that sets some flag which you will see polled in this code.
Anyone else tried this?
gaugeguy
PostPosted: Mon Oct 06, 2025 9:20 am     Reply with quote
Software routines generated be AI are 'A' but definitely not 'I'
PostPosted: Mon Oct 06, 2025 2:00 pm     Reply with quote
I treat AI the same as I do 'simulators' and 'wizards'.....
Not worth wasting MY time on them...
allenhuffman
PostPosted: Mon Oct 06, 2025 2:11 pm     Reply with quote
When they work, they are magic.
But the other 90%...
What stuns me is how I can find no documentation, no forum posts, etc. about how this stuff works -- other than posts from others also asking how they work ;-)
allenhuffman
PostPosted: Mon Jun 15, 2026 4:12 pm     Reply with quote
I have been assigned back to complete this project... Searching for information led me back to a post I made . . . looking for information. Of course it did.
asmallri
Re: PIC24 PCD compiler and MPLAB X compiler I2C?
PostPosted: Tue Jun 16, 2026 6:49 am     Reply with quote
Well, strickly speaking, MPLAB X is an IDE not a compiler. I do all my CCS development work in MPLAB X using the CCS compiler.
Regards, Andrew
PostPosted: Wed Jun 17, 2026 12:39 am     Reply with quote
Problem is of course, that to simulate the Microchip C compiler's library,
you would have to work out how it works. Generally CCS users could not
be bothered to do this, since most of the time it is far easier to just
ignore the library approach, and just use the CCS functions.
asmallri
PostPosted: Wed Jun 17, 2026 1:33 am     Reply with quote
I completely agree.
Regards, Andrew
