Recursion in the Wiznet I/O library
allenhuffman
PostPosted: Fri Sep 19, 2025 3:33 pm     Reply with quote
I am in the process of porting the current Wiznet library over:
https://github.com/Wiznet/ioLibrary_Driver/tree/master
We had a port done a few years ago, and I've been replicating the steps we made to do that. But, new functions have been added, new chip(s) supported, etc. so there are some differences.
Now when I build, I am getting recursion warnings:
*** Error 69 "...\main.c" Line 170(2,7): Recursion not permitted [wizphy_setphypmode]
As I comment things out until it builds, I find that it errors at the first function call:
tmp = getPHYCFGR();
I'll do some digging, but wanted to post this in case someone else has alredy dug into this and knows what changed.
Adding #recursive does not work, as then I get a whole other list of "overloaded" function errors and from what I can see, I find just one prototype and one function and they are identical (there is a second prototype and multiple functions but those should not be compiled for my chip #define).
Cheers...
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Sun Sep 21, 2025 12:09 am     Reply with quote
I think that is just a call to reg_rd. So possibly look at this, Problem is that
the issue could be something in how you are loading the library, and/or
how you have adapted it. Look carefully at all names used in it for something
like a CCS reserved keyword, or something that is just being loaded in the
wrong order.
As has been pointed out here before (many times), the problem is that
the CCS error checking has a nasty habit at erroring at something that
is not actually the fault many lines after what is actually wrong. It's parser
gets confused and carries on reading and getting more confused, until it
eventually displays an error. So I'm afraid you have a lot of diagnosis to do,
Sad
jeremiah
PostPosted: Sun Sep 21, 2025 10:22 am     Reply with quote
Also keep in mind that by default, the CCS compiler is not case sensitive, so you'll want to use
#case
in case the library uses similar names with different casing.
allenhuffman
PostPosted: Sun Sep 21, 2025 4:10 pm     Reply with quote
I've been burned by that so much now #case is the first thing I add ;-) It baffles me that this is not a default. There is a union in Wiznet called "IF" and that won't work without #case.
I checked the functions and they seem identical to the version we ported a few years ago, but other routines have changed. The burst read/write has default "if 1" code that calls the byte routines in a for/next loop, for example. Seeing core things like that change really makes me wish we had checked in the raw files before modifying them so I could see what was done originally.
I'll be back at this on Monday and hopefully figure something out. I already diff'd the wiznet_conf.c/.h to update our changes in the new one, but there is a lot of stuff added in the new one (including support for chips that did not exist a few years ago, it seems). Maybe with a fresh eye this week I will spot something and be able to fix it.
Thanks, much.
PostPosted: Sun Sep 21, 2025 10:34 pm     Reply with quote
If nothing has changed in the part erroring, it suggests it is something
in part of the earlier code triggering the error.
Thoughts:
Stream names?
Variables?.
It suggests something in your code setting up to use this, might contain
something that now clashes with the re-written newer code.
I see you remembered that old function using pointers oddity. I remember
the thread about that when you originally met this. That is an oddity
that really should have been fixed by CCS in the meantime. Worth pointing
this out to them, when you have a moment. Very Happy
jeremiah
PostPosted: Mon Sep 22, 2025 9:15 am     Reply with quote
If I had to guess, it's probably safety related. MISRA C doesn't allow for multiple variable / function names to differ by case alone in the same context, so it is in essence case insensitive. A lot of safer languages also specify case insensitivity.
allenhuffman
PostPosted: Tue Sep 23, 2025 7:16 am     Reply with quote
Seeing changes to the core wiznet_conf files makes everything suspect. We've never ported these, only the ones from years earlier.
Back then, I did drop in the httpServer.c files and did a test with them, and have no recollection of having to do anything to those files to make it work.
But there are hundreds of changed lines in the core files, so likely there is more porting to do. As soon as I add #recursive of whichever the keyword is, I get a different set of errors.
I am back in the office today and will be doing more testing.
allenhuffman
PostPosted: Tue Sep 23, 2025 4:56 pm     Reply with quote
I have successfully gotten the "register" functions to work so I can pass in our own functions and it will use them.
But man, is it picky. Something got bumped and I spent an hour fighting a compiler error. Ended up re-making the CCS project and then it worked again. Weird.
I'll make a topic to share tidbits when I get this done. Working on the httpServer code now.
allenhuffman
PostPosted: Thu Jun 25, 2026 2:04 pm     Reply with quote
Just leaving an update here... We ended up switching to the MPLAB tools for this project. Some of the protocols Wiznet provides were taking way too much effort to make compile with CCS, and MPLAB "just worked" to get things building.
But, so many issues with http server, SNMP, etc. that, if I had it to do all over again, I wouldn't ;-)
