rs232 prints rubish
Goto page Previous  1, 2, 3
gaugeguy
PostPosted: Tue Sep 16, 2025 1:17 pm     Reply with quote
That processor uses PPS (peripheral pin select). Please see the sticky on how to use #pin_select
scanan
PostPosted: Wed Sep 17, 2025 12:50 am     Reply with quote
By using
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
problem solved
many thanks
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Thu Sep 18, 2025 10:13 am     Reply with quote
A a comment, this line is wrong:
setup_spi(SPI_SS_DISABLED);
This turns off SPI slave select. It does not disable the SPI
allenhuffman
PostPosted: Wed Sep 24, 2025 10:45 am     Reply with quote
I ran into corrupt RS232 output via the ICD debugger on one board which was related to one of the timers. Disabling the timer made the output work.
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
jeremiah
PostPosted: Thu Sep 25, 2025 7:56 am     Reply with quote
That's probably because the ICD serial is a software uart, so you need to add the option "DISABLE_INTS" to your #use rs232
Page 3 of 3
