Joined: 01 Jul 2010 Posts: 9653 Location: Greensville,Ontario
Posted: Tue Jul 08, 2025 5:41 am |
the 245 is a 3 volt device. While it can ACCEPT a 5 volt input, it CANNOT output 5 volts.
I have no idea why the 245 are on the PCB.
please post what module you have, and I'll try to find a real schematic of it. |
Posted: Tue Jul 08, 2025 7:17 am |
Yes. These are part of the LCD circuitry. _not_ level shifting for the SD,
If you look a the picture you posted of the module right at the start of the
thread, and enlarge this, you can see that the data connection to the SD
run directly across the board to the pin connector at the right of the board
they go nowhere near the 245 buffers.
As designed, the unit will work with something like a Arduino, since this
accepts +2.4v as high for SPI. However even on this it could well damage
the SD card, since the inputs to the SD will be overdriven. However it
cannot work on a 5v PIC using hardware SPI.
| ilker07 wrote: | | Ttelmah wrote: | The board has a 3.3v regulator to run the SD, but does not have level
shifting to the SD card. I looked at the image and you can see the tracks
go directly to the connector without level shifting.
The PIC is one of the few processors that insist on proper SPI signal
levels. This board will not work without added shifters. |
There are 2 74LVC245A IC on the shield.Arent they level-shifter 3.3 to 5 v?? |
ilker07
Posted: Wed Jul 16, 2025 4:45 am |
I used txs0108e level shifter but it doesn't still work.
signed int8 i;
FILE myfile;
delay_ms(2000);
i = fat_init();
fprintf(SCREEN,"init:%d\n",i);
if(fatopen((char *)"/TEST.TXT", (char *)"r", &myfile) != 0) fprintf(SCREEN,"file err\n");
else {
signed int ch_int;
unsigned char ch;
fprintf(SCREEN,"file ok\n");
fatseek(&myfile, 0, SEEK_SET); // Dosya başına git
for(i = 0; i <2; i++) {
ch_int=fatgetc(&myfile);
if (ch_int != EOF) { ch=(char)ch_int; fprintf(SCREEN,"%c",ch); }
fatclose(&myfile);
fprintf(SCREEN,"\n");
it gives me i=-1 and it says file ok but it doesn't print any character.. |
ilker07
Posted: Wed Jul 16, 2025 4:59 am |
| by the way; even if I write "TST.TXT" it still gives me file ok??? |
ilker07
Posted: Thu Jul 17, 2025 1:30 am |
| I replaced SanDisk (16 gb) with Kingston(8gb)sd card.and kingston sd card gives me 0 but it pirnts only B character(There are AB characters in the file) when I try to read the file it.Then I unplug the sd card and I changed the file (ABCDE) it gives me BI characters.Then I formatted sd card as fat32 and prints nothing. |
Posted: Thu Jul 17, 2025 5:01 am |
had a quick look on sparkfun... saw this...
The board pulls OE LOW through a 110kΩ resistor to disable the I/O pins by default. Make sure to tie the OE pin to VCCA to enable the device.
might be your problem ??? |
ilker07
Posted: Thu Jul 17, 2025 5:11 am |
| temtronic wrote: | had a quick look on sparkfun... saw this...
oe pin ==> VCCA anyway |
ilker07
Posted: Thu Jul 17, 2025 12:06 pm |
sd card for pic???? |
Posted: Thu Jul 17, 2025 4:50 pm |
| you do have side A going to SD card and side B going to the PIC ?? |
ilker07
Posted: Sat Jul 19, 2025 7:58 am |
| temtronic wrote: | | you do have side A going to SD card and side B going to the PIC ?? |
yes |
Posted: Sun Jul 20, 2025 1:17 am |
As the diagram shows the level shifting is only for the LCD.
You should be able to get it working with your level shifter. Post how
this is connected. |
ilker07
Posted: Mon Jul 21, 2025 6:46 am |
| Ttelmah wrote: | As the diagram shows the level shifting is only for the LCD.
https://simple-circuit.com/pic18f4550-sd-card-read-write-files/ The circuit I have exactly like this but I have PIC18F67K22 |
ilker07
Posted: Mon Jul 21, 2025 8:24 am |
| I replaced pinc4 with pin_f1 by the way... |
ilker07
Posted: Tue Jul 22, 2025 1:42 am |
| Problem solved it was about c4 pin.it works with f1 pin ,now haw can I read bmp files?? |
