Joined: 01 Jul 2010 Posts: 9654 Location: Greensville,Ontario
Posted: Fri Jul 11, 2025 6:12 pm |
so.. you're saying the raw datastream from the RF section output is not encoded.
That means it'll be dead simple to decode ! |
bulut_01
Posted: Fri Jul 11, 2025 6:49 pm |
| There is no real-time changing key. If the raw data changes, the RF output data changes. If the raw data is constant, the RF output data is constant. I published the Excel on the top page. What do you think about encryption? |
Posted: Sat Jul 12, 2025 4:48 am |
| Well there has to be some sort of 'rolling' key process going on otherwise, every 'stop' keypress would result in the same 64 bits of data. You've posted 20+ 'STOP' data and they're all different. |
bulut_01
Posted: Sat Jul 12, 2025 5:14 am |
| temtronic wrote: | | Well there has to be some sort of 'rolling' key process going on otherwise, every 'stop' keypress would result in the same 64 bits of data. You've posted 20+ 'STOP' data and they're all different. |
What does the encryption method here remind you of? Is it possible that it is keeloq? Is it really difficult to decipher this encryption? |
Posted: Sat Jul 12, 2025 6:34 am |
1) it reminds me that 'rolling key' encryptions are a real pain ! They were specifically designed to be VERY DIFFICULT to 'hack'.
2) it might be, but no way to tell, unless you acquire 65,000 same key pressed data, then look for the 'start over point'
3) yes, as we've stated before you don't KNOW the encryption algorithm AND you don't KNOW the key.
Just because a PIC was used for the remote, there's no reason that KEELOQ was used. Think of it this was. Guys buy cars....they rip out the OEM radio, put in some aftermarket unit.....
Is it possible to 'reverse engineer' the remote to get the encryption. Yes. |
bulut_01
Posted: Sat Jul 12, 2025 6:44 am |
| temtronic wrote: | 1) it reminds me that 'rolling key' encryptions are a real pain ! They were specifically designed to be VERY DIFFICULT to 'hack'.
how to reverse engineer ?
What path should be followed in light of this information? |
Posted: Sat Jul 12, 2025 7:21 am |
1st step, press same key 65,000+ times and record the data streams.
2nd step, cut code to look for 2 identical data streams.
I'd program a PIC to 'press a key', once every 1 second, capture the data,add CRLF, then send to a PC . Have the PC run a terminal program to capture and save the data. Then cut a program to search the data file for 2 identical 'data stream'. To mimick the 'keypress', you could use a relay across the pushbutton contacts. To search for two identical data, you load 1st entry as the 'sample', then go through the remaining 65,000(end of file) to see if they are the same. If not, load #2 as the 'sample', then test from #3 to end of file. NO ? then load #3, test #4 to end of file.
If it really has a 'rolling key', it will 'repeat' BUT first you need to acquire all the data ! |
bulut_01
Posted: Sat Jul 12, 2025 8:47 am |
| temtronic wrote: |
Once we understand that this is a rolling key, how should we proceed? |
Posted: Sat Jul 12, 2025 9:40 am |
well one problem. in that spreadsheet the 'output data' you say is 64 bits actually has 16 hex characters for most of the 'key presses', so that'd be 256 bits of data......
another problem is the 'data' isn't always 16 characters......even for the same 'keypress'. |
bulut_01
Posted: Sat Jul 12, 2025 10:31 am |
| temtronic wrote: | well one problem. in that spreadsheet the 'output data' you say is 64 bits actually has 16 hex characters for most of the 'key presses', so that'd be 256 bits of data......
Is this related to the counter starting from 1 to 528 ? I'm confused about how I should go about decrypting the password. |
Posted: Sat Jul 12, 2025 12:45 pm |
1st you've got to get 'good' data ! I assume EVERY transmission is the same number of characters. For sure EVERY time you press '3', you NEED to get the SAME number of characters !!!
Until that happens you cannot decode/decrypt/ make sense of the data . |
bulut_01
Posted: Sat Jul 12, 2025 1:18 pm |
| temtronic wrote: | 1st you've got to get 'good' data ! I assume EVERY transmission is the same number of characters. For sure EVERY time you press '3', you NEED to get the SAME number of characters !!!
I will share the RF output as well. |
bulut_01
Posted: Sat Jul 12, 2025 3:37 pm |
I share raw data with the logic analyzer and Manchester decodes
Excel bottom 3 data remote control identification data
Posted: Sat Jul 12, 2025 3:52 pm |
1st, link comes in as 'malware'.......
2nd, grabbed the screenshot and zoomed it up
3rd, don't know why the pink background is there
looks like totally random bytes, no 'pattern' so can't 'decode'.... |
bulut_01
Posted: Sat Jul 12, 2025 4:15 pm |
| temtronic wrote: | 1st, link comes in as 'malware'.......
I will upload the file to a new site. The red ones are duplicate data in the same column. You can remove it if you want.
