PWM with PIC16LF15325
starfire151
PostPosted: Thu Apr 03, 2025 9:42 am     Reply with quote
I've been trying to get the PWM output to work with a PIC16LF15325 but have been unsuccessful.
From the header support file:
#pin_select PWM3=PIN_C0
#use pwm(output=PIN_C0, frequency=15625, bits=10)
From the main program:
setup_pwm3(CCP_PWM);
pwm_set_frequency(10000); // set frequency
pwm_set_duty_percent(200); // 20% duty cycle
pwm_on();
I have tried using PIN_A4 and PIN_C0 as outputs but have not been able to see the PWM output with a scope.
Is there something I'm not setting up correctly?
Thanks.
PostPosted: Thu Apr 03, 2025 3:51 pm     Reply with quote
It seems simple, so post your program so others can copy/paste/compile/test !
'bits and pieces' don't show us the whole story....
also, does the PIC run a '1Hz LED program ' ??
starfire151
PostPosted: Thu Apr 03, 2025 4:15 pm     Reply with quote
.h file:
#include <16LF15325.h>
#device adc=10       // 10-bit ADC => 1024 steps
#device *=16
#define clk_freq 16M
#use delay(internal=clk_freq)
.c file:
#include <pwm_16LF15325_test.h>
   setup_timer_2(T2_DIV_BY_1, 127, 1);
I also tried to use the wizard to generate a baseline program with the pwm but it was not successful, either.
Thanks for looking at it...
PostPosted: Fri Apr 04, 2025 3:28 am     Reply with quote
You are 'overpecifying things'. Normally the compiler will accept this, but
I suspect this is resulting in things not working:
#device *=16
#use pwm(PWM3, frequency=15625)
//You have already specified where PWM3 is to go.
//Also specifying 'bits', implies that the frequency may be adjusted if
//needed to give this. Just specify the frequency and the compiler will
//tell you how many bits it can achieve.
   //setup_pwm3(CCP_PWM);
   //You have already setup pwm3. Don't do it again. This setup is almost
   //certainly what is stopping the  PWM. This is a dedicated PWM, _not_
   //A CCP.  CCP_PWM, is not an acceptable setting for the PWM module
   //If you look at the header file, this is not listed as a parameter for
   //this PWM.... You are using a command for the CCP peripheral
   //on the PWM. Result disaster.......
   //It'll actually turn off the enable bit for the PWM.....
   //You must _never_ use command words for the wrong peripheral.
   //This is exactly like putting diesel in a petrol car......
starfire151
PostPosted: Fri Apr 04, 2025 7:28 am     Reply with quote
Thanks for responding.
I implemented the changes you suggested but there is still no output.
I added the pwm_on(); after setting the duty percent but still no output. The scope shows flatline.
Is there something unusual about setting up the PWM on the 16LF15325? I have used this same method on the 16LF1825 with success, even though the output was not mapped.
When the program compiled, it did specify that the output was 10-bits, as you said.
BTW, I have been able to successfully get a version of the program with this processor to output a 1 second toggle to an LED using a timer interrupt.
starfire151
PostPosted: Sat Apr 05, 2025 6:02 am     Reply with quote
Does anyone have the PIC16LF15325 working with a PWM output?
Any output pin, any frequency, any duty cycle?
I'm having start-up issues with this simple program:
#device adc=10
#device *=16
   pwm_on();
PostPosted: Sat Apr 05, 2025 6:07 am     Reply with quote
Hmm, maybe you damaged the PIC ?
Can you flash an LED on the I/O pin ?
Id there's another internal peripheral, can you confirm it works ?
starfire151
PostPosted: Sat Apr 05, 2025 8:28 am     Reply with quote
Thanks for responding...
Here's my modified code:
#device *=16
#use pwm(PWM3, frequency=15625)  // compiler states PWM resolution = 10 bits
   pwm_on();
      output_high(PIN_C2);
      output_low(PIN_C2);
This is with a new 16LF15325 device. It toggles the LED correctly.
It's looking like there's something fundamental wrong. I have nothing else connected to the PIC.
PostPosted: Sat Apr 05, 2025 12:34 pm     Reply with quote
sounds like it's time to post the listing ( program.lst) file.
maybe someone can see what's wrong with the actual code ?
starfire151
PostPosted: Sat Apr 05, 2025 1:25 pm     Reply with quote
OK. Here's the listing file.... sorry it's so long...
    CCS PCM C Compiler, Version 5.071, 33568 05-Apr-25 08:24
    Filename: D:\projects\PicC\projects\4D0185_pwm_hi-v\pwm_16LF15325_test.lst
    ROM used: 443 words (5%)
    Largest free fragment is 2048
    RAM used: 6 (1%) at main() level
    37 (4%) worst case
    Stack used: 1 locations
    Stack size: 16
    0000: MOVLP 00
    0001: GOTO 15A
    0002: NOP
    .................... #include <16LF15325.h>
    .................... //////////// Standard Header file for the PIC16LF15325 device ////////////////
    .................... //// (C) Copyright 1996, 2014 Custom Computer Services ////
    .................... //// This source code may only be used by licensed users of the CCS C ////
    .................... //// compiler. This source code may only be distributed to other ////
    .................... //// licensed users of the CCS C compiler. No other use, reproduction ////
    .................... //// or distribution is permitted without written permission. ////
    .................... //// Derivative programs created using this software in object code ////
    .................... //// form are not restricted in any way. ////
    .................... #device PIC16LF15325
    0003: BTFSC 03.1
    0004: GOTO 009
    0005: MOVLW 20
    0006: MOVWF 05
    0007: MOVLW 14
    0008: MOVWF 04
    0009: CLRF 77
    000A: CLRF 78
    000B: CLRF 79
    000C: CLRF 7A
    000D: CLRF 34
    000E: CLRF 35
    000F: CLRF 36
    0010: CLRF 37
    0011: MOVF 30,W
    0012: IORWF 2F,W
    0013: IORWF 2E,W
    0014: IORWF 2D,W
    0015: BTFSC 03.2
    0016: GOTO 047
    0017: MOVLW 20
    0018: MOVWF 38
    0019: BCF 03.0
    001A: RLF 29,F
    001B: RLF 2A,F
    001C: RLF 2B,F
    001D: RLF 2C,F
    001E: RLF 34,F
    001F: RLF 35,F
    0020: RLF 36,F
    0021: RLF 37,F
    0022: MOVF 30,W
    0023: SUBWF 37,W
    0024: BTFSS 03.2
    0025: GOTO 030
    0026: MOVF 2F,W
    0027: SUBWF 36,W
    0028: BTFSS 03.2
    0029: GOTO 030
    002A: MOVF 2E,W
    002B: SUBWF 35,W
    002C: BTFSS 03.2
    002D: GOTO 030
    002E: MOVF 2D,W
    002F: SUBWF 34,W
    0030: BTFSS 03.0
    0031: GOTO 041
    0032: MOVF 2D,W
    0033: SUBWF 34,F
    0034: MOVF 2E,W
    0035: BTFSS 03.0
    0036: INCFSZ 2E,W
    0037: SUBWF 35,F
    0038: MOVF 2F,W
    0039: BTFSS 03.0
    003A: INCFSZ 2F,W
    003B: SUBWF 36,F
    003C: MOVF 30,W
    003D: BTFSS 03.0
    003E: INCFSZ 30,W
    003F: SUBWF 37,F
    0040: BSF 03.0
    0041: RLF 77,F
    0042: RLF 78,F
    0043: RLF 79,F
    0044: RLF 7A,F
    0045: DECFSZ 38,F
    0046: GOTO 019
    0047: MOVF 34,W
    0048: MOVWF 00
    0049: MOVF 35,W
    004A: MOVWI W,[FSR0+01]
    004B: MOVF 36,W
    004C: MOVWI W,[FSR0+02]
    004D: MOVF 37,W
    004E: MOVWI W,[FSR0+03]
    004F: RETURN
    0103: MOVLW 20
    0104: MOVWF 38
    0105: CLRF 34
    0106: CLRF 35
    0107: CLRF 36
    0108: CLRF 37
    0109: MOVF 2B,W
    010A: MOVWF 7A
    010B: MOVF 2A,W
    010C: MOVWF 79
    010D: MOVF 29,W
    010E: MOVWF 78
    010F: MOVF 28,W
    0110: MOVWF 77
    0111: BCF 03.0
    0112: BTFSS 77.0
    0113: GOTO 122
    0114: MOVF 2C,W
    0115: ADDWF 34,F
    0116: MOVF 2D,W
    0117: BTFSC 03.0
    0118: INCFSZ 2D,W
    0119: ADDWF 35,F
    011A: MOVF 2E,W
    011B: BTFSC 03.0
    011C: INCFSZ 2E,W
    011D: ADDWF 36,F
    011E: MOVF 2F,W
    011F: BTFSC 03.0
    0120: INCFSZ 2F,W
    0121: ADDWF 37,F
    0122: RRF 37,F
    0123: RRF 36,F
    0124: RRF 35,F
    0125: RRF 34,F
    0126: RRF 7A,F
    0127: RRF 79,F
    0128: RRF 78,F
    0129: RRF 77,F
    012A: DECFSZ 38,F
    012B: GOTO 111
    .................... #list
    .................... #device adc=10 // 10-bit ADC => 1024 steps
    .................... #device *=16
    .................... #define clk_freq 16M
    .................... #use delay(internal=clk_freq)
    0144: MOVLW 20
    0145: MOVWF 05
    0146: MOVLW 02
    0147: MOVWF 04
    0148: MOVF 00,W
    0149: BTFSC 03.2
    014A: GOTO 159
    014B: MOVLW 05
    014C: MOVWF 78
    014D: CLRF 77
    014E: DECFSZ 77,F
    014F: GOTO 14E
    0150: DECFSZ 78,F
    0151: GOTO 14D
    0152: MOVLW 2E
    0153: MOVWF 77
    0154: DECFSZ 77,F
    0155: GOTO 154
    0156: GOTO 157
    0157: DECFSZ 00,F
    0158: GOTO 14B
    0159: RETURN
    .................... #pin_select PWM3=PIN_C0
    .................... #use pwm(PWM3, frequency=15625) // compiler states PWM resolution = 10 bits
    0050: BCF 03.1
    0051: MOVF 28,W
    0052: MOVWF 2C
    0053: MOVF 27,W
    0054: MOVWF 2B
    0055: MOVF 26,W
    0056: MOVWF 2A
    0057: MOVF 25,W
    0058: MOVWF 29
    0059: MOVF 24,W
    005A: MOVWF 30
    005B: MOVF 23,W
    005C: MOVWF 2F
    005D: MOVF 22,W
    005E: MOVWF 2E
    005F: MOVF 21,W
    0060: MOVWF 2D
    0061: CALL 003
    0062: MOVF 7A,W
    0063: BTFSS 03.2
    0064: GOTO 06B
    0065: MOVF 79,W
    0066: BTFSS 03.2
    0067: GOTO 06B
    0068: MOVF 78,W
    0069: BTFSC 03.2
    006A: GOTO 0BE
    006B: RRF 7A,F
    006C: RRF 79,F
    006D: RRF 78,F
    006E: RRF 77,F
    006F: MOVLW 7F
    0070: ANDWF 7A,F
    0071: MOVF 7A,W
    0072: BTFSS 03.2
    0073: GOTO 07A
    0074: MOVF 79,W
    0075: BTFSS 03.2
    0076: GOTO 07A
    0077: MOVF 78,W
    0078: BTFSC 03.2
    0079: GOTO 0C3
    007A: RRF 79,F
    007B: RRF 78,F
    007C: RRF 77,F
    007D: MOVLW 7F
    007E: ANDWF 79,F
    007F: MOVF 79,W
    0080: BTFSS 03.2
    0081: GOTO 085
    0082: MOVF 78,W
    0083: BTFSC 03.2
    0084: GOTO 0C8
    0085: RRF 79,F
    0086: RRF 78,F
    0087: RRF 77,F
    0088: MOVLW 7F
    0089: ANDWF 79,F
    008A: MOVF 79,W
    008B: BTFSS 03.2
    008C: GOTO 090
    008D: MOVF 78,W
    008E: BTFSC 03.2
    008F: GOTO 0CD
    0090: RRF 79,F
    0091: RRF 78,F
    0092: RRF 77,F
    0093: MOVLW 7F
    0094: ANDWF 79,F
    0095: MOVF 79,W
    0096: BTFSS 03.2
    0097: GOTO 09B
    0098: MOVF 78,W
    0099: BTFSC 03.2
    009A: GOTO 0D2
    009B: RRF 79,F
    009C: RRF 78,F
    009D: RRF 77,F
    009E: MOVLW 7F
    009F: ANDWF 79,F
    00A0: MOVF 79,W
    00A1: BTFSS 03.2
    00A2: GOTO 0A6
    00A3: MOVF 78,W
    00A4: BTFSC 03.2
    00A5: GOTO 0D7
    00A6: RRF 79,F
    00A7: RRF 78,F
    00A8: RRF 77,F
    00A9: MOVLW 7F
    00AA: ANDWF 79,F
    00AB: MOVF 79,W
    00AC: BTFSS 03.2
    00AD: GOTO 0B1
    00AE: MOVF 78,W
    00AF: BTFSC 03.2
    00B0: GOTO 0DC
    00B1: RRF 79,F
    00B2: RRF 78,F
    00B3: RRF 77,F
    00B4: MOVLW 7F
    00B5: ANDWF 79,F
    00B6: MOVF 79,W
    00B7: BTFSS 03.2
    00B8: GOTO 0BC
    00B9: MOVF 78,W
    00BA: BTFSC 03.2
    00BB: GOTO 0E1
    00BC: CLRF 77
    00BD: GOTO 0E1
    00BE: MOVLW 80
    00BF: MOVLB 05
    00C0: MOVWF 0E
    00C1: GOTO 0E4
    00C2: MOVLB 00
    00C3: MOVLW 90
    00C4: MOVLB 05
    00C5: MOVWF 0E
    00C6: GOTO 0E4
    00C7: MOVLB 00
    00C8: MOVLW A0
    00C9: MOVLB 05
    00CA: MOVWF 0E
    00CB: GOTO 0E4
    00CC: MOVLB 00
    00CD: MOVLW B0
    00CE: MOVLB 05
    00CF: MOVWF 0E
    00D0: GOTO 0E4
    00D1: MOVLB 00
    00D2: MOVLW C0
    00D3: MOVLB 05
    00D4: MOVWF 0E
    00D5: GOTO 0E4
    00D6: MOVLB 00
    00D7: MOVLW D0
    00D8: MOVLB 05
    00D9: MOVWF 0E
    00DA: GOTO 0E4
    00DB: MOVLB 00
    00DC: MOVLW E0
    00DD: MOVLB 05
    00DE: MOVWF 0E
    00DF: GOTO 0E4
    00E0: MOVLB 00
    00E1: MOVLW F0
    00E2: MOVLB 05
    00E3: MOVWF 0E
    00E4: DECF 77,F
    00E5: MOVF 77,W
    00E6: MOVWF 0D
    00E7: MOVLP 00
    00E8: MOVLB 00
    00E9: GOTO 1A0 (RETURN)
    00EA: MOVLB 05
    00EB: MOVF 0D,W
    00EC: MOVLB 00
    00ED: MOVWF 24
    00EE: CLRF 25
    00EF: INCF 24,F
    00F0: BTFSC 03.2
    00F1: INCF 25,F
    00F2: BCF 03.0
    00F3: RLF 24,F
    00F4: RLF 25,F
    00F5: RLF 24,F
    00F6: RLF 25,F
    00F7: CLRF 2B
    00F8: CLRF 2A
    00F9: MOVF 25,W
    00FA: MOVWF 29
    00FB: MOVF 24,W
    00FC: MOVWF 28
    00FD: CLRF 2F
    00FE: CLRF 2E
    00FF: MOVF 22,W
    0100: MOVWF 2D
    0101: MOVF 21,W
    0102: MOVWF 2C
    012C: BCF 03.1
    012D: MOVF 7A,W
    012E: MOVWF 2C
    012F: MOVF 79,W
    0130: MOVWF 2B
    0131: MOVF 78,W
    0132: MOVWF 2A
    0133: MOVF 77,W
    0134: MOVWF 29
    0135: CLRF 30
    0136: CLRF 2F
    0137: MOVLW 03
    0138: MOVWF 2E
    0139: MOVLW E8
    013A: MOVWF 2D
    013B: CALL 003
    013C: MOVF 78,W
    013D: MOVLB 06
    013E: MOVWF 0D
    013F: MOVF 77,W
    0140: MOVWF 0C
    0141: MOVLP 00
    0142: MOVLB 00
    0143: GOTO 1A4 (RETURN)
    .................... void main()
    015A: MOVLW 55
    015B: MOVLB 3D
    015C: MOVWF 0F
    015D: MOVLW AA
    015E: MOVWF 0F
    015F: BCF 0F.0
    0160: MOVLW 0B
    0161: MOVLB 3E
    0162: MOVWF 20
    0163: MOVLW 55
    0164: MOVLB 3D
    0165: MOVWF 0F
    0166: MOVLW AA
    0167: MOVWF 0F
    0168: BSF 0F.0
    0169: MOVLB 11
    016A: CLRF 12
    016B: CLRF 0F
    016C: CLRF 11
    016D: MOVLW 05
    016E: MOVWF 13
    016F: MOVLW 60
    0170: MOVWF 0D
    0171: MOVLW FF
    0172: MOVLB 05
    0173: MOVWF 0D
    0174: MOVLW 01
    0175: MOVWF 10
    0176: MOVLW 80
    0177: MOVWF 0E
    0178: MOVLW 02
    0179: MOVLB 06
    017A: MOVWF 0D
    017B: CLRF 0C
    017C: MOVLW 8F
    017D: MOVWF 0E
    017E: MOVLB 3E
    017F: CLRF 38
    0180: CLRF 4E
    0181: MOVLB 13
    0182: CLRF 11
    0183: CLRF 12
    0184: CLRF 13
    0185: CLRF 10
    0186: CLRF 15
    0187: CLRF 16
    0188: CLRF 17
    0189: CLRF 14
    .................... setup_timer_2(T2_DIV_BY_1, 127, 1);
    018A: MOVLB 05
    018B: CLRF 11
    018C: CLRF 0F
    018D: CLRF 10
    018E: MOVLW 7F
    018F: MOVWF 0D
    0190: MOVLW 80
    0191: MOVWF 0E
    .................... pwm_set_frequency(10000); // set frequency
    0192: MOVLB 00
    0193: CLRF 24
    0194: CLRF 23
    0195: MOVLW 27
    0196: MOVWF 22
    0197: MOVLW 10
    0198: MOVWF 21
    0199: CLRF 28
    019A: MOVLW 3D
    019B: MOVWF 27
    019C: MOVLW 09
    019D: MOVWF 26
    019E: CLRF 25
    019F: GOTO 050
    .................... pwm_set_duty_percent(200); // 20% duty cycle
    01A0: CLRF 22
    01A1: MOVLW C8
    01A2: MOVWF 21
    01A3: GOTO 0EA
    .................... pwm_on();
    01A4: MOVLB 06
    01A5: BSF 0E.7
    .................... while(TRUE)
    .................... output_high(PIN_C2);
    01A6: MOVLB 00
    01A7: BCF 14.2
    01A8: BSF 1A.2
    .................... delay_ms(1000);
    01A9: MOVLW 04
    01AA: MOVWF 21
    01AB: MOVLW FA
    01AC: MOVWF 22
    01AD: CALL 144
    01AE: DECFSZ 21,F
    01AF: GOTO 1AB
    .................... output_low(PIN_C2);
    01B0: BCF 14.2
    01B1: BCF 1A.2
    01B2: MOVLW 04
    01B3: MOVWF 21
    01B4: MOVLW FA
    01B5: MOVWF 22
    01B6: CALL 144
    01B7: DECFSZ 21,F
    01B8: GOTO 1B4
    01B9: GOTO 1A7
    01BA: SLEEP
    Configuration Fuses:
    Word 1: 3F8C NOEXTOSC RSTOSC_HFINTRC NOCLKOUT CKS FCMEN
    Word 2: 3FFD MCLR PUT NOLPBOR BROWNOUT BORV24 ZCDDIS PPS1WAY STVREN NODEBUG
    Word 3: 3F9F WDTSW NOWDT WDTWIN_SW WDTCLK_SW
    Word 4: 1FFF BBSIZ512 BOOTBLOCK NOSAF WRT NOWRTB NOWRTC NOWRTSAF NOLVP
    Word 5: 3FFF NOPROTECT
