PCH functions setjmp and longjmp
Kieran
PostPosted: Mon Mar 22, 2004 12:04 pm     Reply with quote
I have used these functions successfully with a PIC16F876 but when using them with a PIC18F452 the programme crashes and resets via the watchdog when I execute the longjmp. Crying or Very sad
#include <setjmp.h>
jmp_buf myenv;
// in main
  do
     restart_WDT();
     setjmp(myenv);  // Back to here
// in a function
   do
      key = fetch_key();  // wait for key press
      if (key == 'C')  // abort key ?
         err = 0;
         longjmp(myenv,1);  // should jump to main but crashes
   while (key != 'E');
Compiler version 3.184
Anyone got these to work on a PIC18Fxxx ?
Haplo
PostPosted: Tue Mar 23, 2004 12:33 am     Reply with quote
Are you kicking the watchdog in the fetch_key() function? If not, that may cause the program to reset.
It's hard to say what the problem is. Post your full code (incluing the setjmp.h file) so we can take a look at it.
Kieran
PostPosted: Tue Mar 23, 2004 9:29 am     Reply with quote
The fetch_key() function includes a delay_ms function with watchdog.
The code for the full project is long, I am trying a stripped down version (which works!). So I will try to reintroduce the bug then post it.
Kieran
PostPosted: Wed Mar 24, 2004 5:08 am     Reply with quote
After further testing I have given up with the longjmp approach. It worked sometimes, no time to debug further.
