		| Author | Message |
		| bulut_01
				|  Posted: Mon Feb 26, 2024 12:00 pm |   |
				| The discussion on this subject is going well. There is another issue I want to ask. I want to use 18f25k40 FVR hardware. My settings are as follows.
  	  | Code: |  	  | setup_vref(VREF_ON | VREF_ADC_4v096); SETUP_DAC(DAC_VSS_VDD | DAC_OUTPUT);
 Although I should see around 4 volts from the DAC output, I cannot get any output. Is there something else I missed other than these settings?
		| bulut_01
				|  Posted: Mon Feb 26, 2024 11:26 pm |   |
				| Does anyone have any ideas about FVR hardware not working? |  |
		| Ttelmah
				|  Posted: Tue Feb 27, 2024 2:35 am |   |
				| Several things. First you don't show any line setting the output level for the DAC.
 You need a DAC_write. The DAC1CON1 register (which sets the output)
 defaults to 0 on boot.
 Then why 4v?. You do realise you are routing the Vref to the ADC, not
 the DAC?. You have the DAC operating from the supply. If your supply
 is 3.3v (which your earlier posts say), you cannot select 4.096 as a
 Vref output. The maximum is always just a little under the supply. So
 even if you set the DAC to 31, the maximum you could see would be
 3.19v.
 From the data sheet:
  	  | Quote: |  	  | 1. Fixed Voltage Reference output cannot exceed VDD.
		| temtronic
				|  Posted: Tue Feb 27, 2024 5:53 am |   |
				| I wonder if Proteus will give him 4 volts...using a 3 volt supply ?..   Until we see the results form the OP running the I2C Scanner program, I have to assume this code is all in a Proteus simulation.
		| bulut_01
				|  Posted: Tue Feb 27, 2024 7:06 am |   |
				|  	  | Ttelmah wrote: |  	  | Several things. First you don't show any line setting the output level for the DAC.
 3.19v.
 Can you help me with this? My goal is to get constant voltage. Is it more accurate to get it with DAC or ADC output? How exactly are the ccs configuration settings for this?
		| temtronic
				|  Posted: Tue Feb 27, 2024 7:32 am |   |
				| OK, we need to know what 'constant voltage' ??
 Post with a value for the 'constant voltage' and the allowable range it can be.
 IE: 5.00 volts, + 0.5, -0.2 .
 So this example means constant voltage can be 4.800 to 5.500 and be withing the specifications.
		| Ttelmah
				|  Posted: Tue Feb 27, 2024 8:09 am |   |
				| As Jay says, accuracy is everything on this.
 ADC output????. No such thing.
 The DAC is just a resistive divider. The Vref is only +/-4% accurate. The
 DAC is even worse (+/-5 LSb). Neither of these is even remotely an
 accurate source. Slightly better than guessing, but not by much!....
 Accuracy on references costs money. You don't magically get supplied
 with an accurate voltage source by a cheap PIC. A typical 0.1% Vref will
 cost several times the cost of the PIC. Go more accurate, and this price
 shoots up.
		| bulut_01
				|  Posted: Tue Feb 27, 2024 8:12 am |   |
				| The reason I ask this question is that the circuit is powered by the battery, I need to measure the voltage of the battery, so I need to adjust gnd_fvr. These CCS configuration settings are driving me crazy. |  |
		| Ttelmah
				|  Posted: Tue Feb 27, 2024 8:33 am |   |
				| It won't give you a terribly good result. You don't adjust anything. What you do is simply enable the FVR (this is actually 1.024v - the higher outputs
 are using an op-amp multiplier). Don't feed it to the peripherals, just set the
 ADC to use the supply as it's reference, then read the FVR _channel_ with
 the ADC. So if you read this as (say) 328, then the supply voltage is about
 (1.024/328)*1024 = 3.19v. However this is +/- 0.1276v, so between 3.05
 and 3.3v. Very poor accuracy indeed.
 This is the best you can do without an external Vref. This is described by
 Microchip in their application note AN1072A (in this case for a chip with a
 0.6v reference). The 0.6v reference here is much more accurate than the
 one in your PIC.
		| bulut_01
				|  Posted: Tue Feb 27, 2024 9:05 am |   |
				|  	  | Ttelmah wrote: |  	  | It won't give you a terribly good result. You don't adjust anything. What you do is simply enable the FVR (this is actually 1.024v - the higher outputs
 one in your PIC.
 Thank you for this information. Finally, can you write the FVR CCS configuration settings here?
		| Ttelmah
				|  Posted: Tue Feb 27, 2024 10:41 am |   |
				| You don't. As I said the point is you just read it with the ADC.
  	  | Code: |  	  | #bit FVREN = getenv("bit:FVREN")
 FVREN=TRUE; //this allows us to turn on the FVR without selecting it
 setup_adc(ADC_CLOCK_DIV_128 ! ADC_LEGACY_MODE | ADC_TAD_MUL_2, VSS_VREF); //gives 4uSec acquisition at your clock rate using supply as REF
 set_adc_channel(FVR_CHANNEL); //select the FVR channel to read
 int16 adcval=read_adc();
 int32 supplymV=1048576/adcval; //gives the supply voltage in integer mV
 I've avoided using FP maths, by working in mV. So with my earlier example
 you would get 3196.
		| bulut_01
				|  Posted: Tue Feb 27, 2024 11:17 am |   |
				|  	  | Ttelmah wrote: |  	  | You don't. As I said the point is you just read it with the ADC.
 you would get 3196.
 thank you my friend thank you
		| bulut_01
				|  Posted: Mon Mar 04, 2024 4:48 pm |   |
				| I would like to thank my friends who helped me here. OLED i2c worked in real circuit in terms of hardware.
		| temtronic
				|  Posted: Mon Mar 04, 2024 6:03 pm |   |
				| wow , I'm impressed ! I can't SEE SMT parts let alone SOLDER them !! happy you got it working .
		| bulut_01
				|  Posted: Mon Mar 04, 2024 6:09 pm |   |
