MCUprogrammer
Posted: Sat Sep 16, 2023 8:30 am |
Also, what does IPS stand for? Instruction Per Second ?
it as a message; So:
#use delay(clock=133.333333MHz, crystal=20MHz)
--- Info 301 "E:\dsPIC33CH_PWM\timer.c" Line 23(1,2): Info: IPS: 66666666
_________________ Best Regards...
MCUprogrammer
_______________________________
Work Hard |
Joined: 01 Jul 2010 Posts: 9136 Location: Greensville,Ontario
Posted: Sat Sep 16, 2023 9:51 am |
that would indicate to me that IPS is clock/2. |
MCUprogrammer
Posted: Sat Sep 16, 2023 10:30 am |
What does IPS mean? What does it stand for. What does 666666 written on the output screen mean? _________________ Best Regards...
MCUprogrammer
Work Hard |
Posted: Sat Sep 16, 2023 10:44 am |
Instructions Per Second.
It is a standard term. If you do the same on a PIC18 it'll be clock/4. |
Posted: Sat Sep 16, 2023 11:04 am |
66666666 is sixty six million, six hundred and sixty six thousand ,six hundred and sixty six Instructions per second.
Dang that's a lot of characters to type !
66,666,666 IPS is a lot easier !!! |
MCUprogrammer
Posted: Sat Sep 16, 2023 11:17 am |
Woow. I got it now. Thank you guys.... _________________ Best Regards...
MCUprogrammer
Work Hard |
