| View previous topic :: View next topic   |
			mattmab
				| int32 |
				 Posted: Sat Mar 13, 2004 11:55 pm     |
				does anyone understand why this wont work? it seems i cant initialze leds to hex 4000.
thanks ahead - matt
#case
#include <16f876.h>
#device	*=16 ICD=TRUE
#use delay( clock=11059000 )
int32	leds = 1;
	leds = 0x4000;
				| Re: int32 |
				 Posted: Sun Mar 14, 2004 3:42 am     |
				 	  | mattmab wrote: | 	 		  does anyone understand why this wont work? it seems i cant initialze leds to hex 4000.
thanks ahead - matt
#case
#include <16f876.h>
int32	leds = 1;
	leds = 0x4000;
Should work. Try declaring the constant as a long - so:
leds= 0x4000L;
Sometimes the compiler is less than 'intelligent' about such things...
			mattmab
				| int32a |
				 Posted: Sun Mar 14, 2004 9:59 pm     |
nope,4000L dont work either, it takes it as a 16 bit.  it works if i use make32(), but that seems like a poor way. does 32 bit math work? i never checked...
thankws - matt |
				 Posted: Sun Mar 14, 2004 10:51 pm     |
				It actually does work.   If I take your code here,
 	  | Code: | 	 		  #case
#include <16f876.h>
int32 leds = 1;
leds = 0x4000;
and compile it with PCM vs. 3.184, I get this result in the .LST file:
 	  | Code: | 	 		  0011 01A3       00277 CLRF   23
0012 01A2       00278 CLRF   22
0013 3040       00279 MOVLW  40
0014 00A1       00280 MOVWF  21
0015 01A0       00281 CLRF   20 |
The symbol table shows that 'leds' is at address 0x20:
The ASM code is setting the memory locations as follows:
0x23 = 0
0x22 = 0
0x21 = 0x40
0x20 = 0
Since CCS stores variables in Intel Lo-Hi format, this means
that 'leds' = 00 00 40 00 which is correct.
I suspect that the problem is in how you are viewing the 'leds' variable.
For example, if you're using printf, you need to specify the format
string as "%lx", and not "%x", in order to display a 16 or 32-bit number. |
