Constant pulse with pic18f1220
andresteff
PostPosted: Wed Jul 19, 2023 8:17 am     Reply with quote
I want to read in a pulse of variable width with a Pic18F1220, and output it to a 50us pulse. Can I do this with capture or compare?
dyeatman
PostPosted: Wed Jul 19, 2023 10:15 am     Reply with quote
Using Search I found one good place to start:
http://www.ccsinfo.com/forum/viewtopic.php?t=60024&highlight=pulse+width
It has a couple of good references also.
Google and Forum Search are some of your best tools
PostPosted: Thu Jul 20, 2023 12:34 am     Reply with quote
I think what you want is to simply have a 50uSec pulse triggered by probably
the rising edge of the 'variable' pulse.
Look in the CCP data sheet at 'special event trigger' mode. What you do
is have one CCP set to this mode that resets a timer. Then have a second
CCP to generate a fixed width pulse from this timer.
When the timer resets, the second CCP generates the pulse.
