Metal detector
Goto page Previous  1, 2
PostPosted: Thu Dec 15, 2022 7:40 am     Reply with quote
hmm, I know 14-17 computer languages but how to translate the link site into english ?
sifirzero1
PostPosted: Thu Dec 15, 2022 7:43 am     Reply with quote
https://vrtp.ru/index.php?act=categories&CODE=article&article=2448
sifirzero1
PostPosted: Thu Dec 15, 2022 7:44 am     Reply with quote
Can we access codes with reverse engineering?
PostPosted: Thu Dec 15, 2022 8:23 am     Reply with quote
you already have the HEX file, which contains the program.
if you 'import' into the compiler using the 'disassemble' button (or whatever it's called), it will show you the machine code.
I don't know of any 'reverse engineering' programs to generate the 'C source', IF it actually was written in 'C'.
To reverse engineer the code, you do have to have the PIC datasheet to see the 'instruction set summary' and then decode what each line of code is doing. You also have to understand how the PIC 'boots up' to run the program, set registers, etc.
PICs are easy only 35+- instructions compared to the good old Z80 that had 100s......
sifirzero1
PostPosted: Thu Dec 15, 2022 1:11 pm     Reply with quote
Does anyone have the skills to write the code for this circuit?
PostPosted: Thu Dec 15, 2022 1:21 pm     Reply with quote
yes, probably 95% of the posters here.
The problem, for me anyway, is that without your actual hardware, I have no way to test my code and then modify it to optimize the performance.
Somewhere on the web, you found a 'how to build a metal detector with a PIC', so I'm wondering why their code doesn't work on your hardware ?
PrinceNai
PostPosted: Thu Dec 15, 2022 1:30 pm     Reply with quote
I'd guess a few dozens at least. On this forum. But no one will do it for you, in my opinion.
Who would bother to write a code for free for a toy that this is? Even if someone does it, how will he test it? Nobody has your coil. Just go with the provided hex. Maybe it even works.
On the other hand, if you'll code it alone, you'll find everyone on this forum will do their best to help you. If you ask a specific question. This doesn't work, why? is not a good question.
PostPosted: Thu Dec 15, 2022 9:45 pm     Reply with quote
Post the firmware code in this file: MetFM.zip
Then we can see the firmware.
sifirzero1
PostPosted: Thu Dec 15, 2022 9:51 pm     Reply with quote
https://vrtp.ru/index.php?s=e06165d573ce35a64c806b47f3977e9e&act=Attach&type=post&id=264908
PostPosted: Thu Dec 15, 2022 10:54 pm     Reply with quote
I meant post it here, in the forum.
PostPosted: Fri Dec 16, 2022 8:19 am     Reply with quote
All that's there is the assembled code ready for downloading into the PIC... I looked,grabbed it, had compiler disassemble it, then lost interest due to the freezing rain here....
sifirzero1
PostPosted: Wed Dec 28, 2022 2:44 pm     Reply with quote
Generating a square wave with the comparator
Page 2 of 2
