kmp84
| JSON decoder |
Posted: Wed Nov 16, 2022 2:46 pm |
I'm trying to run this JSON decoder ( http://ww1.microchip.com/downloads/en/Appnotes/90003239A.pdf ) with CCS compiler, but have no success yet.
#include <16F1459.h>
#device *=16
#device PASS_STRINGS=IN_RAM
#fuses INTRC_IO,NOPLLEN,NOPROTECT,MCLR,PUT,NOWDT // CLKOUT -> Enable clk/4 out on PIN_A4
#use delay(int=16MHz, clock=24MHz)
#use RS232(DEBUGGER,rcv=PIN_B6,xmit=PIN_B6,stream=STREAM_SERIAL_INPUT)
#include "json_decoder.c"
#include "mem_model.c"
#include "lexer.c"
#include "parser.c"
#define TEST_JSON "{\"main\":{\"key\" : 10,\"foo\":\"bar\"}, \"alt\":2}"
char str[64];
jsonNode_t *root = 0;
jsonDecoderStatus_t ret;
void main(){
memcpy(str, TEST_JSON, sizeof(TEST_JSON));
ret = JSON_DECODER_fromString(str);
if(JSON_DECODER_OK != ret)
printf("Invalid JSON string.\r\n");
JSON_DECODER_getRoot(&root);
while(1){
// user code ...
CCS compiler(v.5.092) return so many errors:
>>> Warning 209 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\lexer.c" Line 106(1,1): Assignment to enum is not of the correct type
>>> Warning 209 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\lexer.c" Line 116(1,1): Assignment to enum is not of the correct type
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 77(187,188): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 78(196,197): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 81(245,246): A numeric expression must appear here
*** Error 27 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 87(91,92): Expression must evaluate to a constant
*** Error 12 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 89(108,111): Undefined identifier pop
*** Error 22 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 90(125,126): Bad expression syntax
*** Error 12 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 93(209,212): Undefined identifier pop
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 117(254,255): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 118(24,25): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 121(126,127): A numeric expression must appear here
*** Error 22 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 131(88,89): Bad expression syntax
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 152(201,202): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 153(222,223): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 156(58,59): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 161(221,222): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 162(242,243): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 165(71,72): A numeric expression must appear here
*** Error 22 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 169(141,142): Bad expression syntax
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 176(101,105): A numeric expression must appear here
*** Error 12 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 194(157,158): Undefined identifier pop
*** Error 12 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 195(189,192): Undefined identifier pop
*** Error 12 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 196(240,243): Undefined identifier pop
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 201(147,148): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 202(168,169): A numeric expression must appear here
*** Error 51 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 207(237,244): A numeric expression must appear here
*** Error 43 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 212(29,35): Expecting a declaration
*** Error 48 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 212(36,42): Expecting a (
*** Error 43 "D:\MCU Archives\pic my project\pic my project\16F1459_USB_projects\JsonDecoder\parser.c" Line 213(43,44): Expecting a declaration
Can anyone help?
Best Regards, |
Joined: 01 Jul 2010 Posts: 9624 Location: Greensville,Ontario
Posted: Wed Nov 16, 2022 3:37 pm |
well 1st 2 errors are in the 'lexer.c' chunk of code, the rest are from 'parser.c'
You'd have to post those for anyone here to decide what is wrong.
it's probably your conversion to CCS C that's causing the errors as different compilers defaults are never the same.....
BTW...the PDF article doesn't have any source code that I could see |
kmp84
Posted: Wed Nov 16, 2022 10:51 pm |
| temtronic wrote: |
There is a link to github on the first page. |
Posted: Thu Nov 17, 2022 5:04 am |
First thing to use MicroChip code, you almost certainly need to set
#DEVICE ANSI
Microchip by default has all it's integers as signed. CCS does not.
Then every reference to 'int' will need to change to 'int16'.
Now the line that fails in parser, in the original file is a blank line. Implies
you must have edited the file, so what we are looking at is not what you
are using. |
kmp84
Posted: Thu Nov 17, 2022 2:18 pm |
The "#DEVICE ANSI" directive and int to int16 changed, but has no idea for this:
parserStatus_t PARSER_parseTokens(void)
parserStatus_t retVal = PARSER_OK;
jsonToken_t nextToken;
jsonNode_t *currentNode = NULL;
jsonNode_t *previousNode = NULL;
ASSERT_AVAILABLE_SOFT_STACK;
STACK[stackTop++] = (recursionStack_t){
.type = CALL,
.data =
.root = 1,
while (stackTop > 0)
recursionStack_t pop = STACK[--stackTop];
switch (pop.type)
case CALL:
ASSERT_TOKEN(&nextToken);
if (pop.data.root && nextToken.type != LEFT_BRACE)
retVal = PARSER_BAD_FORMAT; //Root must be an object
continue;
if (nextToken.type == LEFT_BRACE)
ASSERT_NODE_ALLOC(currentNode);
if (previousNode != NULL)
previousNode->type = OBJECT;
previousNode->v = currentNode;
if (RIGHT_BRACE == nextToken.type)
retVal = PARSER_OK;
continue;
.type = CALL_LOOP,
.data =
.root = 0,
retVal = LEAF_TOKEN;
continue;
case CALL_LOOP:
if (STRING != nextToken.type)
retVal = PARSER_BAD_FORMAT; // key must be string
continue;
currentNode->key = nextToken.value.str;
if (COLON != nextToken.type)
retVal = PARSER_BAD_FORMAT; // expecting colon after key
continue;
previousNode = currentNode;
.type = RESUME_LOOP,
.data =
.currentNode = currentNode
.type = CALL,
.data =
.root = 0,
case RESUME_LOOP:
if (retVal == LEAF_TOKEN)
memcpy(¤tNode->value, &nextToken.value, sizeof (currentNode->value));
else if (retVal != PARSER_OK)
continue;
retVal = PARSER_OK;
continue;
else if (COMMA != nextToken.type)
retVal = PARSER_BAD_FORMAT; // expecting comma
continue;
ASSERT_NODE_ALLOC(pop.data.currentNode->h);
previousNode = pop.data.currentNode;
currentNode = pop.data.currentNode->h;
.type = CALL_LOOP
default:
return retVal;
Microchip published appnote and source code that doesn't work? ?  |
Posted: Thu Nov 17, 2022 3:21 pm |
It's highly unlikely the code presented by Microchip doesn't work BUT you have to run it on whatever PIC they used and compiler...
I've been caught on the 'device=ans' a couple of times the past, though you've fixed that...
Also check the other 'data definitions or defaults but you should post what errors you're getting.
It could be in your translation into CCS C you've mistyped something, changes a : into a ; or some similar typing error
It's very difficult to 'remotely diagnose what the actual cause of the problem is. For me it's 99.44% a typing error, wished I'd taken 'touch typing' in high school, 1/2 a century+ ago... |
kmp84
Posted: Thu Nov 17, 2022 3:55 pm |
Hi mr. temtronic,
| Quote: |
For me it's 99.44% a typing error |
It's not my typing error. I've just downloaded 'working' code from GitHub link and edited as mr. Ttelmah point to int vars. to int16.
You can also download .c and .h files and run my first posted example code.
Best Regards, |
Posted: Thu Nov 17, 2022 4:06 pm |
hmm, there's no 'main.c' in the GitHub link, so no reference as to what PIC was used... Or it might have been an AVR ... Also no mention of which C compiler was used to create the code.
As such, the document is not complete and I'm unable to 'copy/paste/compile/test'.
Others who do this for a living ( I'm retired..) may be able to 'fill in the blanks' and create a workable program ( main.c). |
Posted: Fri Nov 18, 2022 2:15 am |
That is because you are including parser.h, after parser.c is being loaded.
The .h files must be included _first_. The compiler does not know what
PARSER_BAD_FORMAT actually 'is'.
Seriously, the code will only be 90% 'compatible'. Everything about
the actual I/O will need to be customised to suit CCS. The ordering of
the files, the declaration of the variables, etc. etc.. |
Posted: Fri Nov 18, 2022 6:39 am |
What's curious to me, is that in the original github files, the first line in the parser.c file IS the #include for the parser.h file (same format for the others BTW...)
Puzzling is WHY even have the parser.h file, as it only contains 5-6 lines of code which you need for parser.c, so why not just put them IN the parser.c file ?
Without seeing the complete 'picture' it's hard to diagnose why the failure. |
kmp84
Posted: Sat Nov 19, 2022 11:42 am |
| Ttelmah wrote: | That is because you are including parser.h, after parser.c is being loaded.
Hi mr.Ttelmah,
The "parser.h" file it's included in "parser.c". Example for this app.note says that use " ATmega4808" which is 8bit AVR and I think they use MPLAB XC8 compiler. |
Posted: Sun Nov 20, 2022 10:34 am |
You are missing the fundamental point.
You can't just take code from one compiler and expect it to compile and
run on another. Though the core 'C' functions are 99% portable, everything
handling I/O, is compiler specific, and has to be adapted by _you_ to
work with a different compiler.
You need to go through the code and work out which lines handle I/O,
and re-code these using the CCS functions. The same applies when moving
from a Raspberry Pi to Microchip, or AVR to PIC.
Code is only 90% portable, not 100%. |
kmp84
Posted: Sun Nov 20, 2022 1:36 pm |
Okay mr.Ttelmah,
But in this case there is no specific periphery just ‘standard’ c code and one test string. |
Posted: Sun Nov 20, 2022 2:04 pm |
hmm... 'standard' C....
No such thing, several variations of 'C" exist, each compiler has it's own 'set of C'..and DEFAULTS
I believe CCS C is closely based on K&R version of C, though newer versions have added more 'features/functions'...
That's why Mr. T keeps saying you have to read the CCS manual, look for differences in the GitHib posted C code, which actually isn't posted as to WHAT compiler it is..... |
kmp84
Posted: Sun Nov 20, 2022 2:35 pm |
I have checked all vars. and types and needs to edit just two int to int16 all others are ok and using ccs’s <stdint.h>. |
