Problem calling subroutine
rbarbali
PostPosted: Thu Aug 11, 2022 9:10 am     Reply with quote
HI all.
I have a question, I have 2 structs, and I can't call a subroutine with one of them. Is it a C limitation or a CCS limitation, or I am the limitation?
I get compiler error (A numeric expression must appear here) with:
WriteEeprom(0x04, enabled_WD);
but not with:
WriteEeprom(0x03, enabled_RF.z1);
This is the program:
//ccs 5.091
//real hardware
#include <18f45k40.h>
typedef struct
  int8 z1: 1;//lsb
  int8 z2: 1;
  int8 z3: 1;
  int8 tamper: 1;
  int8 reserved: 4;
} zonesWD;
zonesWD enabled_WD;//remote_enable: set by g100
typedef struct
  int8 z1;//bit0-bit7= z11-z12-z13-z14-z15-z16-z17-z18
  int8 z2;//bit0-bit7= z21-z22-z23-z24-z25-z26-z27-z28
  int8 z3;//bit0-bit7= z31-z32-z33-z34-z35-z36-z37-z38
} rf_zone;
rf_zone enabled_RF;
void WriteEeprom(int8 addr, int8 value)
  disable_interrupts(GLOBAL);
  write_eeprom(addr, value);
  int8 aux8;
  enabled_WD = 0x88;
  enabled_RF.z1 = 0x99;
  //I can do this:
  //But I can't do this:
  //Workaround:
  aux8 = enabled_WD;
  WriteEeprom(4, aux8);
Thanks in advance
PostPosted: Thu Aug 11, 2022 10:23 am     Reply with quote
The write_eeprom function expects to receive a single 8bit value.
Your first example gives it this.
On your second example, the name of a structure (without a element name),
is a C shortcut for the address of the structure. Not an 8bit value.
(This is actually one of these things that is rather undefined, so
'dangerous'). Some C's support this not all do.
Write it by using a pointer an de-referencing this:
WriteEeprom(0x04, *((int *)&enabled_WD));
Which forces the address to be taken, cast to be to an int, then takes
the contents of this and passes it to the write function.
rbarbali
PostPosted: Fri Aug 12, 2022 6:42 am     Reply with quote
It works OK. Very interesting!
Thank you.
gaugeguy
PostPosted: Fri Aug 12, 2022 7:50 am     Reply with quote
Another way using standard C elements would be to add a union so that one element is the bit structure and the other is the full word/byte.
PostPosted: Fri Aug 12, 2022 9:52 am     Reply with quote
Yes, that is the sneaky/best way of doing this:.
union {
    int8 byteval;
} WD;
    //Then use
    WD.zoneWD.z1 //etc to access the bits
    WD.byteval //to access the byte equivalent value.
