tmach
| Help with code |
Posted: Fri Feb 13, 2004 1:03 pm |
Hello!
I am trying to use the interrupt on RB0 to control pin D1 on my PIC16F874A. I have used an example posted in this forum but I do not get expected output out of pin D1.
Initially I set high on pin D1. On a H to L change on RB0, after 2 sec if RB0 still remains low, I turn pin D1 to low. I turn on the PIC with RB0 connected to high and then connect RB0 to low. I expect to see PIN RD1 go low after 2 seconds. I do not see any change on RD1. It always remains high. Please advice.
mach
#include <16f874A.h>
#device ADC=10;
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7, ENABLE=PIN_C0)
#bit INTF_BIT = 0x0B.1
//Global declares
int settle = 2000;
#int_ext
void INTRB0(void);
main()
DELAY_US(10);
ext_int_edge(H_TO_L);
INTF_BIT = 0;
ENABLE_INTERRUPTS(INT_EXT);
ENABLE_INTERRUPTS(GLOBAL);
OUTPUT_HIGH(PIN_D1);
#INT_EXT
intRB0()
disable_interrupts(INT_EXT);
disable_interrupts(GLOBAL);
delay_ms(settle);
INTF_BIT = 0;
if(!INPUT(PIN_B0)) OUTPUT_LOW(PIN_D1);
| Re: Help with code |
Posted: Fri Feb 13, 2004 3:29 pm |
| tmach wrote: | Hello!
mach
#device ADC=10;
//Global declares
int settle = 2000;
#int_ext
void INTRB0(void);
main()
DELAY_US(10);
INTF_BIT = 0;
#INT_EXT
intRB0()
delay_ms(settle);
INTF_BIT = 0;
You need to put a 'stopper' at the end of your main code.
Add:
[code]
while(true) ;
[/code/
as the last line of your code.
Your main routine, will run 'off the end', since it does not loop. The compiler inserts a 'sleep' instruction after the end of the code. You will be hitting this.
tmach
Posted: Sun Feb 15, 2004 12:05 am |
Yes,
I use a while loop at the end in the main program. But I am using this while loop to implement a softare SPI. For example I use statements such as while(~clk) to wait for clock edge. The code would look something like this:
#INT_EXT
intRB0()
delay_ms(settle); //Let RB0 settle for 2 seconds
INTF_BIT = 0;
if(!INPUT(PIN_B0)) OUTPUT_LOW(PIN_D1); //if RB0 is still low, disable D1
printf("test");
main()
output_high(pin_D1); //initially set D1 high
statements;
while(~clk);
statements;;
Still there is no change on pin D1 even if RB0 changes from H->L. I have added a printf to see if the ISR is operating and I do see printf working each time there is a H->L transition on D1. But the statement
if(!INPUT(PIN_B0)) OUTPUT_LOW(PIN_D1); does not seem to execute.
All I want is regardless of my software SPI, i.e even if the control is waiting for the clock transition, I should be able to process the change on RB0 and set the appropriate signal on D1, because RB0 is a current sense signal and is critical for circuit protection. Please tell me where I am doing wrong.
Thanks |
Posted: Sun Feb 15, 2004 1:32 pm |
Here are a few comments on your code.
This is not necessarily enough to make your code work,
but it's just a few things that I noted on a quick scan.
// The CCS syntax for #device statements does not include
// putting a semi-colon at the end of the line. Remove it.
#device ADC=10;
//Global declares
// In CCS, an "int" is an unsigned 8-bit value.
// This next line will not work.
// An "int" can only hold a number up to 255.
// You need to change the data type to be "int16" instead.
// This is the reason why you were not getting a 2 second delay.
int settle = 2000;
#int_ext
void INTRB0(void);
main()
DELAY_US(10);
INTF_BIT = 0;
// Add the following line to prevent
// the PIC from going to sleep.
#INT_EXT
intRB0()
You don't have to turn off Global interrupts here.
// It's done automatically by the PIC, in hardware,
// when an interrupt occurs.
// delay_ms(settle);
// You don't need the following line.
// The compiler automatically puts in code
// to clear the INTF flag at the end of this
// interrupt service routine.
INTF_BIT = 0;
tmach
Posted: Wed Mar 03, 2004 4:01 pm |
Thanks, I got it working now.
mach |
