Posted: Tue Dec 14, 2021 8:02 am |
First thing honestly don't use floating point. This makes code bulky and slow.
You could get '10' much easier with just integer numbers and just divide by
102. For 0-15, use /64.
However using float as you show, if you want 15, then just use /160 instead
of 255. |
Khansokhua
Posted: Tue Dec 14, 2021 9:55 am |
| I did but I can't obtain 0-15 one by one. It is being 0-1-3-4-6-7-8-9, jumps two step value. What can I do for this? |
Joined: 01 Jul 2010 Posts: 9589 Location: Greensville,Ontario
Posted: Tue Dec 14, 2021 10:32 am |
quick comments..
1) What are you using as the ADC Vref ?
2) What kind of 'filtering' have you on the ADC input pin ?
3) Show the program with how you read the pot.
You'd probably be better using 8 bit ADC mode than the 10 bit. |
Khansokhua
Posted: Tue Dec 14, 2021 11:07 am |
Vref=+5V
PrinceNai
Posted: Tue Dec 14, 2021 1:12 pm |
I'd do three things. First some kind of averaging of the readings, maybe as simple as taking 8 samples, add them together and than divide the sum by 8. Second, the way my mind works, I'd forget the calculations and go with ranges, write a function to get the birler and onlar values directly with something like:
if(adc_value <= 68){
birler = 0;
onlar = 0;
else if (adc_value <= 137){
birler= x;
onlar = y; // x and y represent the desired pattern in your digit constant to display 00 - 15
else{ // do it for 0 - 15
birler = n;
onlar = m;
And third, probably the easiest, I'd get a multiturn pot. |
Khansokhua
Posted: Tue Dec 14, 2021 1:29 pm |
I just solved the issue. The POT I have been using had missing the voltage range. So I will be here for some new problems soon, I am sure. Thank you all  |
PrinceNai
Posted: Tue Dec 14, 2021 1:45 pm |
Very nice to hear you solved the problem. I, for one, feel great when the code and hardware click together and work as intended. Without this forum and all the nice guys out there, I'd probably still be trying to blink a LED.
I'm also not a native speaker of English language, but it made me laugh (do trust me, not in any bad way) the way you put it why you'll come back :-) |
Khansokhua
Posted: Tue Dec 14, 2021 5:43 pm |
I have done so far these things "ready 0-15 POT ", "and will be displayed images", not much. Now I need to select and giving time processing. So what do you suggest?
Respects |
Khansokhua
Posted: Fri Dec 17, 2021 4:56 pm |
Greetings... I am stuck,
I have 7 picture in program memory. Each of them 1024 byte. At last situation each time I press the button, I display the pictures by turn (0-1-2-3-4-5 6-0-1...(with arrays's index)). I want to write data (image) which I am being display at that moment with another button. However, PIC18F46K22 has 1024 byte EEPROM memory. Can I save index of array to show 1024 byte picture?Could you guide me what can I do to save chosen pictures with a button ? I should band together all of chosen. I hope I could explain.
Respects... |
Posted: Sat Dec 18, 2021 6:36 am |
In the Q&A section of the CCS manual there's this ..
How do I wait only a specified time for a button press?
It actually does what you want to do !
Just change the 'timeout' vaule to give you maybe 5 seconds,that's lots of time to see the picture and decide IF you want to press button to select it.
Code it as a function, then in 'main()..
set index to zero
'loop to show pictures
display a picture
call 'buttonpressed' function
check if 'button pressed is true'.....-> save the index value,and exit the 'show pictures loop'
'loop back for next picture(index++)
now do 'something' with the saved index, maybe display THAT picture for ever ? |
Khansokhua
Posted: Sat Dec 18, 2021 1:58 pm |
| Code: | #include <18F46K22.h>
#device ADC=8
#use delay (clock=4000000)
#use fast_io(a)
#use fast_io(c)
#include <HDM64GS12.c>
#include <graphics.c>
#define display_1 pin_B6
#define display_2 pin_B7
#define button pin_A1
#define secme pin_B3
#define slayt pin_A2
unsigned int32 sayac;
int a=0;
int index=0;
char birler=0, onlar=0;
int i,j, k;
const int digit[10]={0x7E,0x0C,0xB6,0x9E,0xCC,0xDA,0xFA,0x0F,0xFE,0xDE};
long int adc_value;
const unsigned char imagineall[][1024] = {{
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0, 0xE0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF8, 0xF0, 0xF0, 0xF0,
0xF8, 0xF0, 0xF0, 0xF8, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF0, 0xF8,
0xF8, 0xFC, 0x3E, 0x3E, 0x3F, 0x3F, 0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x0F, 0x07, 0x07, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x1F, 0x0F, 0x1F, 0x1F, 0x1F,
0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F,
0x0F, 0x1F, 0x1F, 0x1F, 0x1F, 0x1F, 0x3F, 0x1F, 0x1F, 0x3F, 0x3F, 0x3E, 0x7E, 0xFE, 0xFC, 0xF8,
0xF8, 0xF0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF,
0x3F, 0x0C, 0x00, 0x00, 0x00, 0xC0, 0x40, 0x40, 0x40, 0x60, 0x60, 0x40, 0x60, 0x60, 0x60, 0x60,
0x60, 0x60, 0x60, 0x60, 0xC0, 0xC0, 0xC0, 0x40, 0xC0, 0xC0, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x40, 0x40, 0x60, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0xE0, 0xE0, 0x60, 0x20, 0x60, 0x60, 0x60, 0x60, 0x60, 0x40, 0xC0, 0x80, 0x00, 0x07, 0x07, 0x1F,
0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x9E, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0D, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x19, 0x0F, 0x03,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x03, 0x03, 0x03, 0x03, 0x01, 0x01, 0x03,
0x03, 0x03, 0x03, 0x01, 0x00, 0x01, 0x01, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x01, 0x03, 0x03, 0x03,
0x01, 0x01, 0x01, 0x03, 0x03, 0x03, 0x03, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x43, 0x07, 0x0D, 0x08, 0x28, 0x10, 0x00, 0x00, 0x00, 0x01, 0x01, 0x06, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x48, 0x68, 0x6A, 0x6A, 0x6E, 0x2C, 0x28, 0x00, 0x54,
0x0C, 0x58, 0x68, 0x6A, 0x6E, 0x6E, 0x68, 0x68, 0x48, 0x48, 0x50, 0x10, 0x10, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0x80, 0x40, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x02, 0x02, 0x03, 0x06, 0x0E, 0x0E, 0x0E,
0x1E, 0x1C, 0x3C, 0x3C, 0x3C, 0x78, 0x78, 0x78, 0x7C, 0x78, 0xF8, 0xF0, 0xE0, 0xF1, 0xE1, 0xE1,
0xE3, 0xE1, 0xF1, 0x71, 0x61, 0x70, 0x68, 0x70, 0x78, 0x78, 0x78, 0x78, 0x38, 0x3C, 0x3C, 0x1E,
0x1E, 0x0E, 0x0E, 0x06, 0x07, 0x02, 0x01, 0x00, 0x01, 0x00, 0x80, 0x70, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x40,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0xC0, 0x60, 0x20, 0x30, 0x1C, 0x06, 0x03, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0E, 0x0C,
0x00, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x07, 0x0F, 0x0F, 0x0F, 0x0E, 0x0C,
0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x67, 0xFF,
0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0x40, 0x60, 0x70, 0x70,
0xF8, 0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFE, 0xFE, 0xFC, 0xFC,
0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0x78, 0x78, 0x78, 0x30, 0x30, 0x60, 0x60, 0xC0, 0xC0, 0x80, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xFF, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x0C, 0x03, 0x00, 0x00, 0x00, 0x70, 0xF0, 0xF8,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xE3, 0x81, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03,
0x0E, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF, 0x03, 0x00,
0x00, 0x00, 0x00, 0x00, 0x3C, 0x1C, 0x16, 0x0E, 0x0C, 0x7E, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFF,
0xFF, 0xFD, 0xF9, 0xF8, 0xF1, 0xF0, 0xE0, 0x00, 0x00, 0x80, 0x00, 0x00, 0x80, 0x40, 0x00, 0x00,
0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x40, 0x60, 0x70, 0xF0, 0xFD, 0xFF, 0x07, 0x00, 0x00,
0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x00, 0x00, 0xC0, 0x40, 0x00, 0x00, 0xF0, 0xF0, 0x70, 0x70, 0xB0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0x70, 0x70, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xC0, 0xF0, 0xF0, 0xF0, 0xB0, 0x90,
0x80, 0xA0, 0xE0, 0xE0, 0xB0, 0xC0, 0x80, 0xC0, 0x0E, 0x16, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xDF,
0xC1, 0xC3, 0xF7, 0xFF, 0xFF, 0xE7, 0xC1, 0xC3, 0x83, 0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xF3, 0xFF, 0xFB, 0xFF, 0x1C, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x61, 0x7A, 0xF0, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x09, 0x23, 0x40, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xE7,
0xE3, 0xF3, 0xF3, 0x00, 0x00, 0x80, 0x80, 0xC0, 0x00, 0x50, 0x68, 0x94, 0x92, 0xCE, 0xFD, 0xFF,
0xFE, 0xFE, 0xFF, 0xFF, 0x67, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xF3, 0xBF, 0xBF, 0xFB, 0xFB, 0xD9,
0xDB, 0xFF, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xE7, 0xE7, 0xFF, 0xFF, 0xFB, 0xFB, 0x7F, 0xFF,
0xFF, 0xFF, 0xFF, 0xDF, 0xF9, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xEF, 0xEF, 0xF8, 0xF8, 0xC0, 0x90, 0x00, 0x00, 0x80, 0x00,
0xC0, 0x80, 0x80, 0x80, 0x80, 0xE0, 0x00, 0x81, 0x00, 0x04, 0x08, 0x18, 0x08, 0x08, 0x00, 0x00,
0xE0, 0xC0, 0xC0, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xC0, 0xD0, 0xFA, 0xFF,
0xFF, 0xEF, 0xEF, 0xE7, 0xF7, 0xFF, 0xFF, 0x7F, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC7,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xF7, 0xFF, 0xFB, 0xEF, 0xEF, 0xFF, 0xFF, 0xFE, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF,
0xFF, 0xFD, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF7, 0xF7, 0xF7, 0xFB, 0xFB, 0xF9, 0xFD, 0x3F, 0x9F,
0xEF, 0x1F, 0x1F, 0xDB, 0xC1, 0xE1, 0xF1, 0xF0, 0xB1, 0x93, 0x97, 0x8F, 0x8F, 0x1F, 0x3D, 0x7E,
0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xF8, 0xF0, 0xE0, 0xE0,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFE, 0xFC, 0xFC, 0xFE, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xF9, 0xFF, 0xFF, 0xFF, 0xE7, 0xE7, 0xEF, 0xFD, 0xFC, 0xFE, 0xFF,
0xF9, 0xFD, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF3, 0xF9, 0xFC, 0xFF, 0xF9,
0xFD, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0x7F, 0xFF, 0xFF, 0xFF, 0xFD, 0xFC, 0xFC, 0xF8, 0xF6,
0xFE, 0xFD, 0xFB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x1F, 0x0F, 0x07, 0xC7, 0xF3, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFC, 0xFC, 0xFF, 0xFF, 0xFC, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xEF, 0xEF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
0x1F, 0x3F, 0x3F, 0x3F, 0x1F, 0x1F, 0x1F, 0x0F, 0x0F, 0x0F, 0x07, 0x07, 0x07, 0x07, 0x07, 0x07,
0x07, 0x03, 0x03, 0x01, 0x01, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x80, 0xC0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0,
0xE0, 0xF0, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x06, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x8F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xF0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xF0, 0xF0,
0xB8, 0x98, 0xB0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x0F, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xB8, 0x7E, 0x6F, 0x03, 0x01, 0x00, 0x03, 0x07,
0x0F, 0x0F, 0x1F, 0x07, 0x0F, 0x0F, 0x0F, 0x1F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xF0, 0xE0, 0xC0, 0x80, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80,
0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x07, 0x0F, 0x1F, 0x1F,
0x3F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0xFE, 0xFC, 0xF0, 0xE0, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xF8, 0xF8, 0xF8, 0xFC, 0xFC, 0xFA, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xBE, 0xFE, 0xFE, 0xFE,
0xF4, 0xF0, 0xE0, 0xE8, 0xF8, 0xE8, 0xE8, 0xC8, 0xC8, 0xC8, 0xC8, 0xC8, 0xC8, 0xC8, 0xC0, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0xE0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xE0,
0xC0, 0xCC, 0x3E, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0x7F, 0xBF, 0xDF, 0xE1, 0xE3, 0xC7, 0x9F, 0x7F, 0xFE, 0xFC, 0xFC, 0xF8, 0xF8, 0xFC,
0xF8, 0xF8, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF,
0xFF, 0x7F, 0xFF, 0xBE, 0xDD, 0xDF, 0xEF, 0xFF, 0xFF, 0xBF, 0xBF, 0xDE, 0xFE, 0xFD, 0xF7, 0x4F,
0xFF, 0xFF, 0xFF, 0x7D, 0x3F, 0x6F, 0x5F, 0x1F, 0x0F, 0x0E, 0x1F, 0x9F, 0x1F, 0x1F, 0x1F, 0x1F,
0x1F, 0x0E, 0x16, 0x86, 0x86, 0xC0, 0xC0, 0xE0, 0xE0, 0x60, 0xE0, 0xE0, 0xF0, 0xF0, 0xF8, 0xF8,
0xF8, 0xFC, 0xFC, 0xFC, 0xFE, 0xFE, 0xFE, 0x7F, 0x7E, 0x7E, 0x7E, 0x6F, 0xA6, 0x76, 0x73, 0x5A,
0xFF, 0xFF, 0xFF, 0xF7, 0xF7, 0xFF, 0xF7, 0xFF, 0xF7, 0xFF, 0xF7, 0xFF, 0xF7, 0xFF, 0xF6, 0xFF,
0xFF, 0xB9, 0xEF, 0xDF, 0xFB, 0xDF, 0xFF, 0xFF, 0xFF, 0xF7, 0xFB, 0xEF, 0xDF, 0xFF, 0xFF, 0xEF,
0xDF, 0xFB, 0xEB, 0xEB, 0xFB, 0xEB, 0xEB, 0xCB, 0xFB, 0xFF, 0xFF, 0xF7, 0xFB, 0xDD, 0xF1, 0xFD,
0xEB, 0xE3, 0xFF, 0xFF, 0xFD, 0xFD, 0xFE, 0xFF, 0xFB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFB, 0xFE, 0xDE,
0xDF, 0xFF, 0xFF, 0xFE, 0xFD, 0xFD, 0xFD, 0xF9, 0xF9, 0xFD, 0xFD, 0x7A, 0xFC, 0xBC, 0xF8, 0xFD,
0xFE, 0x2C, 0x7E, 0xB2, 0xFE, 0x3E, 0xF7, 0xBF, 0x7F, 0x9F, 0xBF, 0xFF, 0xFF, 0xB7, 0x37, 0xAF,
0xFF, 0x2F, 0x37, 0x17, 0x27, 0x0F, 0x7B, 0x39, 0x20, 0x8A, 0xA4, 0xE0, 0x20, 0x70, 0x18, 0xA4
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00,
0x00, 0x01, 0x01, 0x03, 0x02, 0x01, 0x02, 0x02, 0x01, 0x01, 0x01, 0x01, 0x01, 0x02, 0x02, 0x01,
0x01, 0x03, 0x00, 0x03, 0x03, 0x07, 0x0B, 0x02, 0x03, 0x03, 0x0B, 0x07, 0x03, 0x03, 0x03, 0x07,
0x0F, 0x0F, 0x0F, 0x03, 0x0F, 0x0F, 0x0B, 0x0F, 0x0F, 0x1F, 0x1F, 0x1F, 0x1F, 0x0F, 0x1F, 0x1F,
0x00, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0x80, 0x80, 0xC0, 0xC0, 0xC0, 0xC0, 0x40, 0x40, 0x40, 0x80, 0x80, 0x80, 0x80, 0x80, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x06, 0x06, 0x02, 0x0B, 0x0B, 0x0B, 0x1B, 0x19,
0x3B, 0x37, 0xFF, 0xFF, 0xFF, 0xFD, 0xFD, 0xFD, 0xFD, 0xF9, 0xB9, 0x31, 0x76, 0x66, 0xCE, 0xCF,
0x8F, 0x0F, 0x5F, 0x9F, 0x1F, 0x3E, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xBC, 0xFC, 0xFC, 0xF9,
0xF9, 0xF1, 0xF1, 0xF2, 0xF2, 0xE2, 0xC4, 0xC4, 0x88, 0x18, 0x10, 0x20, 0x68, 0xCE, 0xFC, 0xF4,
0xF5, 0xF7, 0xF7, 0xFC, 0xFC, 0xF8, 0xF8, 0xF8, 0xF0, 0xE0, 0xC0, 0x80, 0x80, 0x80, 0x00, 0x00,
0x00, 0x00, 0x07, 0x0F, 0x1F, 0x3F, 0x03, 0x03, 0x03, 0x07, 0x07, 0x0F, 0x0E, 0x1E, 0x3C, 0x38,
0x71, 0xF1, 0xE0, 0xC0, 0x03, 0x06, 0x1F, 0xF7, 0xCF, 0x0F, 0xEF, 0x89, 0x03, 0x0F, 0x3F, 0x6F,
0x0F, 0x1F, 0x1F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xF9, 0xE1, 0xC7, 0x3F, 0x7F, 0xF5, 0xCB, 0x0F, 0x07, 0x3F, 0xEF, 0xB0, 0x80,
0x00, 0x00, 0x01, 0x00, 0x00, 0x02, 0x1E, 0x7F, 0xE7, 0x81, 0x07, 0xFF, 0xF0, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x03, 0x07, 0x07, 0x0F, 0x0E, 0x1C, 0x79,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xF0, 0x81, 0x04, 0x02, 0x1E, 0x7F, 0x07, 0x07,
0x0C, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xB0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xA0, 0x00, 0x00, 0x00, 0x01, 0x08, 0x07, 0x7F, 0xF0, 0x60, 0x70,
0xF0, 0xF0, 0xB0, 0x70, 0x70, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0x81, 0x01, 0x03, 0x0F, 0x3F, 0x7F, 0xDB, 0xBF, 0x6F, 0xFF, 0x74, 0x00, 0x00, 0x00, 0x00, 0x00,
0x40, 0x72, 0x70, 0x70, 0x70, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0,
0xFF, 0xFF, 0xFF, 0xDF, 0xFF, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFB, 0xFF, 0xFF, 0xD9, 0xCF, 0xC1, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC2, 0xC0, 0xC0, 0xC0,
0xC0, 0xC0, 0xC0, 0xE0, 0xE1, 0xEF, 0xFF, 0xFF, 0xFD, 0xFF, 0xFE, 0xFE, 0x27, 0xC7, 0xE7, 0x86,
0x82, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x05, 0x0C, 0x10, 0x1C, 0x08, 0x10, 0x10,
0x10, 0x20, 0x10, 0xF0, 0xF0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xDF,
0xDF, 0xDF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFB, 0xFC, 0xFC, 0xF8, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC,
0xFC, 0xFC, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x00, 0x80, 0x40, 0xC0, 0xC0, 0x40, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xC0, 0xC0, 0xC8, 0xD4, 0xC6, 0xCE, 0xDC, 0xCC,
0xC0, 0xC0, 0xC0, 0xE0, 0xD0, 0xF8, 0x80, 0x80, 0x88, 0x10, 0x20, 0x20, 0x60, 0x00, 0x00, 0x00,
0x00, 0x00, 0xC0, 0x40, 0xE0, 0xA0, 0xE0, 0xE0, 0x20, 0x00, 0x00, 0x00, 0xB0, 0xD0, 0xD0, 0xE0,
0xEB, 0xF7, 0xF7, 0xF3, 0xF8, 0xF8, 0xFC, 0xFB, 0xFD, 0xFD, 0xFC, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0x7F, 0xFF, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x5F, 0x9F, 0x8C, 0xF8, 0xF0, 0xF0,
0xE0, 0xBE, 0xDC, 0x58, 0x10, 0x30, 0xF8, 0xF0, 0xF0, 0xF0, 0xF0, 0xE0, 0xE0, 0xE0, 0x40, 0xC0,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xE0, 0xF0, 0xF8, 0xF4,
0xF8, 0xF1, 0xE1, 0xF3, 0xF6, 0xF7, 0x87, 0x37, 0x6B, 0xAE, 0xD5, 0xDF, 0xFF, 0xFF, 0x3F, 0xFF,
0xFF, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFF, 0x6F, 0x97, 0xDF, 0xCF, 0xF7, 0x0F, 0x9F,
0xDF, 0xEF, 0x2F, 0x4F, 0x8F, 0x9E, 0xDE, 0x87, 0xB9, 0xE5, 0xFD, 0x9F, 0x1F, 0x3D, 0x3F, 0x3D,
0x3B, 0x37, 0x2F, 0x0F, 0x2F, 0x27, 0x3F, 0x37, 0x1B, 0x97, 0x97, 0xCB, 0xC9, 0xE9, 0xF5, 0xFD,
0xFE, 0xFA, 0xF9, 0x79, 0x38, 0x70, 0x91, 0xE3, 0xE7, 0xEF, 0xEF, 0xFF, 0x7F, 0xEF, 0x77, 0xF7,
0xFB, 0xF8, 0xF8, 0xF8, 0xE0, 0xE0, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xCE, 0xCF, 0xCF, 0xDF, 0xDF,
0xFF, 0xFF, 0xFF, 0xFF, 0xF7, 0xF3, 0xF1, 0xF0, 0xEC, 0x9F, 0x9F, 0x3F, 0x7F, 0x7F, 0x7F, 0x3E,
0x3F, 0x3D, 0x7D, 0x7B, 0x7B, 0x73, 0x72, 0x73, 0x72, 0x73, 0x63, 0x62, 0x62, 0x63, 0x63, 0x43,
0x42, 0xC2, 0xE3, 0xE3, 0x41, 0x51, 0x41, 0x48, 0x60, 0x98, 0x8C, 0x96, 0x93, 0x81, 0x81, 0xC1,
0xC1, 0x40, 0x7E, 0x4C, 0x50, 0x40, 0xC0, 0xC0, 0xE0, 0x68, 0x14, 0x53, 0x1C, 0x19, 0x18, 0x18,
0x38, 0x88, 0x0C, 0x04, 0x04, 0x06, 0x06, 0x07, 0x07, 0x03, 0x03, 0x01, 0x01, 0xE0, 0x90, 0xD8,
0xCD, 0xFC, 0xFE, 0xFE, 0xEE, 0x2E, 0x0D, 0xCB, 0x9B, 0x37, 0x0F, 0x3F, 0xFF, 0xFF, 0xFF, 0x36,
0x1D, 0x03, 0x07, 0x0F, 0x1F, 0x3F, 0xFF, 0xDF, 0xFE, 0xE4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0xF0, 0xFC, 0xFE, 0xFF, 0xFF, 0x7F, 0x1F, 0x07, 0x07, 0xCF,
0xDF, 0xDF, 0xDF, 0xDF, 0xDF, 0xFF, 0x1F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0xFE,
0xFE, 0xFF, 0x3F, 0x3E, 0x1E, 0x2E, 0x0E, 0x8C, 0x8C, 0x48, 0xC0, 0x40, 0x40, 0xC0, 0xC0, 0xC0,
0xC0, 0xC0, 0xC8, 0x85, 0x80, 0x80, 0x80, 0x00, 0x02, 0x03, 0x01, 0x01, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xF0, 0xF8, 0xF8, 0xF8, 0xFD, 0xD8, 0x10,
0x01, 0x03, 0x03, 0x03, 0x07, 0x00, 0x00, 0x00, 0x00, 0x02, 0x04, 0x00, 0x09, 0x3F, 0xFF, 0xFF,
0xFF, 0xFE, 0xFC, 0xE0, 0x00, 0x00, 0x00, 0x7F, 0x3F, 0x0F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xFF, 0xFF, 0xFF, 0x03, 0x01, 0x00, 0x00, 0xFC, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0x07, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
0x04, 0x00, 0x00, 0x10, 0x38, 0x38, 0x71, 0x61, 0x7D, 0xFC, 0x7C, 0x7C, 0x7C, 0x5C, 0x3C, 0x3C,
0x38, 0x39, 0x39, 0x39, 0x91, 0x01, 0x00, 0x01, 0x01, 0x00, 0x30, 0x1C, 0x64, 0x04, 0x3C, 0xFC,
0xFC, 0xF8, 0xF8, 0xF8, 0xF0, 0xF0, 0xE0, 0xE0, 0xE0, 0xC0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x80, 0xE0, 0x78, 0x3C, 0x3F, 0x1F, 0x0F, 0x86, 0xE7, 0xF3, 0xFB, 0xE9, 0xC7, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07,
0x3F, 0xBF, 0xFF, 0xFF, 0xFF, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x07, 0x00, 0x00, 0x00, 0x03, 0x03, 0x7F, 0xFB,
0xFB, 0xE3, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x1D, 0x1F, 0x1E,
0x3E, 0x3C, 0x3C, 0x38, 0x38, 0x38, 0x30, 0x31, 0x21, 0x01, 0x01, 0x01, 0x03, 0x03, 0x02, 0x00,
0x00, 0x00, 0x01, 0x01, 0x00, 0x00, 0x38, 0x3C, 0x1E, 0x0B, 0x0D, 0x07, 0x03, 0x01, 0x00, 0x00,
0x40, 0x7F, 0x3F, 0x1F, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x07, 0x0F, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xE0, 0xE0, 0xF0, 0xF0, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0x01,
0x00, 0x01, 0x02, 0x00, 0x00, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x01, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x20, 0xC0, 0x02, 0x01, 0x00, 0x0F, 0x1F, 0x3F, 0xFF, 0xFF, 0xFF, 0x8F, 0x0E, 0x07,
0x00, 0x01, 0x00, 0x80, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFE, 0xFC, 0xF8, 0xF0, 0xE0, 0xC8, 0x8C, 0x8F, 0x07, 0x07, 0x07, 0x0F, 0x1F, 0x0F,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC,
0xF0, 0xE0, 0x80, 0x00, 0x00, 0x01, 0x07, 0x1F, 0x3F, 0x7F, 0xFF, 0xFF, 0xFC, 0xF8, 0xF0, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE3, 0xEE, 0xF4, 0xFE, 0xFE, 0x3F, 0x3F, 0xFF, 0xFF, 0x3F, 0x3F, 0xFE,
0xFE, 0xFE, 0xFF, 0xFB, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF8, 0xFE, 0xFF, 0x7F, 0x3F, 0x1F,
0x0F, 0x03, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xE0, 0xF8, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFE, 0xFC, 0xFC, 0xF8,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xF8, 0xF0, 0xE0, 0xE0, 0xC0, 0x80, 0x81, 0x81, 0x09, 0x09,
0x0D, 0x9D, 0xDD, 0xCF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xF9, 0xE1, 0x61, 0x01, 0x01, 0x01, 0x01, 0x00, 0x80, 0xC0, 0xC0, 0xE0,
0xF0, 0xF8, 0xF8, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xDF, 0xFF, 0xEF, 0xFF, 0xFF, 0xFF, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x7F, 0x3F, 0x3F,
0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F, 0x3F, 0x1F, 0x07, 0x03,
0x0C, 0x04, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xBF, 0x3F, 0x7F, 0xFF, 0x7F, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7E, 0xCE, 0xFF, 0xFB, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF0, 0xE0, 0xE0, 0x80,
0xF0, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0x9F, 0x1F, 0x31, 0x61, 0x00, 0x00, 0x20, 0x00, 0xC0, 0x80,
0xC4, 0xCE, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xF8, 0xFC, 0xF0, 0x38, 0xB8,
0x81, 0xC7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE7, 0xC0, 0xFB, 0xFE, 0xFF, 0xCF, 0x87, 0xC5,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x40, 0xC0, 0xF8, 0xF0, 0xF8, 0xFC, 0xFE, 0xFE, 0xFF,
0xFF, 0xFF, 0x7F, 0xFE, 0xFE, 0xF8, 0xE0, 0xD0, 0xE0, 0xC0, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x20, 0x10, 0x9C, 0x81, 0xFC, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x0F, 0x3F, 0xFF, 0xFF, 0x0F, 0x03, 0x03,
0x07, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFE, 0xFF, 0xFD, 0xFF, 0xFB, 0xFB, 0xFF, 0xFF, 0xF7, 0xF6, 0xF0, 0xB0, 0x30,
0xD8, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x8C, 0xF6, 0xFE, 0xFF, 0xFF, 0x1F, 0xEF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x7F,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x8F, 0x3F, 0x7F, 0x7F, 0x7C, 0x78, 0xF3, 0xF7, 0xEE, 0xD4, 0x84,
0x08, 0x00, 0x01, 0x03, 0x0F, 0x1F, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0x3F, 0x07, 0xFF, 0xFF, 0x9F,
0x9F, 0x97, 0xAF, 0xF8, 0xFF, 0xDF, 0x9F, 0x3F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF7, 0xFF, 0xFF, 0xE9,
0xB8, 0xF1, 0x77, 0xF8, 0x80, 0xA0, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xEF, 0xDF, 0xFF, 0xBF, 0xFF, 0xF8, 0xF3, 0xFF, 0xFF, 0xDF, 0xBF, 0xBF, 0xBF, 0x7F, 0xFF, 0xFF,
0x7F, 0xFF, 0x38, 0x60, 0xE0, 0xC1, 0x83, 0x81, 0x80, 0x80, 0x00, 0x01, 0x01, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x01, 0x07, 0x0C, 0x08, 0x03, 0x01, 0x0F,
0x0F, 0x07, 0x07, 0x07, 0x17, 0x10, 0x1F, 0x1F, 0x13, 0x03, 0x07, 0x83, 0x5F, 0xFF, 0xBF, 0x1F,
0x1F, 0xAF, 0xCF, 0xFF, 0xEF, 0xFF, 0xDF, 0x3F, 0xF7, 0x7F, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0x64,
0x69, 0xC1, 0x83, 0x82, 0x17, 0x07, 0x0E, 0x0F, 0x0E, 0x1C, 0x38, 0x30, 0x60, 0xC0, 0x00, 0x00,
0x40, 0x83, 0x1E, 0xFC, 0xAF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xED, 0xFF,
0xFF, 0xFE, 0xFA, 0xFE, 0xFC, 0xF8, 0x30, 0xA0, 0x20, 0x20, 0x00, 0x00, 0x00, 0x30, 0x30, 0x70,
0x70, 0x70, 0x70, 0x70, 0x70, 0x70, 0x70, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0xC0, 0xF0, 0xE0, 0xE4, 0xF7, 0xB3, 0xFE, 0xFB, 0xFC, 0xFE,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD, 0xF7, 0xE7, 0xF2, 0xDF, 0xFF, 0x7F, 0x1F,
0x0E, 0x18, 0x39, 0x33, 0x27, 0x7C, 0x40, 0x40, 0xC0, 0x80, 0x80, 0x80, 0x98, 0x8F, 0x0E, 0x80,
0x80, 0x81, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x85, 0xEB, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0xFC, 0xFC, 0xF8, 0xF8, 0xF0, 0xF0, 0xE0,
0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xE0, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0x78, 0x78, 0xF8, 0xFC,
0xFC, 0xFC, 0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFD, 0xFF,
0xEF, 0xDE, 0xFA, 0xFA, 0xFA, 0xFF, 0xA6, 0xE4, 0x64, 0x64, 0x64, 0xC0, 0xC0, 0x88, 0x88, 0x80,
0x80, 0xC0, 0x41, 0x00, 0x00, 0x20, 0x20, 0x20, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x10, 0x10,
0x10, 0x10, 0x10, 0x10, 0x10, 0x40, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xFC, 0xFE, 0xFE, 0xFF, 0xFF, 0xFB, 0xF7, 0xEF, 0xEF, 0xFF, 0xDF, 0xFF, 0xBF, 0xFF, 0xFF, 0xFF,
0xFF, 0xF7, 0xEF, 0xEF, 0xDF, 0xFF, 0xBF, 0xFF, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xF7, 0xFF, 0xEF,
0xDF, 0x9F, 0x9F, 0x0F, 0x1F, 0x1F, 0x0D, 0x07, 0x03, 0x01, 0x00, 0x01, 0x00, 0x1E, 0x3F, 0x3F,
0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xDF, 0xDF, 0xDF, 0xDF, 0xDF, 0xFF, 0xDF, 0xDF, 0xDF, 0xDB, 0xD3, 0xD2, 0xD2, 0xE2, 0xE2,
0xE3, 0xE3, 0xE3, 0xA3, 0xA3, 0xA7, 0xA3, 0xA3, 0x63, 0x62, 0x66, 0x0E, 0x0E, 0x1E, 0x1C, 0x5C,
0x7C, 0xBC, 0x7C, 0xF0, 0xF0, 0xF4, 0xE0, 0xE0, 0xFC, 0x80, 0x00, 0x08, 0x08, 0x18, 0x10, 0x20,
0x01, 0x0F, 0x0F, 0x3F, 0x37, 0x7F, 0x6F, 0xDF, 0xDF, 0xBF, 0xBF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xFC, 0xFB, 0xF1, 0xF7, 0xEF, 0xCD, 0xF7, 0xF7, 0xE7, 0xE7, 0xCF,
0x8F, 0x9F, 0x1F, 0x1F, 0x3E, 0x74, 0xF0, 0xE0, 0xE0, 0xC2, 0x84, 0x24, 0x04, 0x04, 0x80, 0x08,
0x08, 0x00, 0x08, 0x08, 0x11, 0x13, 0x13, 0x37, 0x25, 0x29, 0x09, 0x0B, 0x1D, 0x13, 0x17, 0x3F,
0x7F, 0x3F, 0x7F, 0x7F, 0xFF, 0xBF, 0x7F, 0x7F, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xEF, 0xFF, 0xFF, 0xEF, 0x6F, 0xCF, 0xCF, 0xCF, 0x9F, 0x9F, 0xAF, 0xAF,
0xEF, 0xDF, 0xDF, 0x9F, 0x3F, 0x1F, 0x3F, 0x3F, 0x7F, 0x7F, 0xFE, 0xFE, 0xFE, 0xFE, 0xFC, 0xFC,
0xFE, 0xFC, 0xFD, 0xF8, 0xF9, 0xFB, 0xFF, 0xFF, 0xFF, 0x7F, 0xFF, 0xFE, 0xFC, 0xF8, 0xE0, 0xF0
void parametre(void)
int x=0;
int y=0;
for(i=0;i<64;i+=8)
for(j=0;j<128;j++)
for(k=0;k<8;k++)
if(bit_test(imagineall[a][sayac],k))
glcd_pixel(x+j,y+i+k,ON);
sayac++;
sayac=0;
a+=1;
if(a==7) // pictures' index
a=0;
setup_adc(ADC_CLOCK_DIV_32);
setup_adc_ports(sAN0);
delay_us(20);
output_low(display_1);
output_low(display_2);
set_tris_c(0x01);
set_tris_a(0xFF);
char dizi[][1024];
adc_value=read_adc(); // 0-1023
adc_value=(adc_value/17); //1023/255*2.5=10
birler=(adc_value%10);
onlar=(adc_value/10);
output_high(display_2); // 2. display aktif durumda
output_c(digit[birler]); // displaye bilgi gönderiliyor
delay_ms(5); // gecikme veriliyor
output_low(display_2); // 2. display pasif durumda
output_high(display_1); // 1. display aktif durumda
output_c(digit[onlar]); // displaye bilgi gönderiliyor
output_low(display_1); // 1. display pasif durumda
if(input(button))// A1 display all pictures (one picture each press)
glcd_init(on);
parametre();
while(input(button));
if(input(secme))//B3 save index button
dizi[index][1024]=imagineall[a-1][1024];//Here what is wrong?
index++;
while(input(secme));
if(input(slayt))//A2-slideshow start button
glcd_init(on);
int x=0;
int y=0;
for(i=0;i<64;i+=8)
for(j=0;j<128;j++)
for(k=0;k<8;k++)
if(bit_test(dizi[index-1][sayac],k)) // I can't see,not working.
sayac++;
sayac=0;
My apologies sir, excuse my ignorance.I just try to learn.Here I tried to save index into another array but couldn't happen.There is no error message.Without timing I just try to display selected pictures.Thank you. Respects... |
Khansokhua
Posted: Mon Dec 20, 2021 6:33 pm |
| Above, How do I can set display time using timer with ADC POT for each picture? |
Posted: Mon Dec 20, 2021 7:22 pm |
Once again ,have a look at this...
Easily modified for what you want to do...
within the loop to display the pictures add some code like..
preset the 'timed button press' for say 10 seconds
now enter the ''button press loop'
inside this loop, read the ADC and display on your 2 digit 7 segments
turn pot until you get the number you want
save the 'time value' for the picture.
press the button ( or wait until timer ends)
rest of main code....
1) remember once you're in the 'get time 'loop, you only have , in this case 10 seconds to turn the pot. Really it's more than enough time.
2) you only need to update the 'time display, say every 1/2 second, otherwise it'll be a blur...
3) the time for each picture needs to be store with the picture data, so I suspect you'll use a 2d array. if the time is zero, that picture doesn't get displayed. |
Khansokhua
| Timer1 |
Posted: Mon Jan 24, 2022 8:22 pm |
Greetings
I want to use timer1 instead of delay_ms(3000). So what can I do about it ? Because I am receiving Interrupts disabled to prevent re-entrancy? I thought but did not found anything.
#include <18F46K22.h>//DENETLEYİCİ İSMİ
#device ADC=8 // 8bit ADC birimi POT ayarlamak için kuruldu
#use delay (clock=4000000) // 4Mhz internal osilatör
#use fast_io(a) // A0 ADC için giriş
#use fast_io(c) // butonlar için giriş
#include <HDM64GS12.c> // GLCD kütüphane tanımı
#include <graphics.c> // GLCD kütüphane tanımı
#define display_1 pin_B6//DISPLAY ONLAR BASAMAĞI
#define display_2 pin_B7//DISPLAY BİRLER BASAMAĞI
#define button pin_A1 // RESİM SEÇME
#define kaydet pin_B3 // RESİM KAYDETME
#define slayt pin_A2 // slayt gösterisi
int a=0;
int index=0;
int i,j, k;
const int digit[10]={0x7E,0x0C,0xB6,0x9E,0xCC,0xDA,0xFA,0x0F,0xFE,0xDE};//C1-C7 arası pinler için 0'dan 9'a kadar olan tek basamaklı sayı dizisi
long int adc_value;//ölçülen adc değerini atamak için değişken
int sunum; // seçili resimleri taratırken gerekli bağımsız değişken
int denge=11;//Seçim başlatılmadan kaydetme işlemini engellemek için değişken
char bosdizi[7]={9,9,9,9,9,9,9};// Aynı değerlere sahip hafızadaki resim adedince değişken
const unsigned char imagineall[7][1024] = {{
}}; ///////7 ADET RESİM
void parametre(void)//RESİM TARATMASI İÇİN FONKSİYON
int x=0;//PİXEL KAYDETMEK İÇİN DEĞİŞKEN
int y=0;//PİXEL KAYDETMEK İÇİN DEĞİŞKEN
glcd_init(on);//GLCD açılıyor
for(i=0;i<64;i+=8)//en 64 bit, tek seferde 8 bit işleme alınıyor
for(j=0;j<128;j++)//yukarıdan aşağı tarama 128bit
for(k=0;k<8;k++) // her bir pixel taranıyor
if(bit_test(imagineall[a][sayac],k))//belirtilen pixel resme ait bir parça ise siyah yapılıyor.
glcd_pixel(x+j,y+i+k,ON);// x+j y+i+k belirtilen pixelleri üst üste bindirerek ekranda kalmasını sağlıyor
sayac++; //8192 pixel taranıyor
sayac=0;//Diğer resme geçişte saydırma işlemini tekrarlamak için sıfırlanıyor
a+=1;//index numaralandırma kaydediliyor.
if(a==7)//indexi başa sarmak için
a=0;
setup_adc(ADC_CLOCK_DIV_32); // 32 DIV
setup_adc_ports(sAN0); // A0 ADC BİRİMİ
delay_us(20);
output_low(display_1);//displayler kapalı
set_tris_c(0x01);// C0 pini, GLCD nin 17.pinine bağlanmış giriş yapılarak 5V besleme verilmiştir.
set_tris_a(0xFF); //A0 ADC birimi kullanılıyor
adc_value=read_adc(); // ADC değerini değişkene atıyoruz
adc_value=(adc_value/17); //0-15 sayıcı POT yapabilmek için 17 tam sayısına bölündü
birler=(adc_value%10);//ADC de elde edilen değerleri displayde görüntüleyebilmek için bu yöntem kullanıldı.
denge=12;
glcd_init(on);
parametre();
if(input(kaydet) && denge>11)//B3
if(a==0)// son resmi kaydedebilmek için if koşulu eklendi
bosdizi[index]=6;
bosdizi[index]=a-1;//resim kaydetme
index+=1;//indexi değiştirme
if(index==7)//indexi başa sarma
index=0;
while(input(kaydet));//tek basışta
if(input(slayt))//slayt
int x=0;
int y=0;
for(sunum=0;sunum<7;sunum++){//tüm indexleri tara 0-6
if(bosdizi[sunum]!=9){//eğer indexe ait 9 değeri değişmişse bir resim indexlenmiştir, tüm elemanların "9" olamsının sebebi budur.
glcd_init(on);
for(i=0;i<64;i+=8)
for(j=0;j<128;j++)
for(k=0;k<8;k++)
if(bit_test(imagineall[bosdizi[sunum]][sayac],k))//bosdiziye indexleri kaydetmiştik şimdi her bir kaydedilen değer için resim gösterimi oluyor.
sayac++;
delay_ms(3000);//her resimden sonra 3000 ms bekliyor.
sayac=0;
I arranged those
| Code: | if(input(slayt))//slayt
set_timer1(3036);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);
enable_interrupts(int_timer1);
timer1
| Code: | #int_timer1
void kesme ()
set_timer1(3036);
a++;
if(a>=9){ int x=0;
int y=0;
glcd_init(on);
for(i=0;i<64;i+=8)
for(j=0;j<128;j++)
for(k=0;k<8;k++)
sayac++;
sayac=0;
Posted: Tue Jan 25, 2022 6:22 am |
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
it's a software based RTC in the code library. You can use the 'core' of it to set a flag that '3 seconds is done', to do 'stuff' in main.
you have a programming issue with doing so much code inside the ISR !.
ISRs are supposed to be small, tight code that set a few flags and change a few variables. They are NOT supposed to have 'delays' in them, no printing functions, no 'high math calculations(SINS, floating point, etc.) |
