Problem with Digital Pot MCP4017 driving
Goto page Previous  1, 2, 3
PostPosted: Mon Nov 01, 2021 7:15 am     Reply with quote
PICmodule wrote:
In the i2c in theory we do not need to care about that. This is because we have open drain I/O ins SDA and SCL, and that is the reason we are using pull up resistors that must be pulled up to "other side" interface voltage. This what I
done. But this is theory, in practice not :-)
BR
Very much 'no'.
I2C, cares about the high level voltage, just as much (in fact in many case
'more'), than any other interface.
You cannot mix 3.3v and 5v I2C busses without level shifting.
You can do it by using pins on the PIC that support TTL input levels, and
software I2C. This then sees 3.3v, as a reliable 'high' level.
gaugeguy
PostPosted: Mon Nov 01, 2021 7:35 am     Reply with quote
From MCP4017 data sheet:
Schmitt Trigger
High Input
Threshold
VIH 0.7 VDD — — V 1.8V ≤ VDD ≤ 5.5V
5.0 * .7 = 3.5V
5V5 : 5.5 * .7 = 3.85V
Most I/O pins on the PIC will not allow the pin to be pulled up past its VDD
PostPosted: Mon Nov 01, 2021 7:52 am     Reply with quote
That is where the '5v tolerant' inputs come in. If you have
these the bus can be made to work (using pull ups to 5v).
RB5, 6, 7, 8, 10 & 11. RC6, 7 8 & 9.
Not the pins he was trying to use.
Reading the data sheet and understanding the implications of voltages
needed at both end of the bus is 'critical'...
Page 3 of 3
