Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Microchip ICD2 Debugger
Regular Guy
PostPosted: Thu Jun 24, 2021 12:23 pm     Reply with quote
Will it work on our CCS 16F877 development board please?
Thanks!
CCS 16F1459 PCWH Compiler
CCS 18F14K50 PCWH Compiler
ICD-U40
ICD-S40
Embedded Serial Busses Development Kit
dsPIC30F4012 Development Kit
16F877 Development Kit
PostPosted: Thu Jun 24, 2021 7:02 pm     Reply with quote
Yes.
You will need an IDE that supports the ICD2. MPLAB X does not.
You didn't say what IDE you are using.
Regular Guy
PostPosted: Thu Jun 24, 2021 7:48 pm     Reply with quote
Thank you PCM programmer
We have been using MPLAB 8.92 IDE.
Here is a link for the 16F877 Development Kit we have.
Hardware only.
https://www.ccsinfo.com/product_info.php?products_id=16F877Akit
ICD-U40
ICD-S40
PostPosted: Thu Jun 24, 2021 8:54 pm     Reply with quote
If you're using that IDE, then:
- Go to the Configure menu at the top of the IDE.
- Go to Select Device.
- Choose 16F877 to select that PIC.
Then it tells you what debuggers (programmers) work with that PIC
and are supported by the IDE.
