"printf" and "int32"
ibg
PostPosted: Fri Feb 27, 2004 11:18 am     Reply with quote
Hej,
I'm using a int32 variable and I'm wondering which the format for the printf instruction. I've tried with %lu but it's not working :(
Cheers,
ibg
The code is the following...
void initiate_freq_array(int32 a_freq_array[])
   int i;
   for (i= 0; i < NUMBER_OF_FREQUENCIES; i++)
      a_freq_array[i]= 150000 + (10*i);
      fprintf(DEBUG, "a_freq_array[%d]= %u \n", i, a_freq_array[i]);
PostPosted: Fri Feb 27, 2004 5:15 pm     Reply with quote
Your 10*i value is only 8-bit. With CCS, you need to tell
the compiler to promote it to 32 bits. See the code below:
a_freq_array[i]= 150000 + (int32)(10*i);
