Posted: Fri May 28, 2021 8:16 am |
What you post, cannot work, since 'buffer; is not declared anywhere.
It won't actually compile as shown.
Also the declaration of 'main' is simply wrong. Again won't compile.
So this is not what you are testing. Not a good start...
rand will always give the same sequence, unless you seed it with srand.
No magic involved, look at the source code. It simply takes the current
seed value, multiplies by 1103515245, adds 12345, then returns the upper
16bits mod RAND_MAX.
This will always give the same sequence unless the seed is changed. It
cannot do anything else.
Actually there is a way you could get different sequences. If you reset
the chip and did not power down, the sequence would continue from the
last place it was at before the reset. The RAM does not get cleared on a
reset. However power down, and the sequence will start again at the
beginning. |
Joined: 01 Jul 2010 Posts: 9631 Location: Greensville,Ontario
Posted: Fri May 28, 2021 8:32 am |
hmm... since he's now using the 10f322,...
using this...
from the datasheet...
3.5 User ID
Four memory locations (2000h-2003h) are designated
as ID locations where the user can store checksum or
other code identification numbers. These locations are
readable and writable during normal execution.
would be EASY to get unique 'serial numbers' into the PICs....
or am I missing the something?
Jay |
Posted: Fri May 28, 2021 9:21 am |
No. That is why the 3 22 is so much better.  |
rodrigo_cirilo
Joined: 31 Mar 2019 Posts: 43 Location: Sao paulo/Brazil
Posted: Fri May 28, 2021 11:38 am |
| Ttelmah wrote: | No. That is why the 3 22 is so much better.  |
Sorry for not posting the whole code, I only posted what I thought was necessary.
This is true, in the protheus simulator, if I reset the mclr, it would change the code, even in the simulation, if I switched it off and on again, then the number would be the same.
But during the pic recording with pickit3, I record and observe it in the memory, and it changes the values after I erase the chip and record again, maybe that's it, it doesn't turn off completely when being recorded several times by pickit3, so the values change .
#include <10F322.h>
//#include <12f675.h>
#FUSES NOWDT //Watch Dog Timer
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES INTRC
#FUSES NOWRT
#use delay(clock=4000000)//,RESTART_WDT)
#ORG 0x1E0, 0x1E3 {}
#define RAND_MAX 255
#INCLUDE <STDLIB.H>
#define HEF 0x1E0
#define saida PIN_A0
//Register and bit definitions
#byte PMADRH=getenv("SFR:PMADRH")
#byte PMADRL=getenv("SFR:PMADRL")
#byte PMDATH=getenv("SFR:PMDATH")
#byte PMDATL=getenv("SFR:PMDATL")
#bit CFGS=getenv("BIT:CFGS")
#bit WREN=getenv("BIT:WREN")
#bit FREE=getenv("BIT:FREE")
#bit LWLO=getenv("BIT:LWLO")
#BIT WR=getenv("BIT:WR")
#byte PMCON2=getenv("SFR:PMCON2")
int8 buffer[8];
int8 buffer2[3];
int8 buffer1[8] = {0,0,0,0,0,0,0,0};
const int16 te = 500; //valor de TE
int counter = 0;
int8 a;
void my_erase_program_eeprom(int16 address)
//erases the page at the selected address
disable_interrupts(GLOBAL);
CFGS=FALSE;
PMADRL=make8(address,0);
PMADRH=make8(address,1);
CFGS=FALSE;
FREE=TRUE;
WREN=TRUE;
PMCON2=0x55;
PMCON2=0xAA;
WR=TRUE;
delay_cycles(1);
delay_cycles(1);
WREN=FALSE;
void my_write_program_memory(int16 address, int16 *data, int8 ctr)
//Beware - this does not erase a page for you, and will not handle
//a write that goes beyond the end of a page. Only works to
//write ctr bytes, to the program memory starting at address
int8 count;
WREN=TRUE;
CFGS=FALSE;
LWLO=TRUE; //load latches only
for (count=0;count<((ctr/2)-1);count++)
PMDATL=make8(data[count],0);
PMDATH=make8(data[count],1);
PMCON2=0x55;
PMCON2=0xAA;
WR=TRUE;
delay_cycles(1);
delay_cycles(1);
PMADRL++;
LWLO=FALSE;
PMDATH=make8(data[count],1); //last word
PMCON2=0x55;
PMCON2=0xAA;
WR=TRUE;
delay_cycles(1);
delay_cycles(1);
WREN=FALSE;
//memory layout definitions
struct twobytes
int8 l;
int8 h;
union prog_mem
int16 word;
struct twobytes b;
void pilot_period(){
output_low(saida);
delay_us(23*te);
void start_bit(){
output_high(saida);
delay_us(te);
output_low(saida);
void bit1(){
output_low(saida); //'1'
delay_us(2*te);
output_high(saida);
delay_us(te);
output_low(saida);
void bit0(){
output_low(saida); //'0'
delay_us(te);
output_high(saida);
delay_us(2*te);
output_low(saida);
void end_period(){
bit0();
bit1();
bit0();
bit1();
void envia(int valor){
int b;
for(b=0;b<8;b++){
if(valor&1){
bit1();
else{
bit0();
valor>>=1;
read_program_memory(HEF,buffer1,8);
if(buffer1[0] == 0xFF)
// my_erase_program_eeprom(HEF);
buffer[0] = 0x10;
buffer[2]=rand();
buffer[4]=rand();
buffer[6]=rand();
if(buffer[2] < 100)
buffer[2] = buffer[2] + 100;
if(buffer[4] < 100)
buffer[4] = buffer[4] + 100;
if(buffer[6] < 100)
buffer[6] = buffer[6] + 100;
my_write_program_memory(HEF, buffer, 8);
read_program_memory(HEF,buffer,8);
buffer2[2] = buffer[2];
buffer2[1] = buffer[4];
buffer2[0] = buffer[6];
while(true)
for(int x = 0; x < 200; x++)
counter++;
pilot_period();
start_bit();
for(a=3;a>0;a--){
envia(buffer2[a-1]);
end_period();
while(counter >= 200)
Posted: Fri May 28, 2021 11:59 am |
Reprogramming a PIC, does not erase it's RAM. That is why you are seeing
different sequences. To see what happens on a real chip, you need to use a
real chip and cycle the power. You will then see the sequence starts again
with the same values.  |
rodrigo_cirilo
Posted: Fri May 28, 2021 12:07 pm |
| Ttelmah wrote: | Reprogramming a PIC, does not erase it's RAM. That is why you are seeing
What I reported was with a real chip, I look at the pickit3 programming screen, I can see the memory addresses, then I record the pic, then start reading the RAM, and I see that the generated numbers were recorded in that indicated location 0X1E0, then erase the pic, and record again, start and read, and see that they are different numbers. |
Posted: Sat May 29, 2021 6:48 am |
No, you are 'missing the point'.
When you reprogram the chip, it does not erase the RAM.
When you carry on after this, the chip carries on as if it has been running
'all the time'. The RAM is retained. So though you have put in new code,
the rand function functions as if the chip has kept on working. So you see
apparently a 'new' sequence. However this is not what would happen if
you powered the chip down, and retried. You would then see the same
sequence repeated as Proteus shows. |
Posted: Sat May 29, 2021 8:39 am |
Should have
Near the beginning of the program...
This would eliminate any 'ghosting'...
A term I learned in the 70s when a certain video card for a PC had GREAT caps, so the Video RAM kept data even though PC had been powered off for a hard reboot.
Zero it all out, preset with KNOWN values, then run program.
Always best to KNOW what's in RAM to begin with.... |
