georpo
Joined: 18 Nov 2008 Posts: 281 Location: Athens, Greece.
Posted: Fri Apr 02, 2021 7:37 am |
The yellow trace above is the output of the ACS.
The circuit already has ZC detection to sync with the phases and fire the triacs.
In your example, if I wait 5mS after zero crossing and then take a reading I will probably read '0' if triggering is done beyond 90 degrees which is 5mS.
I do not understand how this could work. _________________ George. |
Woody
Joined: 11 Sep 2003 Posts: 86 Location: Warmenhuizen - NL
Posted: Fri Apr 02, 2021 1:58 pm |
It was a while ago, and it was a bit of a 'let's see if I can do it this way' project, but from the top of my head:
- When the ACS712 is in an AC powerline shunting current it gives off a voltage between 0 and 5V, a 50Hz sine around the 2.5V mark. 2.5V is 0A.
- Period @ 50Hz is 20 msec. I made a 0-crossing detector, connected to an external interrupt. When that fired it started a 5ms timer.
- When the timer rolled over an interrupt was generated that started an AD conversion. This conversion was then more or less done at a top of the sine.
- At zero cross you don't know if you hit a 'mountain' or a 'valley' in the sine, but that can easily be established by testing the ADC value: bigger than 2.5V = mountain, less that 2.5V = valley. In the first instance you subtract 2.5V from the AD value and then have a ratiometric value for the current that was flowing. In the second instance you subtract the AD value from 2.5V and also get that value.
I remember noise was a bit of a problem, the relay next to the ACS was a stupid mistake, but on the whole it did what I wanted: to know if there was AC and to see if current actually flowed and if that flow increased or decreased when somewhere else something got connected / adjusted.
(edited for language)
Joined: 01 Jul 2010 Posts: 9641 Location: Greensville,Ontario
Posted: Fri Apr 02, 2021 4:11 pm |
re: | Quote: | | the relay next to the ACS was a stupid mistake, |
but it looked sooo good on paper !
Some thing are learned BEST while 'on the bench'.....
NO amount of fancy computer 'simulation' program will have EMI or varying VDD or other 'random noise' makers...... |
