BME280 debug output help / now error on PIC24
Goto page Previous  1, 2, 3
towpew
Hurray PIC24 BME280 error looks be solved
PostPosted: Wed Jan 06, 2021 11:04 am     Reply with quote
Ttelmah wrote:
Personally I'd just change all references to 'char' to 'byte'. I've found this
to be the simplest thing. Only use 'char'' for things that are text. For all
things that want a 8bit integer and to work the same on PCB/PCM/PCH/PCD,
the byte data type is the easiest thing to use. Very Happy
It seems that when I change ALL char to byte in the bme280.c file
the problem disappear
I will test it more later this evening.
Thanks all for helping out.
towpew
Re: Hurray PIC24 BME280 error looks be solved
PostPosted: Thu Jan 07, 2021 12:20 pm     Reply with quote
It still working fine this change from char to byte.
PostPosted: Fri Jan 08, 2021 1:51 am     Reply with quote
Good. Smile
I've made that my 'default' since I started using the PIC24/33 chips.
Anything that is used for handling a 'value' being read in from a device, and
wants 8 bit storage, instead of using 'char', always use 'byte'. It solves
a lot of issues that otherwise appear....
towpew
PostPosted: Sun Jan 10, 2021 12:57 pm     Reply with quote
Ttelmah wrote:
Good. Smile
Ok Smile
PostPosted: Sun Jan 10, 2021 1:43 pm     Reply with quote
'default' ...definition....
the set of values some other programmer decided should be 'normal'......NOT you.....
the 'default' (aka standard) for serial communications on a PC was true RS232 using a 25 pin connector........NOW the 'default' is USB3, well today, it'll change in a few moments....
Jay Smile
PostPosted: Mon Jan 11, 2021 1:04 am     Reply with quote
No, Jay, that is to 'compiler default'. I carefully said 'my default'..... Very Happy
PostPosted: Mon Jan 11, 2021 6:01 am     Reply with quote
hmm, well I guess 'default' is mine....sigh, getting old and had a newborn lamb stay overnight in my office.found out what you feed into a lamb eventually comes back out....
PostPosted: Mon Jan 11, 2021 7:10 am     Reply with quote
That's true of an amazing number of newborn things... Very Happy
Must admit 'lamb in the office', is not one I've encountered. Had owls,
foxes, bats, ferrets, puppies, dogs, cats, snakes, squirrels, hamsters,
tortoises and rats at various points.
Page 3 of 3
