16 bit integer to binary
raman00084@gmail.com
PostPosted: Fri Jan 01, 2021 9:11 am     Reply with quote
I want to convert a 16bit number to binary and store the value in an array.
What is the best and simple way to do this?
PostPosted: Fri Jan 01, 2021 9:20 am     Reply with quote
Where do your 16-bit numbers come from, and what format are they in ?
Are they ASCII numbers in a string ? Are they in BCD format ?
Or, are they already in binary and you don't know it ?
What device is sending these numbers to you ?
PostPosted: Fri Jan 01, 2021 9:42 am     Reply with quote
A 'bit' is a binary digit. So if you have a '16bit number', then it already is
binary!.... Internally things are stored in binary....
Do you mean you want to output it as a binary text string?. If so, look
at the itoa function.
PostPosted: Fri Jan 01, 2021 10:30 pm     Reply with quote
for example i have i int16 number
unsigned int16= 62261;
the binary for the above is 1111 0011 0011 0101
now how can i convert 62261 to 1111 0011 0011 0101 and store the
1s and 0s in an array
PostPosted: Sat Jan 02, 2021 2:16 am     Reply with quote
So you actually want an array of numbers 0/1, not ascii text?. itoa
converts to ASCII.
You would just have to code it. Something like:
int1 result[16];
void valtobin(unsigned int16 from)
   int8 index=0;
   for(index=0;index<15;index++)
      if (from & 1/
         result[index]=1;
         result[index]=0;
      from/=2;
//If you then call valtobin(62261);
result[0] will be the bottom bit result[1] the next etc..
In fact you could probably do this directly by creating a union. So:
union {
   int1 bits[16];
   unsigned int16 whole;
} getbits;
    getbits.whole=62261;
//should then give getbits.bits[0] withh the least significant bit etc...
PostPosted: Sat Jan 02, 2021 4:28 am     Reply with quote
converts to ASCII.
int1 result[16];
   int8 index=0;
      if (from & 1/
         result[index]=1;
         result[index]=0;
      from/=2;
union {
   int1 bits[16];
} getbits;
You have done one mistake it should be index<=15, you have missed the =
for(index=0;index<15;index++);
Thanks for your help it is working now.
PostPosted: Sat Jan 02, 2021 9:40 am     Reply with quote
Honestly the union method is far better. Uses a huge amount less space and
time.
