int32 to int array
pilar
int32 to int array
PostPosted: Wed Sep 09, 2020 3:06 pm     Reply with quote
I am trying to save an number int32 into an int array containing each of that number's int8
i.e. if I have
int32 number = 1599684516 which in HEX = 5F59 3FA4
how can I get to
int numberArray[4]
where:
numberArray[0] = 0xA4;
numberArray[1] = 0x3F;
numberArray[2] = 0x59;
numberArray[3] = 0x5F;
Any suggestions gratefully received.
jeremiah
PostPosted: Wed Sep 09, 2020 4:38 pm     Reply with quote
the make8() and make32() functions are one method of doing this (see them in the manual).
Additionally you can do a union type between the unsigned int32 and the 4 byte array.
elcrcp
PostPosted: Wed Sep 09, 2020 4:39 pm     Reply with quote
You can use make8() function, something like this would help you
for(int8 cnt=0;cnt<4;cnt++)
   numberArray[cnt]=make8(number,cnt);
There is nothing you can't do if you try
PostPosted: Wed Sep 09, 2020 4:58 pm     Reply with quote
I think he wants an 'unmake32()' function NOt a make32().
he needs to breakdown the int32 into 4 int8 ?
jeremiah
PostPosted: Wed Sep 09, 2020 5:02 pm     Reply with quote
yes, that's why we suggested make8() (I tossed in the make32 for rebuilding if desired).
PostPosted: Thu Sep 10, 2020 12:25 am     Reply with quote
Honestly, use a union:
union {
   unsigned int32 whole;
   unsigned int8 bytes[4];
} combiner;
combiner.whole=1599684516 //which in HEX = 5F59 3FA4
//then combiner.bytes[0] will contain 0xA4
//combiner.bytes[1] will contain 0x3F
//combiner.bytes[2] will contain 0x59, and
//combiner.bytes[3] will contain 0x5F
//The great thing about this is it'll work both ways. You can write (say)
combiner.bytes[2]=0x1A
//and then combiner.whole will contain 0x5F1A3FA4 = 1595555748
The union is a really nice way to move data from one format to another.
What happens is the two (or more) parts, are written into and read from
the same part of memory. So here you have an int32 variable called
'whole', in the same location as an array of four int8's.
steve__p
PostPosted: Thu Sep 10, 2020 12:07 pm     Reply with quote
what about this:
int32 number;
int    *numberarray;
numberarray=(int*) &number;
then you can use numberarray[0]....
dluu13
PostPosted: Thu Sep 10, 2020 2:21 pm     Reply with quote
steve__p wrote:
what about this:
int32 number;
int    *numberarray;
That's kind of like the union, but the union is cleaner and you don't need to mess around with pointers.
PostPosted: Thu Sep 10, 2020 2:46 pm     Reply with quote
I'm thinking the union method is faster and smaller, though I haven't tested it.
Jay
PostPosted: Fri Sep 11, 2020 8:03 am     Reply with quote
You are using pointers either way (after all you access an array...). However
casting does have an overhead, so the pointer approach will take a little
longer.
If you use fixed indexes for the bytes, the union codes as single byte moves.
The pointer version even then results in a lot of code.
So the union will optimise better.
