Can't read data with SPI using PIC16f18346
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
L.T.
PostPosted: Thu Aug 13, 2020 3:04 am     Reply with quote
Thank for your time and sorry for my ignorance. I need your help. I tried everything but I failed. :(
OK. No guarantees on this, but this covers most of the problems with
what has been posted:
#include <16F18346.h>
#device ADC=10
#use delay(internal=16000000)
//setup softwarew SPI so bit order can be reversed.
#use spi(DI=PIN_B4, DO=PIN_C7, CLK=PIN_B6, LSB_FIRST, baud=1000000, MODE=2, stream=PGA)
#PIN_SELECT U1TX=PIN_A1
#PIN_SELECT U1RX=PIN_A0 //basic UART setup for diagnostics
#use RS232(UART1, baud=9600, ERRORS)
// Define commands by name
#define P1BL  0x00
#define P2BL  0x01
#define P1LO  0x02
#define P2LO  0x03
#define TNLM  0x04
#define UMR  0x05
#define TNLR  0x06
#define TEDD  0x07
#define SD  0x08
#define SRR  0x09
#define SRW  0x0A
#define EEBR  0x0B
#define EEBW  0x0C
#define TVGBR  0x0D
#define TVGBW  0x0E
#define THRBR  0x0F
#define THRBW  0x10
#define syncByte 0x55
int numObj=1;
unsigned int objTime[8];
byte ultraMeasResult[36]; //buffer for results
/*------------------------------------------------- calcChecksum -----
| Function calcChecksum
| Purpose: Calculates the UART checksum value for n bytes in the buffer
| Parameters:
| Number of bytes
| Returns: byte representation of calculated checksum value
int checksum(char * buffer, int number)
   unsigned int16 sum=0;
   unsigned int8 ctr=1; //ignore 0x55
   do {
      sum+=buffer[ctr++];
   } while (ctr<number);
   sum &= 0xff; //low 8 bits only
   sum ^= 0xFF; //inverted
   return sum;
/*------------------------------------------------- ultrasonicCmd -----
| Function sendCommand
| Purpose: Issues a burst-and-listen or listenonly
command based on the number of objects to be detected.
| Parameters:
| cmd (IN) -- determines which preset command is run
| • 0 = Preset 1 Burst + Listen command
| • 1 = Preset 2 Burst + Listen command
| • 2 = Preset 1 Listen Only command
| • 3 = Preset 2 Listen Only command
| number (IN) -- PGA460 can capture time-offlight,
width, and amplitude for 1 to 8 objects.
| TCI is limited to time-of-flight measurement data only.
| Returns: none
void sendCommand(int cmd, int number)
   //send a command packet to the device
   int ctr;
   byte bufCmd[4]; // prepare bufCmd
   bufCmd[0]=syncByte;
   bufCmd[2]=number;
   numObj=number; //update number of objects to detect
   memset(objTime, 0xFF, 8); // reset buffer
   switch (cmd)
   case 0: // Send Preset 1 Burst + Listen command
   bufCmd[1] = P1BL;
   bufCmd[3] = Checksum(bufCmd,3);
   case 1: // Send Preset 2 Burst + Listen command
   bufCmd[1] = P2BL;
   case 3: // Send Preset 1 Listen Only command
   bufCmd[1] = P1LO;
   case 4: // Send Preset 2 Listen Only command
   bufCmd[1] = P2LO;
   default: return;
   //Now write buffer
   for (ctr=0;ctr<4;ctr++)
      spi_xfer(PGA,bufCmd[ctr],8);
void pullResult(void)
   //Now data sheet disagrees with itself on whether a checksum is required for
   //the read command. Code shows it, but data sheet says it is not needed.
   //Including anyway....
   byte buf[3]; //temporary TX buffer
   int ctr;
   buf[0]=syncByte;
   buf[1]=UMR;
   buf[2]=checksum(buf,2);
   //Now write buffer
   for (ctr=0;ctr<3;ctr++)
      spi_xfer(PGA,buf[ctr],8);
   //clear incoming buffer
   memset(ultraMeasResult,0,sizeof(ultraMeasResult));
   //Now need to read reply
   delay_us(125); //worst case command processing dead time
   for(ctr=0; ctr<((2+(numObj*4))); ctr++)
      //read max 'numObj replies
      ultraMeasResult[ctr]=spi_xfer(PGA,0xFF,8);
float convertResult(byte source)
   int16 speedSound = 343;
   int index;
   int16 objDist;
   index=(source/3)*3;
   switch(source%3)
      case 0: //Objn Distance (m)
         objDist = make16(ultraMeasResult[index+1],ultraMeasResult[index+2]);
         return (objDist/2*0.000001)*speedSound;
      case 1: //Objn Width (us)
         return (ultraMeasResult[index+3])*16.0;
      case 2: //Objn Peak Amplitude
         return ultraMeasResult[index+4];
   //Now, comms requires 300uSec active data before starting
   //Clock out 0xFF's to generate this
   int ctr;
   float distance;
   for (ctr=0;ctr<8;ctr++)
      spi_xfer(PGA,0x55,8);
   //Now need to issue a preset 1 command, then pause for 100uSec
   //and read response
   while (TRUE)
      sendCommand(P1BL, 1); //one channel only
      delay_ms(70); //worst case command delay is 65mSec
      pullResult();
      //Now need to convert these values
      for (ctr=0; ctr<numObj; ctr++)
         distance=convertResult(0+(ctr*3));
         printf("Distance %f/n", distance);
      delay_ms(500); //slow things down
Uses a com port for output (move this somewhere to suit your hardware.
L.T.
PostPosted: Thu Aug 13, 2020 3:14 am     Reply with quote
Thanks, I'll try it now.
I tried but PGA didn't answer.
L.T.
PostPosted: Fri Aug 14, 2020 12:45 am     Reply with quote
Hey there,
I found a problem in the code. memset function doesnt work perfectly. It isn't erasing all data in misoBuf array. misoBuf is the array of slave device's answers.
BYTE misoBuf[131];
memset's description in 16F18346.h file is:
_bif void memset(unsigned int8* destination, unsigned int8 value, unsigned int16 num);
And I used memset function in this part for clean the buffer:
void pga460_spiTransfer(BYTE* mosi, BYTE size )
   uint16 temp2;
   memset(misoBuf[0], 0x00, sizeof(misoBuf)); // idle-low receive buffer data
   for (int i = 0; i<size; i++)
      //digitalWrite(SPI_CS, LOW);
      misoBuf[i] = usscSPI_transfer(mosi[i]);
      //digitalWrite(SPI_CS, HIGH);
   return;
When I used memset as you can see in the code above, I get misoBuf array as follows:
misoBuf before memset:
"\x e9\x ea\x eb\x ec\x ed\x ee\x ef\x 0\x 88\x 88\x 88\x 88\x 88\x 88\x 0\x 20\x 21\x ff\x 84\x 21\x 8\x 42\x 0\x 0\x 0\x 75\x 1b\x 81\x 20\x 0\x 0\x 5\x e9\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x f0\x f1\x f2\x f3\x f4\x f5\x f6\x f7\x f8\x f9\x fa\x fb\x fc\x fd\x fe\x ff\x 0\x 1\x 2\x 3\x 4\x 5\x 6\x 7\x 8\x 9\x a\x b\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0"
misoBuf after memset:
"\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 88\x 88\x 88\x 88\x 88\x 88\x 0\x e9\x 20\x ff\x 84\x 21\x 8\x 42\x 0\x 0\x 0\x 75\x 1b\x 6b\x 21\x 0\x 0\x 5\x 20\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0"
I tried a lot of version of using memset as below:
memset(&misoBuf[0], 0x00, sizeof(misoBuf));
memset(*misoBuf[0], 0x00, sizeof(misoBuf));
*memset(misoBuf[0], 0x00, sizeof(misoBuf));
*memset(&misoBuf[0], 0x00, sizeof(misoBuf));
etc.
Even, I wrote memset function myself. You can see below.
void *tmemset8( uint8 * adrest, uint8 datat, uint8 sizet){
   while(sizet-->0){
      *adrest=data;
      adrest++;}
    tmemset8(misoBuf, 0x00, sizeof(misoBuf)); // idle-low receive buffer data
   return;
And I get same result. It never erase all data. I tried a lot of version of writing new memset function as below:
   for(int index=0;index<sizet;index++)
      adrest[index] = datat;
   return(adrest);
void tmemset8( uint8 * adrest, uint8 datat, uint8 sizet){
   return(adrest);
etc.
What is the problem guys?
PostPosted: Fri Aug 14, 2020 1:54 am     Reply with quote
This is not how you pass the address of an array in C.
You are giving memset the value of the 1st element in the array.
uint16 temp2;
PostPosted: Fri Aug 14, 2020 2:00 am     Reply with quote
So you are actually erasing loads of stuff in the wrong part of the
processor's memory. The code I posted use the correct syntax for memset.
L.T.
PostPosted: Fri Aug 14, 2020 2:50 am     Reply with quote
uint16 temp2;
When I did like you told, I get the result as follows:
"\x e9\x ea\x eb\x ec\x ed\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x f6\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 75\x 1f\x 3\x 1\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 1\x 0\x 0\x 0\x a0\x 1\x 90\x a6\x 8\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0\x 0"
L.T.
PostPosted: Fri Aug 14, 2020 2:55 am     Reply with quote
I can't see any difference between yours and mine. I used memset for objTime or ultraMeasResult. It does not work for them too, some of them are reset and some remain stable.
PostPosted: Fri Aug 14, 2020 3:39 am     Reply with quote
Do you think I am telling you to do this ?
I am not telling you to do that. I was quoting your code.
This is what you should do:
memset(misoBuf, 0x00, sizeof(misoBuf));
If it doesn't work, then post your compiler version.
L.T.
PostPosted: Fri Aug 14, 2020 4:50 am     Reply with quote
I tried it too.. Doesnt work. MPLABX IDE V5.05 and CCS C Compiler v5.076
PostPosted: Fri Aug 14, 2020 5:06 am     Reply with quote
See the test program posted below.
Here are the results. First it prints the array contents to show that
it holds all these numbers.
0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,
16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,
32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,
48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,
64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79,
80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,
96,97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,
112,113,114,115,116,117,118,119,120,121,122,123,124,125,126,127,
128,129,130,
Then it prints the array again, after running memset on it. It works.
This was tested with vs. 5.094. If it doesn't work with your version,
then I'll install your version and test it.
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,
Test program:
#include <18F46K22.h>
#fuses NOWDT
#use delay (internal=4M)
BYTE misoBuf[131] =
0, 1, 2, 3, 4, 5, 6, 7, 8, 9,10,11,12,13,14,15,
109,110,111,112,113,114,115,116,117,118,119,120,
121,122,123,124,125,126,127,128,129,130
int8 i;
for(i=0; i<sizeof(misoBuf); i++)
    if(i%16 == 0)
       putc('\r');
    printf("%u,", misoBuf[i]);
putc('\r');
putc('\r');
    if(i%16 == 0)
       putc('\r');
while(TRUE);
L.T.
PostPosted: Fri Aug 14, 2020 6:08 am     Reply with quote
I cant run the program, it gave an error about RS232.Then I erased RS232 part, because it is not necessary. I did debug, but when it came memset line, program has closed.
PostPosted: Fri Aug 14, 2020 6:24 am     Reply with quote
what was the RS232 error ??
L.T.
PostPosted: Fri Aug 14, 2020 6:51 am     Reply with quote
I had to choose a pin (#select_pin), but I have no idea which pin is correct to read from the computer.
PostPosted: Mon Aug 17, 2020 3:01 am     Reply with quote
Working with Ttelmah, I was able to get MPLAB X vs. 5.30 to display printf
statements in the UART1 tab of the MPLAB X Simulator.
I installed CCS vs. 5.076 (same as your version). I compiled the
test program shown below and it worked fine. It displayed this output.
This shows that memset() did zero the array correctly.
128,129,130,
0,0,0,
Test program:
#fuses NOWDT
#pin_select U1TX = PIN_C6
#pin_select U1RX = PIN_C7
BYTE misoBuf[131] =
int8 i;
    if(i%16 == 0)
       printf("\r\n");
printf("\r\n");
printf("\r\n");
    if(i%16 == 0)
       printf("\r\n");
while(TRUE);
Page 3 of 7
