screen print cleaning
Goto page Previous  1, 2
ertansuluagac
PostPosted: Thu May 14, 2020 1:25 am     Reply with quote
lcd_line=1 in your code give error. Others codes are OK.
Line 231(10,18): Undefined identifier lcd_line
Es
PostPosted: Thu May 14, 2020 2:58 am     Reply with quote
That is assuming you are using flex_lcd. Doesn't everybody?.
If you are using the CCS LCD driver instead, you will need:
g_LcdX = 0;
g_LcdY = 0;
ertansuluagac
PostPosted: Thu May 14, 2020 4:24 am     Reply with quote
Is it correct?
         lcd_send_byte (0,2);
         g_LcdX = 0;
         g_LcdY = 0;
         delay_us (1640);
Es
PostPosted: Thu May 14, 2020 5:42 am     Reply with quote
That depends on WHICH LCD driver you are using !! We can't see the rest of your program( 1st 9+- lines at least), to SEE which LCD driver you've added to your program.
Page 2 of 2
