Programming MAX1463
Oliver Lai
Programming MAX1463
PostPosted: Wed Feb 11, 2004 6:56 pm     Reply with quote
I have MAX1463 and PIC18F452, the interface between them is SPI.
How can I programming MAX1463 through PIC18F452?
Need your knowlege and any suggestions urgent!
Thanks!
Oliver
Neutone
PostPosted: Thu Feb 12, 2004 8:05 am     Reply with quote
I suggest you try using a less complex chip. Develop some experience using SPI protocol and then get started with a very complex sensor chip. You could also get the developers kit they offer for people who are just getting started with that chip. The fact they even make a kit just for that chip indicates it is not a simple chip to use.
Oliver Lai
how to get the data file, which is saved in PC, into PIC
PostPosted: Thu Feb 12, 2004 11:45 am     Reply with quote
Thanks, Neutone for your kindly suggestion!
My problem actually is: I don't know how to get the data file, which is saved in PC, into PIC (the data file is the code of MAX1463 hex file).
Oliver
