kmp84
Nibble to word |
Posted: Sat Nov 23, 2019 3:17 am |
Any faster and simple method to make word from nibbles?
byte3 <<= 4;
byte2 &=0xF;
byte3 |= byte2;
byte1 <<= 4;
byte0 &=0xF;
byte1 |= byte0;
word = make16(byte3, byte1); |
Best Regards! |
Joined: 01 Jul 2010 Posts: 9586 Location: Greensville,Ontario
Posted: Sat Nov 23, 2019 7:22 am |
Use of 'structure' would allow direct access to the 4 nibbles within the 16bit word.
Just be sure the order is correct by testing known values !
Posted: Sat Nov 23, 2019 12:50 pm |
Combining a union with a bitfield structure is the easiest way to get a
word:
struct nibble {
int8 one:4; //4bit bitfield
int8 two:4;
union {
struct nibble nib[2];
int16 word;
} combiner;
//you can then access the nibbles as
combiner.nib[n].one //etc..
//The word is then combiner.word;
Also, look at the machine instruction 'swap'. CCS makes this available
as a C instruction, and it would get rid of all the 4bit rotations:
swap(byte3);
byte3=(byte3 & 0xF0) | (byte2 & 0xF);
Will give you 'byte3 containing what was byte2 in the top nibble and byte2
in the bottom nibble. If you can be sure that the values arriving will never
exceed 0xF, then the '& instructions are not needed. |
kmp84
Posted: Sat Nov 23, 2019 1:46 pm |
Hi Mr. Ttelmah and Mr. Temtronic,
In my case I have four bytes in array, for example:
0x3A, 0x3B, 0x3C, 0x3D and have to be converted to word 0xABCD.
Thanks and Best Regards! |
Posted: Sat Nov 23, 2019 2:27 pm |
The union is for a 16bit result. You have:
combiner.nib[0].one
combiner.nib[0].two
combiner.nib[1].one
combiner.nib[1].two
Write your bytes into these, and combiner.word is the 16bit result.
On using swap I was showing just one byte, but you already know
how to combine two bytes to make a word. |
kmp84
Posted: Sun Nov 24, 2019 2:53 am |
Thanks for help!
Any idea why when I'm in debug mode I can't see all data: https://ibb.co/h9tVSmT
Compiler ver. 5.076.
ICD U64.
Best Regards! |
Posted: Sun Nov 24, 2019 7:00 am |
Please post your test code, somethings 'funny' for sure.
There may be a 'cleaner' way to do what you want. |
Posted: Sun Nov 24, 2019 7:42 am |
Consider not storing your nibbles separately.
Instead store them directly into 4bit variables:
#include <18F45K80.h>
#device ADC=12
#FUSES NOWDT
#use delay(crystal=20000000)
#use RS232(UART1, ERRORS, BAUD=9600) //setup basic comm port
union {
struct {
int8 byte0:4;
int8 byte1:4;
int8 byte2:4;
int8 byte3:4;
} parts;
unsigned int16 word;
} combiner;
//Write the four nibble variables as a demo
combiner.parts.byte0=4;
combiner.parts.byte1=3;
combiner.parts.byte2=2;
combiner.parts.byte3=1;
//Print the 16bit value
printf("%LD\n", combiner.word);
delay_cycles(1);
You have four values called combiner.parts.bytex, each of which can
hold a four bit value. You can use these just like any normal variable
reading or writing them at will. Then when you want to access the
combined 16bit value, just use combiner.word. Use the 'parts', where
you currently use bytex. |
kmp84
Posted: Sun Nov 24, 2019 12:38 pm |
This is test code which has a problem in debug mode:
#include <16F1459.h>
//#device *=16
#fuses INTRC_IO,NOPROTECT,MCLR,PUT,WDT
#use delay(clock=4M)
#use rs232(DEBUGGER, stream=MONITOR, rcv=PIN_B6, xmit=PIN_B6)
/* Ttelmah's example*/
union {
struct {
int8 byte0:4;
int8 byte1:4;
int8 byte2:4;
int8 byte3:4;
} parts;
} combiner;
#zero_ram
void main (){
fprintf(MONITOR, "\n\rTarget 16F1459 StartUp!");
combiner.parts.byte0=1;
combiner.parts.byte1=2;
combiner.parts.byte2=3;
combiner.parts.byte3=4;
fprintf(MONITOR, "\n\r a : 0x%LX", combiner.word);
for(;;){
and it's debug screen: https://ibb.co/RjPBpxv |
Posted: Sun Nov 24, 2019 2:15 pm |
Maybe it's just me but I'd like you to refer to 4 bit wide variables as nibbles or nibs instead of bytes...
4nibs instead of parts.... it just 'reads' better to me...
Old guys like me think bytes are 8 bits wide, nibbles are 4, words are 16....
have to ask though, does the ..
actually send the correct 0x1234 data to a PC terminal program ?
kmp84
Posted: Sun Nov 24, 2019 2:41 pm |
temtronic wrote: |
Yes, Mr.temtronic. The printed word value is correct!
Debuggers and debugging is not the best part of the CCS Compiler!
We may have diverted a bit from the main topic.. |
Posted: Sun Nov 24, 2019 3:01 pm |
well.. you've confirmed Mr. T's code is correct and the PIC is sending data to the PC !! It'd the debugger that appers to be faulty.
I never use the ICD or debugger, prefer to test in the 'Real World'.
kmp84
Posted: Sun Nov 24, 2019 3:28 pm |
temtronic wrote: |
I think so, but when developing new code debugging save more time IF work correct!
Posted: Sun Nov 24, 2019 11:20 pm |
Obviously the issue here is that the debugger can't understand offset
bitfields. Not really surprising. Honestly probably better to just display
the combined result. If you think about it expecting the debugger to be
able to display a variable that could be anywhere in the actual byte
and could be any size, is asking rather too much.... |
Posted: Mon Nov 25, 2019 1:01 am |
temtronic wrote: | Maybe it's just me but I'd like you to refer to 4 bit wide variables as nibbles or nibs instead of bytes...
Agree wholeheartedly. I only called them 'bytex', to match his existing
variables. |
