16LF18426 - ADC² module: Problem of PIC current consumption
Synthex
PostPosted: Sat Oct 12, 2019 4:28 am     Reply with quote
It seems to me that it is not possible to shut down the ADC² module.
Is there a bug?
#include <16LF18426.h>
#device ADC=12
#FUSES NOCLKOUT
#FUSES NODEBUG
#FUSES NOEXTOSC
#FUSES NOLPBOR
#FUSES NOLVP
#FUSES NOPPS1WAY
#FUSES NOSTVREN
#FUSES NOWRT
#FUSES NOWDT
#FUSES NOPROTECT
#FUSES NOMCLR
#FUSES NOBROWNOUT
#FUSES NOFCMEN
#FUSES RSTOSC_HFINTRC
#use delay(internal=1000000)
void main()   {
      delay_ms(4000);    //  210 µA  @  3 volts
      SETUP_ADC(ADC_OFF);
      delay_ms(4000);    //  700 µA  @  3 volts
Consumption after startup : 210 µA
Consumption after instruction SETUP_ADC(ADC_OFF) : 700 µA
I use CCS C Complier version 5.090
Thank you so much for any help !
PostPosted: Sat Oct 12, 2019 4:50 am     Reply with quote
While I don't use that PIC or compiler version, the numbers are interesting.
My 'guess' is that the bit to turn on/ turn off the ADC is backwards.
Assuming the PIC starts up with ADC on, it consumes 210ua, then when adc is off, 700 ua.
I suggest dumping the listing and reading the datasheet (ADC section) to decode which bits are being controlled.
Jay
PostPosted: Sat Oct 12, 2019 4:57 am     Reply with quote
It's a bug in vs. 5.090. See below. They're moving 0x84 into ADCON0.
That turns the ADC on. See page 287 of the 16F18426 data sheet.
http://ww1.microchip.com/downloads/en/DeviceDoc/PIC16LF18426_46-Errata-70000799B.pdf
.................... SETUP_ADC(ADC_OFF);
002C: MOVLW 08
002D: MOVLB 02
002E: MOVWF ADCON2
002F: CLRF ADCON3
0030: CLRF ADCLK
0031: CLRF ADACQH
0032: MOVLW FF
0033: MOVWF ADACQL
0034: MOVLB 01
0035: CLRF ADRPT
0036: MOVLW 84
0037: MOVLB 02
0038: MOVWF ADCON0
Try the work-around shown in bold below:
#byte ADCON0 = getenv("SFR:ADCON0")
SETUP_ADC(ADC_OFF);
ADCON0 = 0; // *** Bug fix in vs. 5.090. Turn ADC off.
You should report this to CCS support.
Synthex
PostPosted: Sat Oct 12, 2019 1:27 pm     Reply with quote
Yes, it works perfectly now.
I will report this bug to CCS support.
Thank you for your reactivity
and your commitment during all these years !
PostPosted: Sun Oct 13, 2019 8:46 am     Reply with quote
Yes.
I've just done a little more testing, since normally a fault like this is just
a matter of the wrong value in the #define for ADC_OFF. However in this
case, none of the bits in this seem to stop the compiler from physically
enabling the ADC. So it looks as if the problem is fundamental in their
code.
So for now use PCM_Programmer's fix, and hopefully CCS will come back
with a compiler fix for this....
