How to change AD channel "in fly" ??
artohautala
PostPosted: Mon Oct 07, 2019 5:52 am     Reply with quote
I'm trying to change AD-channel from channel 0 to channel 1 but I can't make it work.
Please help me... I'm tried it about three hours today and nothing seems to help.
#include  <16F88.h>
#device ADC=10
   //I THINK THIS WORKS ,,,
   void init_FIRST(void){
   set_pwm1_duty(0);
   led_demo();
   // pin A0 measures temperature,pin A1 measures battery voltage:
   //I WANT VREF LOW TO BE PIN A2 TO BE LOW REFERENCE IT'S GROUNDED AND
   //PIN A3  HIGH REFERENCE IT'S VOLTAGE COMES FROM REFERENCE IC REF02 TO PIN A3
   //IS THIS OK FOR MY PURPOSE ?????
   setup_adc_ports(sAN0 | sAN1 | VREF_VREF);
   //It is now set to use the two external Vref pins and allow readings
   //from AN0 and AN1.
   setup_adc(ADC_CLOCK_DIV_16);
  //THIS WORKS
float meas_temp(void){
      float PV;
      set_adc_channel(sAN0);
      delay_ms(20);
      PV = read_ADC();
      return PV;
 //BUT THIS DON'T WORK !!!!!!!!
 //MY battery_V is measured about 2.5 V but lowbat_led is allways ON
//battery_V = 900;    this make it OFF ok
 void test_battery(void){
      int16 battery_V;
      set_adc_channel(sAN1);
      delay_ms(20);
      battery_V = read_ADC();
      delay_ms(20);
      //battery_V = 900;
      if(battery_V <= 10)      //battery voltage below 8 V turn lowbat_led_ON
         lowbat_led_ON;
      if(battery_V > 10)      //battery voltage more than 8 V turn lowbat_led_OFF
         lowbat_led_OFF;
PostPosted: Mon Oct 07, 2019 7:13 am     Reply with quote
Two things:
First you only need to do the actual 'setup', once. So just have:
Once at the start of the code. This is not needed again.
The reason it is not working, is the wrong value for the set_adc_channel
command. This doesn't want/take the defines sAN0 etc. It just takes the
channel number. So you just want:
set_adc_channel(0);
and
set_adc_channel(1);
Smile
artohautala
PostPosted: Mon Oct 07, 2019 7:37 am     Reply with quote
Ttelmah wrote:
Two things:
set_adc_channel(0);
and
set_adc_channel(1);
Smile
Thank you very much ... now it works fine !!
all the best
-arto-
Smile
