Pic18F46k22 Bootloader?
Badwoef
PostPosted: Fri Jul 12, 2019 4:35 am     Reply with quote
Good day all, have anybody got the CCS bootloader to work on the 18F46k22?
Have been trying for a long time now, got it working once but never wanted to load again. Would appreciate it if someone could share their loader.c and load.c files as I have to get a reliable bootloader working.
Thanx in advance.
PostPosted: Sat Jul 13, 2019 7:24 pm     Reply with quote
Post your CCS compiler version, and please don't let it be vs. 5.008 or
some low number like that.
Badwoef
PostPosted: Sun Jul 14, 2019 11:48 pm     Reply with quote
I am currently using ver.5.082
PostPosted: Mon Jul 15, 2019 1:31 am     Reply with quote
The CCS loader.c file says this at the top:
The driver uses XON/XOFF flow control. Also, any buffer on
the PC UART must be turned off, or to its lowest setting,
otherwise it will miss data.
Did you enable XON/XOFF in Windows ?
Badwoef
PostPosted: Mon Jul 15, 2019 1:44 am     Reply with quote
Yes I did, I am not really sure what the memory mapping settings should be and suspect that this might be the problem.
PostPosted: Mon Jul 15, 2019 1:55 am     Reply with quote
If the #org settings are wrong, it won't compile. Does it compile with
no errors ?
