Output_high() function
Thomas
PostPosted: Sun Dec 22, 2002 2:22 pm     Reply with quote
Hi everyone,
I have a variable which contain the address of a port, but I want to use this variable for the Output_high() function. The Output_High() function, as you know, requires a constant in its argument. How do I "convert" the content of a variable to a constant so I can use in the Output_High() function.
test = BIT_A3;
Output_High(test); //?
Thank you in advance
___________________________
Original Post ID: 10202
Dale Herman
Re: Output_high() function
PostPosted: Sun Dec 22, 2002 4:47 pm     Reply with quote
cant
<a href="http://www.ccsinfo.com/faq/?26" TARGET="_blank">http://www.ccsinfo.com/faq/?26</a>
Original Post ID: 10203
Tomi
PostPosted: Mon Dec 23, 2002 2:34 am     Reply with quote
If you use FIXED_IO or any other way to be sure that the port pin is in output state then you can use the following:
void My_Output_High(char bitaddress)
char byteaddr,bitaddr;
byteaddr = bitaddress >> 3;
bitaddr = bitaddress & 0x07;
bit_set(*byteaddr,bitaddr);
If you use 16F87X then it is possible to use:
bit_clear(*(byteaddr | 0x80),bitaddr); // set pin to output
And of course you can use the same way for 18Fxx2 to compute the right TRIS register address.
:=Hi everyone,
:=I have a variable which contain the address of a port, but I want to use this variable for the Output_high() function. The Output_High() function, as you know, requires a constant in its argument. How do I "convert" the content of a variable to a constant so I can use in the Output_High() function.
:=test = BIT_A3;
:=Output_High(test); //?
:=Thank you in advance
Original Post ID: 10212
Bruce R. Knox
PostPosted: Mon Dec 23, 2002 7:37 am     Reply with quote
:=Hi everyone,
:=test = BIT_A3;
Assuming you mean that your variable contains the address of a BIT on a port, why not use bit_set(addr,bit)?
For example:
#byte PORTA = 5
int test;
test = 3; // Bit 3 position
bit_set(PORTA,test); // as in the CCS manual!
Of course, you'll have to have set up the TRIS register(s) on your own to use this method.
Bruce
Original Post ID: 10214
