Trial Version of PCD: what modules are supported
jehcc
PostPosted: Sat Jan 12, 2019 7:26 pm     Reply with quote
In test driving the PCD compiler from MPLAB X v5.10 I am getting a lot of compile failures without any helpful error messages.
I am wondering if that is due to the limitations of the trial version, the description states that "Only 15% of the example programs and drivers are provided".
Is there any way to tell if my test project falls into this category?
dluu13
PostPosted: Sat Jan 12, 2019 8:09 pm     Reply with quote
It would be helpful if you posted some code and the compiler output anyway.
This page shows all the drivers and example code that are included with the full version:
http://www.ccsinfo.com/devices.php?page=exlist
You can compare that list with the Program Files\PICC\Drivers and examples folder to see what you are missing.
As far as I am aware, everything of the core compiler is included and only those drivers and examples will be missing a majority. In other words, I think that if a function is in the manual then it should be supported.
dluu13
PostPosted: Sun Jan 13, 2019 12:39 pm     Reply with quote
I think this is actually relevant info since you are using MPLAB X.
I recently purchased the PCD command line compiler (v 5.082) and the first time I tried to compile with MPLAB X, the compiler would get stuck. The CCS compiler window would hang, saying "Not Found". However, compiling from the command line would work. I contacted CCS support and they provided me with a new ccsc.exe.
You should also contact the email address at the top right of the forum board for technical support if that's what you are experiencing.
