I2C CCS Compiler
Goto page Previous  1, 2
AlbertoBu
PostPosted: Tue Dec 18, 2018 2:16 pm     Reply with quote
Ttelmah wrote:
Does that imply you don't have a chip, but an Arduino module?.
If so, this may have a 3.3v power supply built in.
yeah I know and I tried but for some reason when i plug 3 devices to my usb ports each port gives less than 5 volts (4V exactly) and I cant run the pic but that was the point yeah.
PostPosted: Tue Dec 18, 2018 2:36 pm     Reply with quote
Sounds like you're drawing too much current from the USB ports. Providing the USB port is configured correctly you can get 1 amp at 5 volts all day long. The 'trick' is to confirm you have configured the USB port. I had an 'odd' situation 2-3 years ago where some 'app' reconfigured a USB port for a lower power setting !! Don't know which one but after I configured it for full power, it was fine. I've since gone back to a dedicated PC for PIC stuff...NO internet, no apps..just Windows, MPLAB and CCS compiler with NO updates allowed.
Jay
AlbertoBu
PostPosted: Tue Dec 18, 2018 2:45 pm     Reply with quote
Yeah i'll take a look on the USB because there are situations when I only plug the pickit3 and sometimes the port gives me less than 5 volts.
Page 2 of 2
