how is the deep sleep?
Goto page 1, 2  Next
cvargcal
PostPosted: Thu Sep 27, 2018 5:52 pm     Reply with quote
Hi, I want put mode sleep the micro 18LF26K22.
This is my configuration:
#fuses HSH, NOWDT, BROWNOUT, PUT, NOPBADEN, NOHFOFST, INTRC_IO, MCLR , NOLVP
//#fuses WDT_SW         //No Watch Dog Timer, enabled in Software
#use delay(internal=4MHz)
The datasheet say the mode sleep consume 100 nA but I make the measure and take 42 uA =42000nA.
On the pcb, only solder the micro and the resistor MCLR no more... and put to sleep the micro and wake up with ext0.
What is the problem? The 100nA is theoretical?
output_toggle(LED_CMD);
delay_ms(2000);
sleep();
PostPosted: Thu Sep 27, 2018 9:28 pm     Reply with quote
You can start by disabling Brownout, and set all unused i/o pins to be
low level outputs. Don't leave them as floating input pins.
PostPosted: Fri Sep 28, 2018 12:47 am     Reply with quote
PCM_programmer has covered the first key points.
If you look at the table giving the 100nA figure, this is with
WDT, BOR, FVR and
SOSC disabled, all
Peripherals inactive
You have brownout enabled. This uses 8uA....
Then the critical thing about pins, is that if they 'float' to a voltage that is in the transition region for the input, they will draw unexpected power. They need to either be driven by the PIC to a level that draws no current from the pin, or be externally biased by a resistor to a level outside this region. So assuming they are not actually connected to anything, as PCM says, drive them low.
Then your code should have a 'delay_cycles(1);' after the 'sleep' instruction. This is standard for the PIC. The instruction here is #pre-fetched' when you sleep, and needs to be a NOP. delay_cycles(1) gives this.
Now you don't show anything allowing you to wake on INT_EXT.
To do this needs something like:
#include <18LF26K22.H>
#fuses NOWDT, BROWNOUT_NOSL, PUT, NOPBADEN, NOHFOFST, INTRC_IO, MCLR , NOLVP, NOXINST
//HSH.... No. You are using the internal RC, you don't want the HS oscillator
//enabled.
//Brownout now disabled when sleeping
#define LED_CMD PIN_B1 //whatever pin your LED is on
#byte ANSELA=getenv("SFR:ANSELA")
#byte ANSELB=getenv("SFR:ANSELB")
#byte ANSELC=getenv("SFR:ANSELC")
   int ctr;
   setup_adc(ADC_OFF); //Otherwise by default this will be controlling B0
   setup_adc_ports(NO_ANALOGS);
   setup_comparator(NC_NC_NC_NC); //disable comparator
   setup_dac(DAC_OFF);
   ANSELA=0;
   ANSELB=0;
   ANSELC=0; //select all pins for digital I/O
   output_a(0); //drive all  I/O pins low
   output_b(0);
   output_c(0);
   output_high(LED_CMD); //set LED high initially
   output_float(PIN_B0); //Set INT0 pin as input
   delay_ms(1000); //delay so LED can be seen
   while (TRUE)
      disable_interrupts(GLOBAL);
      enable_interrupts(INT_EXT); //allow INT_EXT to trigger an interrupt
      //LED will need to be off here. Otherwise will draw power.
      //Not sure how driven, so setting low
      output_low(LED_CMD);
      clear_interrupt(INT_EXT); //ensure clear before trying to sleep
      sleep();
      delay_cycles(1);
      //will get here when INT_EXT triggers
      disable_interrupts(INT_EXT);
      //do something - flash LED a couple of times to show awake
      for (ctr=0;ctr<4;ctr++)
That should be close, unless I have missed something...
cvargcal
PostPosted: Fri Sep 28, 2018 8:21 am     Reply with quote
Ttelmah wrote:
Thanks you so much.. its amazing, now is 0.18uA = 180nA
now if is as said the datasheet (100nA).
Every day is for learn more... Smile
PostPosted: Fri Sep 28, 2018 10:08 am     Reply with quote
The data sheet figure is only to one decimal. It does change with supply voltage, so is probably something like 80nA at the minimum supply, and rises to perhaps 140+uA at higher supplies. It is also 'typical', so between chips will probably vary by something like +/- 25%. So though your figure is upper end of what I'd expect, it sounds much better.
Glad you have a working figure now. Smile
cvargcal
PostPosted: Fri Sep 28, 2018 5:04 pm     Reply with quote
Well. the example work very good.... my PCB is a device LoRa:
This is my example code:
////////////////////  UARTs  ///////////////////////////////
#use rs232(baud=57600,xmit=PIN_c6,rcv=PIN_c7,bits=8,parity=N,ERRORS,stream=lora)  /// UART 1 LORA
#use rs232(baud=57600,xmit=PIN_b6,rcv=PIN_b7,bits=8,parity=N,ERRORS,stream=debug)  /// UART 2 DEBUG
// MAP
//*********PORTA
//none
//*********PORTB
#DEFINE BOTON1      PIN_B0    // Boton 1, (ext0)
//*********PORTC
#DEFINE RN2903_RST  PIN_C4    // RESET RN2903 ( whit drive)
#DEFINE LED_CMD     PIN_C5    // LED CMD
static short button_pressed=FALSE;
int8 moduleBufferIndex=0;
short messageReady=0;
unsigned char moduleResonseBuffer[64]="";
char bufferByte=0x00;
void clean_buffer();
void blink_led(int);
void main(void) {
   setup_dac(DAC_OFF);
   ANSELA=0;
   ANSELB=0;
   output_b(0);
   output_c(0);
  ext_int_edge(0, L_TO_H);                  // Set up PIC18
  enable_interrupts(int_ext);
  enable_interrupts(int_rda);
   while (TRUE)
     // Wake up module ... PIN MCLR High
     delay_ms(1000);  // wait to module it ok..
      if(button_pressed) blink_led(1);
      clean_buffer();
      fprintf (lora,"sys sleep 4294967296\r\n"); ///49.8 dias
      fprintf (debug,"to sleep\r\n"); ///49.8 dias
      sleep();
      delay_cycles(1);
#int_rda
void rda_isr(){
           bufferByte = getchar(lora);
        // See what we got
        if (bufferByte == 0x0D){
            moduleResonseBuffer[moduleBufferIndex] = 0x00;   // Add Null terminator
            messageReady=1;
            moduleBufferIndex = 0;                           // Prepare index for next message
        else if ( (bufferByte == 0x00) || (bufferByte == 0x0A) )
            // Do nothing
            moduleResonseBuffer[moduleBufferIndex++] = bufferByte; // Add Byte to Buffer
#int_ext
void ext_isr(void){
  button_pressed=TRUE;
void clean_buffer(){
   memset(moduleResonseBuffer,0x00,sizeof(moduleResonseBuffer));
void blink_led(int times){
  int i;
   for(i=0;i<=times;i++){
      delay_ms(10);
I want configure all and sleep the module and sleep the pic.. if ext0 is activated, so blink led and sleep again.
But no work...
The data sheet say the pic sleep 100 nA and the module RN2903 0.0032mA... I search sleep all.
The Module only used TX, RX, MCLR for reset ... I think the power is high when use the uart. Because when I solder the module the power go since 0.001 mA to 5mA - 10 mA .... that eat any battery of 3V very soon.
PostPosted: Sat Sep 29, 2018 2:30 am     Reply with quote
First thing, look at how I wake from sleep. You don't need an INT_EXT handler, if INT_GLOBAL is not enabled.
You need to put the LoRa module to sleep before you sleep the PIC. Otherwise it will sit 'idle', not asleep. Difference is idle draws about 3mA....
Look at the sys sleep command in the reference.
You will need to set it for a really long time (millions of seconds), then when the PIC wakes, send a break character followed by 0x55, which will wake it and reset it's UART baud rate automatically.
   setup_uart(FALSE, LORA); //turn off the UART
   output_low(PIN_C6);
   delay_us(250); //at 57600 174uSec is required for a break
   output_high(PIN_C6);
   setup_uart(57600, LORA); //re-enable the UART
   fputc(LORA,0x55);
   //The lora module will now be awake.
cvargcal
PostPosted: Sat Sep 29, 2018 7:30 am     Reply with quote
Ttelmah wrote:
Thank you, I tried many for wakeup by software but no work... so to end I did with the master clear from module...
When I put fprintf (lora,"sys sleep 4294967296\r\n"); ///49.8 days
The device go to sleep, but the power is 3 to 5 mA.
I try send more command for "look" if its sleep... and not answer... I think its sleep.
Please help me to configure the pic for only sleep the module and wakeup the pic... after the module I wake with Reset Pin.
I solder all less the module on PCB try your code and the power is 0.001mA but once I solder the module even up to 20mA.
Maybe the interruption UART make up the power?
#use rs232(baud=57600,xmit=PIN_c6,rcv=PIN_c7,bits=8,parity=N,ERRORS,stream=LORA)  /// UART 1 LORA
//!#use standard_io(A)
//!#use standard_io(B)
//!#use standard_io(C)
#define LED_CMD PIN_C5 //whatever pin your LED is on
void wakeup();
void main(void) {
int ctr;
//!   //-------------- Configuración de TRISx-----------------
//!  set_tris_a(0b11111111);
//!  set_tris_b(0b10111111);
//!  set_tris_c(0b10000000);
   setup_dac(DAC_OFF);
   ANSELA=0;
   ANSELB=0;
   output_b(0);
   output_c(0);
   int i=0;
   while (TRUE)
      i++;
      output_low(LED_CMD);        //LED will need to be off here. Otherwise will draw power.       //Not sure how driven, so setting low
      fprintf (LORA,"sys sleep 4294967296\r\n"); /// 49.8 dias
      fprintf (debug,"to sleep %i\r\n",i);       //  49.8 dias
      sleep();
      delay_cycles(1);
      for (ctr=0;ctr<4;ctr++){
       wakeup();
void wakeup(){
   output_low(PIN_C6);         //
   output_high(PIN_C6);        //
   fprintf (LORA,"%c",0x55);       //  49.8 dias
   //fputc(LORA,0x55);
PostPosted: Sat Sep 29, 2018 10:16 am     Reply with quote
There is an erratum for the module, having it drawing more power than the data sheet says, but still not the level you are seeing.
You are sleeping fully so all peripherals are off. However all lines will drive to their static levels. So you need to test each I/O line and see if power is drawn when you take each line to it's driven state.
So (for instance) disable uart1, and then drive the TX line high. Does the power go up?. If it does you need to work out what is wrong with the connection. The input to the radio module should not draw any significant current.
cvargcal
PostPosted: Sat Sep 29, 2018 10:43 am     Reply with quote
Ttelmah wrote:
I See just when I solder TX and RX to module go to 11mA .
this 2 lines are direct to pic...
How I off the uart, only put to 0 TX?
PostPosted: Sat Sep 29, 2018 12:41 pm     Reply with quote
That's what I do in the wake up code.
   output_low(PIN_C6);
This puts TX low. Used here to send a break.
cvargcal
PostPosted: Sat Sep 29, 2018 1:59 pm     Reply with quote
   output_low(PIN_C6);
Thanks you... now if work the wakeup by software... But still all device take 3.2mA I think the module lora the michochip it not good... and that 3mA is the normal energy... Or maybe all GPIO RN2903 should be to GND
Well.. thank you the down was 20mA to 3.2mA its very good but... my wish is max 1mA... its amazing I solder all component less the module and the consume is 0.001mA... all this power it took by TX and RX...
maybe it better turn off the module before to sleep.
newguy
PostPosted: Sat Sep 29, 2018 2:13 pm     Reply with quote
Try setting both RX and TX lines on the PIC to 0 (low level). I wonder if the RF module is partially powering itself from the logic high (idle level) on the PIC's TX pin.
PostPosted: Sun Sep 30, 2018 1:14 am     Reply with quote
If you do a search on the lora module, you will find a lot of threads with people having problems with their low power consumption. Honest answer best thing to do is add a FET, and turn the modules power physically off when you want low power...
PostPosted: Sun Sep 30, 2018 4:59 am     Reply with quote
and.... use a larger capacity battery.
Sounds obvious but why struggle with using a physically small battery ? All my remote (battery) devices have 'huge' batteries in them good for 5-10 years and are cheaper than a day's R&D costs to 'tweak' code and components.
Goto page 1, 2  Next
Page 1 of 2
