pic16f877a CFGWORD2 not implemented
electrobaiker
PostPosted: Mon May 28, 2018 4:23 pm     Reply with quote
this is the code
//LCD module connections
#define LCD_RS_PIN PIN_D0
#define LCD_RW_PIN PIN_D1
#define LCD_ENABLE_PIN PIN_D2
#define LCD_DATA4 PIN_D3
#define LCD_DATA5 PIN_D4
#define LCD_DATA6 PIN_D5
#define LCD_DATA7 PIN_D6
//End LCD module connections
#include <16F887.h>
#fuses NOMCLR NOBROWNOUT NOLVP INTRC_IO
#use delay(clock = 8MHz)
#include <lcd.c>
short nec_ok = 0;
unsigned int8 nec_state = 0, command, inv_command, i;
unsigned int16 address;
unsigned int32 nec_code;
#INT_EXT                                         // External interrupt
void ext_isr(void){
  unsigned int16 time;
  if(nec_state != 0){
    time = get_timer1();                         // Store Timer1 value
    set_timer1(0);                               // Reset Timer1
  switch(nec_state){
    case 0 :                                     // Start receiving IR data (we're at the beginning of 9ms pulse)
      setup_timer_1( T1_INTERNAL | T1_DIV_BY_2 );   // Enable Timer1 module with internal clock source and prescaler = 2
      set_timer1(0);                             // Reset Timer1 value
      nec_state = 1;                             // Next state: end of 9ms pulse (start of 4.5ms space)
      i = 0;
      ext_int_edge( H_TO_L );                    // Toggle external interrupt edge
      return;
    case 1 :                                     // End of 9ms pulse
      if((time > 9500) || (time < 8500)){        // Invalid interval ==> stop decoding and reset
        nec_state = 0;                           // Reset decoding process
        setup_timer_1(T1_DISABLED);              // Stop Timer1 module
        nec_state = 2;                           // Next state: end of 4.5ms space (start of 562µs pulse)
      ext_int_edge( L_TO_H );                    // Toggle external interrupt edge
      return;
    case 2 :                                     // End of 4.5ms space
      if((time > 5000) || (time < 4000)){        // Invalid interval ==> stop decoding and reset
        return;
      nec_state = 3;                             // Next state: end of 562µs pulse (start of 562µs or 1687µs space)
      return;
    case 3 :                                     // End of 562µs pulse
      if((time > 700) || (time < 400)){          // Invalid interval ==> stop decoding and reset
        setup_timer_1(T1_DISABLED);              // Disable Timer1 module
        nec_state = 4;                           // Next state: end of 562µs or 1687µs space
      return;
    case 4 :                                     // End of 562µs or 1687µs space
      if((time > 1800) || (time < 400)){         // Invalid interval ==> stop decoding and reset
        return;
      if( time > 1000)                           // If space width > 1ms (short space)
        bit_set(nec_code, (31 - i));             // Write 1 to bit (31 - i)
      else                                       // If space width < 1ms (long space)
        bit_clear(nec_code, (31 - i));           // Write 0 to bit (31 - i)
      i++;
      if(i > 31){                                // If all bits are received
        nec_ok = 1;                              // Decoding process OK
        disable_interrupts(INT_EXT);             // Disable the external interrupt
#INT_TIMER1                                      // Timer1 interrupt (used for time out)
void timer1_isr(void){
  ext_int_edge( L_TO_H );                        // External interrupt edge from high to low
  clear_interrupt(INT_TIMER1);                   // Clear Timer1 interrupt flag bit
void main(){
  setup_oscillator(OSC_8MHZ);                    // Set internal oscillator to 8MHz
  set_tris_b(0x01);
    set_tris_d(0x00);
  lcd_init();                                    // Initialize LCD module
  lcd_putc('\f');                                // LCD clear
  enable_interrupts(GLOBAL);                     // Enable global interrupts
  enable_interrupts(INT_EXT_L2H);                // Enable external interrupt
  enable_interrupts(INT_TIMER1);                 // Enable Timer1 interrupt
  lcd_gotoxy(1, 1);
  printf(lcd_putc, "Address:0x0000");
  lcd_gotoxy(1, 2);                              // Go to column 1 line 2
  printf(lcd_putc, "Com:0x00 In:0x00");
  while(TRUE){
    if(nec_ok){                                  // If the mcu successfully receives NEC protocol message
      nec_ok = 0;                                // Reset decoding process
      nec_state = 0;
      address = nec_code >> 16;
      command = nec_code >> 8;
      inv_command = nec_code;
      lcd_gotoxy(11, 1);                         // Go to column 11 line 1
      printf(lcd_putc,"%4LX",address);
      lcd_gotoxy(7, 2);                          // Go to column 7 line 2
      printf(lcd_putc,"%2X",command);
      lcd_gotoxy(15, 2);                         // Go to column 15 line 2
      printf(lcd_putc,"%2X",inv_command);
      enable_interrupts(INT_EXT_H2L);            // Enable external interrupt
when i start the simulation in proteus i get this error list
PROSPICE 8.02.00 (Build 18620) (C) Labcenter Electronics 1993-2015.
Loaded netlist 'C:\Users\wahab\AppData\Local\Temp\LISA4057.SDF' for design '6 KANAL.pdsprj'
PIC16 model release 8.03.00 (Build 19892) simulating PIC1684 device. [U1]
PIC16 model release 8.03.00 (Build 19892) simulating PIC1684 device. [U2]
PIC16 model release 8.03.00 (Build 19892) simulating PIC168771 device. [U3]
Loaded 64 bytes of persistent EEPROM data. [U1]
[COFF] Loading PIC COFF file 'D:\pic\rf remote pic16f84a\rf_remote_pic16f84a.COF'. [U1]
END Of BOOTING [U1]
Loaded 277 program words and 0 data bytes. [U1]
Loaded 64 bytes of persistent EEPROM data. [U2]
[COFF] Loading PIC COFF file 'D:\pic\rf remote pic16f84a\reciver\ir modified\rf_remote_pic16f84a.COF'. [U2]
END Of BOOTING [U2]
Loaded 280 program words and 0 data bytes. [U2]
Loaded 256 bytes of persistent EEPROM data. [U3]
[COFF] Loading PIC COFF file 'D:\pic\rf remote pic16f84a\reciver\interrupt and timer0  pic16f877a\16f877a_nec_decoder.COF'. [U3]
CFGWORD2 not implemented [U3]
END Of BOOTING [U3]
Loaded 894 program words and 0 data bytes. [U3]
[PIC16 MEMORY] PC=0x0311. Attempt to write unimplemented memory location 0x008F with 0x71 ignored. [U3]
[PIC16 MEMORY] PC=0x0312. Attempt to read unimplemented memory location 0x008F ignored. [U3]
[PIC16 MEMORY] PC=0x0318. Attempt to read unimplemented memory location 0x0189 ignored. [U3]
[PIC16 MEMORY] PC=0x031A. Attempt to write unimplemented memory location 0x0189 with 0x00 ignored. [U3]
[PIC16 MEMORY] PC=0x0320. Attempt to write unimplemented memory location 0x0188 with 0x00 ignored. [U3]
[PIC16 MEMORY] PC=0x0322. Attempt to write unimplemented memory location 0x0107 with 0x00 ignored. [U3]
[PIC16 MEMORY] PC=0x0323. Attempt to write unimplemented memory location 0x0108 with 0x00 ignored. [U3]
[PIC16 MEMORY] PC=0x0324. Attempt to write unimplemented memory location 0x0109 with 0x00 ignored. [U3]
[PIC16 MEMORY] PC=0x0329. Attempt to write unimplemented memory location 0x008F with 0x71 ignored. [U3]
[PIC16 MEMORY] PC=0x032A. Attempt to read unimplemented memory location 0x008F ignored. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 2.304000. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 4.608000. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 6.912000. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 9.216000. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 11.520000. [U3]
[PIC16] PC=0x0354. Processor has been reset by watchdog timer expiring at time 13.824000. [U3]
Thanks in advance to help solve this problem.
PostPosted: Mon May 28, 2018 5:28 pm     Reply with quote
Your title says this:
But your code says this:
#include <16F887.h>
So which is it ? Those are two different PICs.
PostPosted: Mon May 28, 2018 5:34 pm     Reply with quote
get rid of Proteus !!!
please read PIC101
this...
appears to ONLY simulate 2 devices, neither is your device...
so I'll assume your version of Proteus is NOT capable of simulating the PIC you're trying to use, well test.
electrobaiker
PostPosted: Mon May 28, 2018 5:51 pm     Reply with quote
I changed #include <16F887.h> to #include <16F877a.h>
The problem now is I can't get 1us delay in Timer1.
Using this prescaler config
What is wrong please ?
PostPosted: Mon May 28, 2018 6:17 pm     Reply with quote
well I counted 5 or 6 lines where you disabled timer1( including inside the ISR) and nowhere you enable it after the first 'initialization' code..
the code seems correct
8MHz Fosc/4= 2 MHz then /2 give 1MHz which is 1us...
electrobaiker
PostPosted: Mon May 28, 2018 6:56 pm     Reply with quote
Yes now it work properly. The problem with Timer1 delay come from i miss to set pic frequency in proteus to 8 MHz, by default it is 1 MHz.
Thanks for your support.
