Timer 1 behaving strange
Frans
PostPosted: Mon Jan 19, 2004 6:56 am     Reply with quote
Could someone help me white this problem #int timer_1.
this is the code. i have a questio about.
when leaving out the two line markt with **, the timer 1 give an interrupt every 16uS (see set_timer1 at FF90). When insert the line markt with ** the code works great and give a correct interupt.
I do not know what cousing the problem, could someone help to explane why behaving so strange.
thanks
Frans n
#include "C:\Program Files\PICC\progam\dmx.h"
#int_RDA
RDA_isr()
Dmx_data = getc();
if (bit_test(RS232_ERRORS,1) == 1) //is er een overflow oerr test
if (bit_test(RS232_ERRORS,2) == 1) //break detect FERR bit test
disable_interrupts(INT_RDA);
setup_timer_1(T1_INTERNAL); **
set_timer1(0xFF90);
output_low(PIN_B2);
delay_cycles( 2 );
output_high(pin_B2);
if (Break_true == true) // break is true
// output_low(PIN_B2);
// delay_cycles( 2 );
// output_high(pin_B2);
Break_true = false;
#int_TIMER1
TIMER1_isr()
disable_interrupts(INT_TIMER1);
setup_timer_1(T1_DISABLED);**
output_low(PIN_B2);
delay_cycles( 2 );
Break_true = true;
enable_interrupts(INT_RDA);
//int8 Dmx_data;
Break_true = false;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_2(T2_DISABLED,100,1);
// enable_interrupts(INT_TIMER1);
enable_interrupts(global);
while(TRUE);
neil
Could be this...
PostPosted: Mon Jan 19, 2004 7:39 am     Reply with quote
Hello, firstly, your setup_timer1 command seems incomplete, you are not setting up the prescaler. The line should be something like:
setup_timer_1 ( T1_INTERNAL | T1_DIV_BY_4 );
You will only need to setup timer 1 once, unless you wish to change the prescaler rate.
Secondly, there is no need to disable and re-enable the interrupts and the timer when inside the ISR. This will cause problems. I know that with some architectures this is common practise, but the pic handles interrupts differently. I ran into this problem a while ago. See this post: http://www.ccsinfo.com/forum/viewtopic.php?t=16799&highlight=
Look at the 3rd post down from RJ Hamlett. This explains the problem you seem to be having!
Hope this helps!
Neil.
