MQ7 carbon monoxide sensor
PrinceNai
PostPosted: Fri Apr 06, 2018 11:44 am     Reply with quote
Dear All,
I wonder if any of you have used the MQ7 sensor? I have a few of Flying Fish modules from China. I read on an Arduino forum that some kind of modifications on board are needed to make it work. I don't need a 1ppm accuracy, just simple "CO is present more than it is usual". Any sample code would be greatly appreciated.
Regards, Samo
PostPosted: Fri Apr 06, 2018 3:22 pm     Reply with quote
Why not just grab the Ardunio code, convert to CCS? When you've got it 'up and running', post in the code library here, so others can use it too.
