different baud rates on hardware uart
bcs99
PostPosted: Wed Jan 14, 2004 4:17 pm     Reply with quote
I have a display that transmits at 19200 and has no need to receive and a GPS that receives at 4800 and has no need to transmit. Is it possible to use the hardware usart with Tx at 19200 and the Rx at 4800 at the same time?
Bob
bcs99
correction
PostPosted: Wed Jan 14, 2004 4:18 pm     Reply with quote
That should be that - I want to transmit at 19200 to the display and receive at 4800 from the GPS.
Bob
Haplo
PostPosted: Wed Jan 14, 2004 4:59 pm     Reply with quote
You can use the function SET_UART_SPEED(baud, [stream]) to change the baud rate on the fly.
Mark
PostPosted: Wed Jan 14, 2004 7:19 pm     Reply with quote
But you cannot send and receive at the same time with different baud rates.
Haplo
PostPosted: Wed Jan 14, 2004 8:15 pm     Reply with quote
Yes. What you have to do is to set the baud rate and send, then switch the baud rate and receive. Shouldn't be difficult to manage.
