Posted: Thu Nov 09, 2017 11:05 am |
The command to read a pin without changing it is 'output_state'.
if (output_state(PIN_B1)==0)
tests that pin B1 is low, without changing it to be an input. |
jacktaylor
| Thank you Ttelmah |
Posted: Fri Nov 10, 2017 9:42 am |
This if (output_state (PIN_B1) == 0) command does not appear in the ccs manual.
And when I enter it in my code, it presents error in the complication:
*** Error 12 "RelogDispl7Seg.c" Line 42 (22,23): Undefined identifier - output_state
| Ttelmah wrote: | The command to read a pin without changing it is 'output_state'.
Posted: Fri Nov 10, 2017 9:45 am |
| It actually should be input_state(). Try that. That's in the manual. |
Posted: Fri Nov 10, 2017 9:49 am |
jacktaylor
| Thank you friend PCM programmer |
Posted: Sun Nov 12, 2017 3:31 pm |
| PCM programmer wrote: | | It actually should be input_state(). Try that. That's in the manual. |
jacktaylor
| Thank you Ttelmah |
Posted: Sun Nov 12, 2017 3:32 pm |
Thank you friend Ttelmah
