Fastest way to set pin output
Goto page Previous  1, 2
curt2go
PostPosted: Sat Jul 08, 2017 8:07 pm     Reply with quote
That means that I am using ICD1 position on the chip for debugging.
Yes its in Release mode.
Newguy thats a good tip. Thanx
PostPosted: Sun Jul 09, 2017 11:00 am     Reply with quote
temtronic wrote:
hmm..
OK maybe another silly thing...
I see this" icd=1 ", does that mean the ICD IS enabled ? I do not use ICDs or debuggers so not sure what the syntax means.
IF so that may slow down things.
Also I assume program is compiled in 'release' mode not 'debug'...
There's only so many straws in a bale but eventually we'll pull the right one !
Jay
Just as an explanation on this. A lot of the later PIC's have multiple sets of ICD pins that can be used. This instruction specifies which pin 'set' is going to be used, _but does not enable the ICD_. The debug enable is still the normal DEBUG instruction. Very Happy
Alphada
PostPosted: Sun Jul 09, 2017 1:39 pm     Reply with quote
newguy wrote:
Alphada wrote:
#byte PORTA = 0x0E22
The compiler has a very nice feature, "getenv" that saves you from looking up the addresses of the special function registers (SFRs). Use it like this:
#byte PORTA=getenv("sfr:PORTA")
Thx!
Page 2 of 2
